RailUK Forums > Rail Photography > Photography Sites & Videos > Photography Advice & Discussion
View Poll Results: Canon or Fuji
Canon Powershot S3 IS 1 9.09%
Fuji Finepix S6500fd 10 90.91%
Voters: 11. You may not vote on this poll
Closed Thread
Thread Tools
Unread 30th August 2007, 07:11   #61
5872
5872's Avatar
Default
Quote:
Originally Posted by Tom View Post
Fred - I'd just like to remind you that you still have a limit for 4 posts per day.
What , no I dont.
5872 is offline
Sponsored links - Registered users do not see these banners - join today!
Unread 30th August 2007, 07:39   #62
Nathan
Nathan's Avatar
Default
Ok i just voted in this poll and let is pass. Time for me to come to the light.
I brought the S5700 we've established it zooms during filming but only unless the object is moving fast when you pan will the zoom be good enough. Problem during filming is that it zooms too fast in and out, if it is very quiet you can hear what is like a small steam engine in the camera puffing away, a fairly light wind factor will mean all you get is noise because the microphone is so sensative! However all in all if you can get it right then it really does shoot film like quality. Of course for me its not a problem, i just use another camera for the videos, use it for what its worth and shoot photos only videos if you have too!
For evidence, 5:55 onwards to 8:15 http://youtube.com/watch?v=hPwQJSx7W3Q obviously from the grass you'll notice the wind
Purple fringing, yes it is present however it only ever occurs for me if im shooting into direct sunlight on a clear day, its not that big a deal. Just photoshop it later to reduce the effect but even then you have to zoom quite a lot to see it present. Chances are that if you dont have a tripod you wont be able to zoom in to maximum and get a clear shot even if you've got the image stablisation on. if you take a photo without a tripod at 10x well i can say for definate the quality wont be like a normal photo.
Macro, the camera having a wide lense means that close up shots are slightly distorted like using a fisheye to an extent. Good flash by all means in low light and even without flash so night shots not a problem. As for battery consumption the first set of batteries which came with the box lasted me my first 7 days before dieing, afterwards discharging my rechargables and ive been on my way since!
Hope this helps in anyway,
Nathan
__________________
http://www.youtube.com/34028
Nathan is offline
Unread 30th August 2007, 08:03   #63
5872
5872's Avatar
Default
Thanks for that nathan , Ive added your vid to my favourites its fantastic , I think I will get the s5700 , its ok and purple fringing isnt to bad.
ITS ARRIVED
5872 is offline
Unread 30th August 2007, 08:10   #64
thefab444
Default
Cheers for that Nathan, we need someone to convince him to buy a camera, any camera, so as to stop all this posting. Next thing will how brilliant the S5700 is, and then 94 threads on "How do you change the screen saze" "You can't" "What , someone said you culd" etc.
If the microphone is like that on S6500, its ok, but it picks up the wind like nobody's business. Again, if its like the S6500, there is a drop in contrast of photos as you zoom in. Not noticeable until you get into 9x/10x zoom, then things start getting a bit pale. Very easy to correct though.
Does the S5700 actually have image stabilization?
JS
__________________
Cleared classes: 444
thefab444 is offline
Unread 30th August 2007, 08:24   #65
Nathan
Nathan's Avatar
Default
JS
Yeah it does and thank goodness it has too. I simply avoid going to 9 or 10x when zooming, seeing as the photos are taken at 3072 x 2304 just going maybe to 7x max ensures that you are less likley to blurr the shot and when you get home you can just zoom in a bit more yourself without losing the quality!
__________________
Nathan is offline
Unread 30th August 2007, 08:33   #66
thefab444
Default
I thought it just had an anti-shake mode on the mode setting ring thing?
JS
__________________
Unread 30th August 2007, 10:30   #67
5872
5872's Avatar
Default
JS
Nope image stabilization , nathan what camera do you have???:.
5872 is offline
Unread 30th August 2007, 14:03   #68
devon_metro
Default
Doh
__________________
devon_metro is offline
Unread 30th August 2007, 14:11   #69
5872
5872's Avatar
Default
Quote:
Originally Posted by Liam View Post
Doh
Hmm , Looks like the s5700 isnt bad after all.
5872 is offline
Unread 30th August 2007, 14:24   #70
devon_metro
Default
Quote:
I was refering to that
__________________
Unread 30th August 2007, 14:35   #71
5872
5872's Avatar
Default
Well his vids and shots are good. So Im going to try now because the HP was such a let down. Now I can get good results.
5872 is offline
Unread 30th August 2007, 16:26   #72
Tom
Guest
Posts: n/a
Default
What , no I dont.
It was NEVER lifted.
Keep going over and expect a holiday.
Unread 30th August 2007, 16:35   #73
5872
5872's Avatar
Default
:error: , I had spent well over two months on it , so I gatherd it got lifted...
5872 is offline
Unread 30th August 2007, 19:29   #74
Nathan
Nathan's Avatar
Default
JS
Both, there is a setting for anti-shake (most usefull at times) and image stabilisation too.
Took you a while, for clarification, yes i do have the S5700.
__________________
Nathan is offline
Unread 30th August 2007, 20:52   #75
David
Talking Trains?
David's Avatar
Default
Agreed.
I can sense this thread being locked.
So can I ....
What , no I dont.
Erm, yes you do. As Tom says, your limit was never lifted ....
__________________
Latest Gallery BSB @ Cadwell Park August 2012
Last edited by David; 30th August 2007 at 20:52. Reason: Double post prevention system
David is offline
Closed Thread
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright © 2000 - 2013, Jelsoft Enterprises Ltd.
© RailUK Forums 2005 - the year after 2012
