RailUK Forums > Fares, Ticketing & Routeing > Fares Advice & Policy
Reply
Thread Tools
Old 19th March 2017, 14:14   #1
scarby
Default Woolwich Arsenal to Cambridge - valid via DLR?
An anytime day return from Woolwich Arsenal to Cambridge costs £36.30
An anytime day return from King's Cross to Cambridge costs £35.80.
Therefore for travelling from Woolwich Arsenal to Cambridge, the first fare is the obvious choice.
But can I simply use the DLR to commence my journey and go to Bank, then Northern Line to King's Cross?
Or do I have to take the rail service to London Bridge and change there?
The DLR route is much my preferred option for getting to King's Cross in the morning peak.
Thanks in advance.
scarby is offline   Reply With Quote
Registered users do not see these banners - join today!
Old 19th March 2017, 14:29   #2
bb21
Moderator
bb21's Avatar
Default
That is absolutely fine.
bb21 is offline   Reply With Quote
Old 19th March 2017, 14:33   #3
swt class 450
swt class 450's Avatar
Default
Thanks in advance.
Yes that should indeed be a a valid route. That ticket has a cross on it which means it is valid for cross London travel by Docklands Light Railway and London Underground services.
http://www.brfares.com/#faredetail?o...&ldn=1&tkt=SDR
And this page says that Woolwich Arsenal (DLR) and Kings Cross St Pancras (LU) are valid stations and routes.
http://www.nationalrail.co.uk/times_...pes/46587.aspx
So yes your ticket should definitely be valid on that route.
__________________
<a href=https://upload.wikimedia.org/wikipedia/commons/thumb/7/76/Class_450_South_West_Trains_Diagram.PNG/1280px-Class_450_South_West_Trains_Diagram.PNG target=_blank>https://upload.wikimedia.org/wikiped...ns_Diagram.PNG</a>
swt class 450 is offline   Reply With Quote
Old 19th March 2017, 15:36   #4
Joe Paxton
Default
Is there not sometimes the suggestion that for tickets with a cross-London transfer element (on the Tube and/or DLR), technically you shouldn't actually commence the journey on the Tube/DLR? i.e. It is supposed to be sandwiched between two NR journeys.
Easy enough to get around in most cases - in this instance, tickets from Plumstead or Abbey Wood to Cambridge cost the same as from Woolwich Arsenal (they are both just up the line from Woolwich).
Joe Paxton is offline   Reply With Quote
Old 20th March 2017, 09:46   #5
maniacmartin
Southern Commuter
maniacmartin's Avatar
Default
This view is taken by some LU staff, and the rules don't explicitly say one way or another. I would buy the ticket with Plumstead or Abbey Wood and start short so that this issue can't come up
__________________
Peak times are determined by the ticket, not the train
maniacmartin is offline   Reply With Quote
Old 20th March 2017, 10:48   #6
scarby
Default
Thanks everyone for the information and suggestions.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8
© RailUK Forums 2005 - 2017
