RailUK Forums > Fares, Ticketing & Routeing > Fares Advice & Policy
Closed Thread
Thread Tools
Old 25th January 2017, 12:39   #1
Default 'Routes your ticket is valid on' - NRE website feature
There's a button on the NRE website that attempts to show valid routes for tickets. It's available when you click on the 'Other fares' link or click to view an itinerary. Is this a new feature, or have I just been blind to it in the past?
It's not great as it only shows three valid routes for a Dundee to London ticket, but if they work on it then it could be useful.
__________________
Favourite saying: "There's no difference between theory and practice. In theory."
najaB is offline
Registered users do not see these banners - join today!
Old 25th January 2017, 13:21   #2
FenMan
Default
It's been around for a while.
It won't bring up all the valid routes immediately though. Some have to be forced by adding appropriate via points.
Try Wokingham to London and select the Any Permitted ticket. It won't display the valid routes via Guildford or via Chertsey, unless forced.
FenMan is online now
Old 25th January 2017, 15:32   #3
Default
I suspect it just shows routes that have come up in the journey planner query.
__________________
Neil
Bletchleyite is online now
Old 25th January 2017, 17:34   #4
JB_B
Default
So far I've not found it to be particularly useful.
Just tried York to Brighton now.
Both are routeing points so that's typically valid (very broadly speaking ) ...
Via London: via ECML direct, or via ECML+Cambridge , or via MML; (and then BML) [AY EY KY]
Avoiding London via MML to Birmingham/Coventry Oxford -> Gatwick etc. [XB+BY]
( With, of course, a myriad of of possible routes within these broad descriptions.)
But on NRE you get back maps of four "valid" routes - each of which is identical at the resolution presented ( all ECML direct ->LONDON->BML). If you zoom in and look very carefully the four routes are identical apart from their slightly different routes through South London.
When I first thought took a look at it I concluded that the problem is they're just presenting the first n answers on a depth-first search ( so you get trivially different answers that are clustered around origin or destination.) I guess that could still be true if the planner is splitting the search at London.
There are potentially far too many different useful routes to display in this route-by-route format : the best way to show other valid routes would show the maps instead (consolidated and suitably redacted and annotated for easements/doublebacks.) That's not a straightforward thing to do.
If they're constrained to showing n individual routes then they should have need a measure of difference in the presented results so you at least begin to explore the space in a useful way (rather than showing almost identical answers.)
JB_B is offline
Old 25th January 2017, 19:00   #5
Default
Quote:
That's what I found as well. I'm going to play around with via points as suggested by FenMan and see what happens. Try some of the less common routes and see if it freaks out.
__________________
najaB is offline
Old 26th January 2017, 19:57   #6
paulweaver
Default
This is dangerous, as guards may declare as your route isn't shown on this page, it's not valid.
Either do it right or don't do it.
paulweaver is offline
Old 26th January 2017, 20:01   #7
shredder1
shredder1's Avatar
Default
What a great post, thanks very much to the OP
shredder1 is offline
Old 20th March 2017, 15:07   #8
AY1975
Default
It doesn't seem to offer you the option of adding via points.
I've also noticed that if you simply go to the National Rail homepage, it doesn't give you the 'Routes your ticket is valid on' tool, and it can be hard to find. It's best to go straight to it by clicking on the link: http://ojp.nationalrail.co.uk/NreOjp...rney/search#pr
At first sight the map does not appear to show via points, but it does if you zoom in.
AY1975 is offline
Old 21st March 2017, 00:09   #9
FenMan
Default
I've found the trick is to enter your preferred via point in the original search. Otherwise it's pot luck whether or not it will be displayed. That's ok for people who know what they're doing, but not for the public at large who don't take an interest in which routes are permitted.
Closed Thread
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletinŽ Version 3.8
© RailUK Forums 2005 - 2017
