RailUK Forums > Other Rail & Transport > Transport Simulations & Games
Reply
Thread Tools
Unread 31st August 2007, 21:40   #31
Tom B
Lord High Executioner
Tom B's Avatar
Default
Hi
I've been doing a bit of experimentation with this using a plasma screen with native resolution 1360 x 768. Using the graphics card tools it is being run with a 90 degree pivot i.e. on its side. However, when BVE is run with these settings, it is very unstable and crashes after a couple of stations. Has anybody else had any similar symptoms? I was using the first version of the program and subsequent releases may have run better.
Cheers
Tom
__________________
Tom B
Tom B is offline   Reply With Quote
Sponsored links - Registered users do not see these banners - join today!
Unread 31st August 2007, 22:33   #32
reschanger
reschanger's Avatar
Default
Quote:
So when running a 1360x768 screen 90° pivoted, the resolution would be 768x1360 (because it's on its side) and the corresponding aspect ratio would be 0.5647059. However, neither 1360x768 nor 768x1360 should be a resolution your graphics card would natively support (it's non-standard), so I guess you ran the whole thing in fullscreen then and it became unstable because of that incompatibility. That's how I would explain it. For a list of compatible resolutions just open the properties of the desktop (right click -> properties), go to the right-most tab and see what is selectable (applies to Windows XP). If you're using window mode or I got the whole idea wrong, then I still practiced my imagination well.
reschanger is offline   Reply With Quote
Unread 1st September 2007, 07:43   #33
Tom B
Tom B's Avatar
Default
Hi
You're pretty much spot on. I tried it both in Windowed and in Full Screen - the crashing was in fullscreen, windowed was very jerky. That's a thought, I'd not considered the graphics card, will look into it. I suppose it's an occupational hazard of using a funny shaped screen!
__________________
Tom B
Unread 1st September 2007, 08:58   #34
dennis63uk
Member of THT and GLF
dennis63uk's Avatar
Default
Best resolution i can run in with TFT Monitors here is 1024 by 768 32bit in full screen mode. One monitor is running in VGA and the other one in DVI which is capable of receiving HDTV as have been experimenting with it. In any other resolution BVE 4.2 crashes on me
dennis63uk is offline   Reply With Quote
Unread 1st September 2007, 09:44   #35
reschanger
reschanger's Avatar
Default
You might also want to try putting christmas-tree-shaped CDs into your CD ROM drive and see if it starts spinning or just breaking.
Quote:
Interesting, because we couldn't have don THAT before.
Ok, and now seriously.
I have problems imagining all of that. And you're not the only ones reporting that BVE crashed. How exactly does BVE "crash". Do you get an error message when starting, do you see at least something on screen, can you drive for a while and then when you least expected it, etc. That would be interesting now.
I probably can only say the thing one more time, hoping that's what's causing the problems. In fullscreen, the resolution can be arbitrarily set in the tool but must still be supported by the graphics card (and monitor) for it to properly work (the tool does not check against that). The easiest way of finding that out would probably have to be XP's desktop properties (right tab then) and looking what is available from the slider.
Unread 1st September 2007, 10:27   #36
Tom B
Tom B's Avatar
Default
It generally works for a short while, then crashes - exactly where you least expect it. Leaving Belsize Park on the Northern having started there, for example - nothing there which is special or out of the ordinary. Running it unpivoted seems to be fine, so as you say it may well be that asking it to pivot as well is causing the gfx card to throw the dummy out of the pram. The crash takes the form of freezing followed a few seconds later by a BSOD and reboot. I'll take a look at the graphics card and let you know.
__________________
Tom B
Unread 1st September 2007, 10:53   #37
reschanger
reschanger's Avatar
Default
Blue Screens of Death are only possible in Window XP when in kernel mode. Programs run in user mode. The only things that run in kernel mode are device drivers, so it seems like a buggy driver to me. Try downloading a new driver (or if you have the newest then try an older one). A longer while ago I also had some random crashes in BVE and it resulted from a buggy sound driver. Updating the driver solved the problem for me.
Last edited by reschanger; 1st September 2007 at 12:49. Reason: Typos, I was too lazy to use the preview
Unread 1st September 2007, 11:26   #38
Muppet
SPOOOOOOOOOOOON!
Muppet's Avatar
Default
Quote:
Originally Posted by Bill EWS View Post
Thanks Muppet. I don't have MSN running on my computer. Perhaps another programme is causing the same problem!
Cheers.
BilllEWS.
If you got any other applications running in the background try turning them off to see if it solves the flickering
Muppet is offline   Reply With Quote
Unread 2nd September 2007, 13:19   #39
devon_metro
Default
I got plenty of XP blue screens running the internet!
__________________
devon_metro is offline   Reply With Quote
Unread 6th September 2007, 20:42   #40
FusionRail
There goes the bonus...
FusionRail's Avatar
Cool
thanks for this.. it really looks better on my 19" highdef monitor.. and its brilliant in window mode as i can have it any size depending on what im doing. cheers
FusionRail is offline   Reply With Quote
Unread 11th September 2007, 23:45   #41
reschanger
reschanger's Avatar
Default
Now isn't this interesting: Someone translated the program into Chinese and hosted it on their website. I never really thought about the possibility of translating it for users who don't speak English, but obviously someone felt it was necessary. Releasing the source code has therefore finally paid off. See http://www.konkyu.net/ for that purpose...
Unread 27th September 2007, 17:58   #42
Richard Armstrong
Richard Armstrong's Avatar
Default
This worked well before but it's now cocked up on me, when I use it, the sim is very very slow, about a frame every 5 seconds. Any ideas?
__________________
Richard
Photo site | Video site
Richard Armstrong is offline   Reply With Quote
Unread 26th October 2007, 00:55   #43
rocky4427
Default
can you give me an example on how to put new display resolutions in my BVE4 folder pls
rocky4427 is offline   Reply With Quote
Unread 26th October 2007, 08:14   #44
D306
D306's Avatar
Default
install the program into the normal BVE4 folder, then when you want to change it, you need to go into the destination folder, then the installer is in there under a folder called reschanger.
D306 is offline   Reply With Quote
Unread 26th October 2007, 08:39   #45
Tom B
Tom B's Avatar
Default
Quote:
This is the second time you've made a post like this - it explains quite clearly how to use the program, it's a very simple application to use.
__________________
Tom B
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright © 2000 - 2013, Jelsoft Enterprises Ltd.
© RailUK Forums 2005 - the year after 2012
