RailUK Forums > Other Rail & Transport > Other Public Transport
Reply
Thread Tools
Unread 17th March 2012, 20:26   #181
robertclark125
Default
Unusual working tonight, 20334 on a 32 to Glenrothes, in place of the usual MAN 18.220 or Optare Solo. And it was on time, so hadn't covered a breakdown at Kirkcaldy?
robertclark125 is offline   Reply With Quote
Sponsored links - Registered users do not see these banners - join today!
Unread 20th March 2012, 01:13   #182
Jamester
Default
I'm not sure about weight restrictions on bridges etc. but I have heard a rumour (and I stress it is only a rumour) that after the London Olympics, Fife will receive new coaches (B9s) and these will be used on X58/X60 and possibly X54. These new vehicles will have been used for the Olympics contract initially. The current B7R coaches will be used on X24/X27/X26.
The cloth seated B7s will be moved on elsewhere. In my view it is more likely any new coaches will be used for Edinburgh services and Glasgow will get the "hand me-downs"!
Jamester is offline   Reply With Quote
Unread 20th March 2012, 14:38   #183
Blindtraveler
Scotlands No.1 Pacer Fan!
Default
that would certainly make sense and the B9s I would think, might, be better?
Blindtraveler is offline   Reply With Quote
Unread 20th March 2012, 14:50   #184
cainebj
cainebj's Avatar
Default
Don't know about B9R's, but there's some B13R Elite's on order for September delivery.
__________________
my Flickr photostream
cainebj is offline   Reply With Quote
Unread 21st March 2012, 00:23   #185
Jamester
Default
B13s would not be suitable on X58/X60 routes. I don't know much about the B9s but if they do come to Fife let's hope they are designed for service work. The B7s certainly are not.
Unread 21st March 2012, 05:08   #186
Blindtraveler
Default
agreed. Would hope they dont make that mistake again.
Unread 21st March 2012, 20:00   #187
cainebj
cainebj's Avatar
Default
There's 9 of the B13R Elite's on order for Aberhill, all to "executive" spec. Local management have asked for them, so must have found them suitable for something if not X58/X60. The only other vehicles on order for East Scotland are the E350H's for Perth, and 11 single deckers for St Andrews.
__________________
Unread 21st March 2012, 20:21   #188
robertclark125
Default
Those 11 single deckers are for the 99 group, and possibly for either the 23 or 96. It's worth noting the PVR for the 23 is 2 buses, the 96 is 2 buses at st Andrews, the 99 group has a PVR of 7.
As for the coaches, maybe they're headed for the X58/60. We'll have to wait and see what surprise local management has up its sleeve.
This will also lead to a cascade of some coaches to Rennies once again.
Unread 21st March 2012, 20:31   #189
tbtc
I am the passenger...
tbtc's Avatar
Default
Quote:
Are they both from St A though? I thought Glenrothes ran the duties that First/ Midland Bluebird used to run from Stirling?
It may well have changed of course
tbtc is offline   Reply With Quote
Unread 21st March 2012, 20:55   #190
mbonwick
mbonwick's Avatar
Default
Both from St. A according to the fleetcard.
The 11 single decks will replace 11 MANs and 1 B10M most likely, giving 1 spare on a PVR of 10.
__________________
mbonwick is offline   Reply With Quote
Unread 21st March 2012, 20:58   #191
robertclark125
Default
First withdrew their journeys in 2005, and so stagecoach Fife took over all journeys. At the same time, route 14 ended, and so Stagecoach Fife extended their 78 to Stirling.
Unread 22nd March 2012, 11:22   #192
tbtc
tbtc's Avatar
Default
Quote:
Cheers
Yes, but IIRC initially the second duty on the route (e.g. the one that First previously ran) was operated by Glenrothes when Stagecoach took over (partly because the timings suited having a bus start/end in the Kinross area)
Unread 26th March 2012, 20:56   #193
Jamester
Default
Quote:
I've been hearing various "rumours" over the last few days. My understanding is B13s are not currently suitable for Aberhill depot but Stagecoach want to use them on the X24/X27 route. This could result in Aberhill losing these routes and the rumour is Aberhill will do most of the X54 instead. There may be some or no truth in this!
Unread 26th March 2012, 23:55   #194
Blindtraveler
Default
9 wouldnt be enough for the Edinburgh runs anyway would it?
Unread 27th March 2012, 23:08   #195
Jamester
Default
Quote:
It would be enough for X58/X60 as 8 vehicles are required for this.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright © 2000 - 2013, Jelsoft Enterprises Ltd.
© RailUK Forums 2005 - the year after 2012
