RailUK Forums > UK Railway Forums > Traction & Rolling Stock
Reply
Thread Tools
Old 19th May 2014, 06:36   #1
SpacePhoenix
Default Class 800
Was reading about the class 800s, on wikipedia it says that the diesel engines are under the floor. With the emissions/pollution regulations as they are, isn't any new design of DMU or DEMU that utilizes under-floor engines dead in the water before it even makes it to the drawing board?
SpacePhoenix is offline   Reply With Quote
Registered users do not see these banners - join today!
Old 19th May 2014, 06:56   #2
jopsuk
Default
Only if you take "internet received wisdom" as "fact".
jopsuk is online now   Reply With Quote
Old 19th May 2014, 07:43   #3
starrymarkb
starrymarkb's Avatar
Default
I think I know where it has come from. There was a rush to re-engine the last of the HST power cars as MTU's new version of the 4000V wouldn't fit in the Power cars. It's easier to accommodate the extra catalytic converters and other emission reduction gubbins in a new design then to shoehorn it into an existing one.
__________________
My Rail and Aviation Videos | My Flight Diary
Fallen Lovers Won't You Rise - Fallen Demons Won't You Fight
starrymarkb is offline   Reply With Quote
Old 19th May 2014, 15:09   #4
Chris125
Chris125's Avatar
Default
Quote:
IIRC the issue was mainly about the economics involved especially for the number likely to be needed and where, and the IEP does not appear to be a cheap train by any stretch of the imagination - that said 26m carriages presumably provides more room underneath than a 23m Turbostar carriage for example, while the door layout allows a higher floor.
Chris
Chris125 is offline   Reply With Quote
Old 19th May 2014, 17:56   #5
WatcherZero
Default
I think the rumour is down to the newer compliant engines firstly not being available at the time (they are now) and secondly having to be larger and not fitting underneath an existing design like a Turbostar.
WatcherZero is offline   Reply With Quote
Old 19th May 2014, 18:11   #6
Jonny
Default
There is a new version of the QSK-19 (used underfloor on Voyagers, Adelantes, Meridians and Pennines) that is compatible with the latest restrictions. It's the QSK-19R. Whether it would fit on existing designs is one thing, but it could easily be fitted to a new design built around it.
Jonny is offline   Reply With Quote
Old 20th May 2014, 01:29   #7
fgwrich
fgwrich's Avatar
Default
Quote:
Chris
Sounds lovely already, higher floors, thumping great big 700kW MTU 12V 1600 R80L constantly thumping away underneath almost constantly... reminds me of something else with higher floors, and thumping great Cummins engines constantly droning away underneath all the time.
It will be interesting to see how Hitachi accommodate the rather large MTU powerpack though, but I hope they do a good job of soundproofing first, and better underfloor mechanical layout than Alstom did of the Adelantes!
fgwrich is offline   Reply With Quote
Old 20th May 2014, 04:17   #8
Jonny
Default
I would expect the engine to be driving a generator/alternator which feeds traction motors for final drive, after all the IEP/Class 800 comes in either electric only or electro-diesel ("bi-mode") ^flavours^, and running like a DEMU when not drawing overhead traction power, rather than a mechanical/hydraulic unit like the Adelantes. With energy transferred as electrical current, as long as the wires are properly insulated and everything else is up to specification then it's pretty hard to go wrong.
Old 20th May 2014, 10:01   #9
asylumxl
I has this many monies..
asylumxl's Avatar
Default
I suggest you read the IEP specification if you haveb't. As with most new tenders, they have decibel limits for various situations and the volume in the passenger saloon shouldn't exceed the volume of a normal conversation.
__________________
This is not the signature you are looking for...
asylumxl is offline   Reply With Quote
Old 20th May 2014, 11:06   #10
cf111
Do Not Alight Here
cf111's Avatar
Default
I really don't see the issue with under-floor engines, at least in new stock. I've never found the Voyagers, for example, to be too loud. I actually prefer them to the creaking and squeaking of the vestibules in Mark 3 coaches. They just suffer from being too short for the job they're given.
Anyway, I hope the IEP is a good train because we're going to be stuck with it for a while!
cf111 is offline   Reply With Quote
Old 20th May 2014, 11:34   #11
tsr
"to stop specially at..."
tsr's Avatar
Location: Between the yellow line and the white line, probably undertaking technical work
Default
Quote:
When you've been sitting on similar trains (one or two Meridians, in my case) for long-distance journeys, and the engines have been faulty and vibrating horribly the whole time, then you come to realise that it's not always a good plan to keep them underfloor!
__________________
Friends come and go, but trains come and stay. Especially if the line is suspended. @BookOfMetro - Twitter
tsr is offline   Reply With Quote
Old 20th May 2014, 13:15   #12
NotATrainspott
Default
Please remember that the vast majority of passenger kilometres on the IEP fleet will be done under the wires where there would be no need for the diesel engine to be active. On the East Coast the worst case scenario is the Highland Chieftan but that will still spend most of its journey under the wires - currently there are 4 hours and 39 minutes (London-Haymarket) under the wires compared to the total 8 hours 6 minute journey time. With EGIP wiring up to Dunblane, this becomes 5 hours 28 under the wires around the same time that the IEP fleet will replace the HSTs on EC. As the rolling programme of electrification continues this under-wire journey time increases more and more and so there will be less and less time spent with the diesel engine running.
NotATrainspott is offline   Reply With Quote
Old 20th May 2014, 13:18   #13
Hairy Bear
E.M.T Driver H.S.T /222.
Hairy Bear's Avatar
Default
Worse engine Cummings have ever made. Noisy, unbalanced vibration and leak oil and water like theres no tommorow.
Hairy Bear is offline   Reply With Quote
Old 20th May 2014, 14:59   #14
Yew
Yew's Avatar
Default
Quote:
Thats still pretty loud.. Although I guess that might include the volume under heavy acceleration too?
Yew is offline   Reply With Quote
Old 20th May 2014, 16:17   #15
cjmillsnun
Default
I'd rather have that creak and squeak of those wonderfully comfortable Mk3s than the awful vibration I feel through the floor in a Voyager.
The jury's out on IEP. Many feel it's going to be an expensive piece of crap. It's certainly going to be expensive, and it will have an incredibly hard act to follow. Both the HST and 91/Mk4s were and are excellent trains that have proven to be very good at the job they do.
But then, many felt the same about HST when it took over from the Deltic. All we can do is wait and see.
cjmillsnun is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8
© RailUK Forums 2005 - 2017
