RailUK Forums > Other Rail & Transport > Transport Simulations & Games
Reply
Thread Tools
Unread 25th October 2010, 20:25   #286
Hidden Quality
Default
Hi guys,
I have windows 7, and have downloaded BVE 4 and BVE 2 and they dont work properly. Well, BVE 2 works, opens ina window, but doesnt display trains, etc properly. I have followed the ingtructions on this thread, but where my command prompt , cos i have 64 bit, should say c:/windows/sysWOW64 or something like that , it says c:/windows/system32, even though I have 64 bit. I dont, understand, and I have tried to change it to sysWOW64, but dont know how to. Any suggestions???
Mike
Hidden Quality is offline   Reply With Quote
Sponsored links - Registered users do not see these banners - join today!
Unread 29th January 2011, 14:21   #287
DavidMcCahon
Default
I had a Read threw that and tbh it makes no sense lmaoo, i dont really understand this kind off stuff but i am interested in playing the game. I am on Windows Vista, could someone add my msn (davidmccahon@hotmail.co.uk) and use teamviewer too do this for me please? Ohh anytime i download BVE it comes up images too, confussing
DavidMcCahon is offline   Reply With Quote
Unread 16th March 2011, 14:15   #288
Statto
I'm in the pub at the bar
Statto's Avatar
Default
Quote:
Originally Posted by GB View Post
Im using windows 7 and have downloaded the 3 dll files on the first page but when I enter them into the command promt I get this error....
Same thing is happening to me, i have Windows Vista.
[Homer Simpson style]Whoo, i've managed to get BVE4 working on Vista, i didn't use the dll files, i used the files from here http://openbve.trainsimcentral.co.uk...d_windows.html , had a run on the Bakerloo line, in Arcade mode.
Last edited by Statto; 16th March 2011 at 14:15. Reason: Double post prevention system
Statto is offline   Reply With Quote
Unread 22nd May 2011, 18:06   #289
tonytrainsfree
Default bve 4 windows 7
i can not get bve 4 to work on windows7 and i have opeon bve but it is vere slow
tonytrainsfree is offline   Reply With Quote
Unread 22nd May 2011, 18:23   #290
valenta
valenta's Avatar
Default
Quote:
Take a look at this page http://www.railsimroutes.net/openbve..._windows_1.php
Hope it helps.
__________________
PARDEW OUT
valenta is offline   Reply With Quote
Unread 7th January 2013, 20:43   #291
Darkedriver26
Train Lover
Default BVE on Vista
Hi, new to this forum but have been trying to get BVE4 to run under Vista.
have tried all the tricks on here but nothing has worked. Just installed Virtual PC2007 and have put windows xp on that, will try installing BVE4 tonight on the virtual pc and let you know what happens.
In all truth the installation of Virtual PC and XP was pretty painless and it should be no different than running the application normally (with the exception of a couple of extra mouseclicks).
Will let you know what happens.
Sadly no luck - Windows XP will not run Windows Update so has problems loading all the necessary files for BVE to run. I manually downloaded Dotnetframework 2, then had to get the Windows Installer 3.1 or above, then I had to get the Windows Imaging Component plus DirectX.
Then BVE kept failing with some sort of Runtime error (.net framework error) so I downloaded the Visual C++2005 redis in case that would help - it didn't.
So for all my efforts, no further forward - damn!
That's the end of my favourite sim...
Darkedriver26 is offline   Reply With Quote
Unread 7th January 2013, 21:02   #292
Bedpan
Default
When I got my present computer with Windows 7, I just downloaded Open BVE. I don't know the first thing about computers, but managed it with the help of http://www.railsimroutes.co.uk and it works perfectly. Open BVE's much better as other trains move, as does road traffic on bridges etc.
Bedpan is offline   Reply With Quote
Unread 7th January 2013, 21:07   #293
Darkedriver26
Train Lover
Default
I did try OpenBVE once before on XP but had so much trouble configuring it I gave up, perhaps I should try again?
Having said that I have managed to get BVE 5 running, its just that I have so much BVE4 routes etc that I now stand to lose the lot - bit of a shame as I love the LU stuff and Birmingham/treston run.
Unread 8th January 2013, 11:25   #294
Bedpan
Default
I think that you can load BVE4 routes onto Open BVE, I've got all the London Underground stuff.
Unread 8th January 2013, 17:10   #295
Darkedriver26
Train Lover
Default
Yeh, been trying that but when I select the route and the train it tells me to run it in BVE4 and won't let me go any further - weird...
Also tried running BVE4 on my old laptop with Win2K - Jeez, you wouldn't believe the problems I had with that, upgraded to XP and it still fell over yet on my old PC running XP it ran fine, grrr...
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright © 2000 - 2013, Jelsoft Enterprises Ltd.
© RailUK Forums 2005 - the year after 2012
