RailUK Forums > UK Railway Forums > UK Railway Discussion
Closed Thread
Thread Tools
Unread 25th September 2009, 19:33   #46
Proud Salopian
from the forgotten county
Proud Salopian's Avatar
Default
Quote:
Originally Posted by mumrar View Post
Shrewsbury has platforms 4-8.
Erm.
Shrewsbury has platforms 1-7. Platforms 1 & 2 have no track, but otherwise are still there. Platform 3 is back in use and has very recently had a lift and passenger waiting room installed. Platforms 4, 5, 6 & 7 are on the main island of the station. As for platform 8... it doesn't exist. I sometimes (jokingly) call the "mini-platform" by Howard Street "platform 8" and the only trains that pull up in that siding are permanent way ones.
So I'm afraid there's nothing really unusual about Shrewsbury's platforms or their numbering!
Proud Salopian is offline
Sponsored links - Registered users do not see these banners - join today!
Unread 25th September 2009, 20:54   #47
jonmorris0844
What would Bob Crow say?
jonmorris0844's Avatar
Default
Quote:
Originally Posted by CCF23 View Post
Kings Cross is soon to have a platform 0, the new one that's going to be next to platform 1.
It was going to be platform Y, not 0 - but now it appears ALL the platforms are going to be renumbered so it starts at 1 (as you'd expect if common sense is used) and all the others go up by one - which as I said above, puts 9 3/4 in the right place between the main building and the suburban one (assuming it is still going to remain a separate building?)
Clearly there's a cost associated with signalling etc, but I presume someone realised that it needed to be done - and other work was going to be done anyway?
jonmorris0844 is offline
Unread 26th September 2009, 09:25   #48
driver9000
Mystery Excursion
driver9000's Avatar
Default
Quote:
Originally Posted by kwvr45 View Post
Preston has totally silly bay platforms 3c and 4c miles away down the end of the main platforms which are numbered 3 and 4 and not in any way connected with the bays. They are totally out of view from the main part of station so if anything still does use them, god help the passengers actually trying to find the platforms!
The bays at Preston are associated with the main through platforms 3 and 4. Platforms 3 and 4 are split into A and B subsections (north end is A and south end is B). The platforms signs dont make reference to 3a and 4a but departure screens do, this being most obvious when TPE portion trains split. Platforms 3c and 4c are still in daily use mostly by off peak Ormskirk services, by late running trains being terminated at Preston instead of continuing on to Blackpool etc and some Hazel Grove/Buxton services use it around the peak period to save a through platform and shunting. When services are going from the bays the station announcer usually tells passengers that they are at the 'extreme south end of the station'
__________________
clickety clack
Gone for a long walk.
driver9000 is offline
Unread 26th September 2009, 11:38   #49
EltonRoad
Default
The two platforms at Oban are still numbered 3 and 4.
EltonRoad is offline
Closed Thread
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright © 2000 - 2013, Jelsoft Enterprises Ltd.
© RailUK Forums 2005 - the year after 2012
