RailUK Forums > UK Railway Forums > UK Railway Discussion
Closed Thread
Thread Tools
Unread 26th October 2010, 08:26   #46
ajax103
ajax103's Avatar
Default
Quote:
Originally Posted by Failed Unit View Post
Most people in Edinburgh can afford a single to Haymarket to get through the barrier, just like people in Glasgow will just buy a single to high street to get them through! (Maybe even a child one the barrier can't tell!)
Actually the barriers should be able to tell the difference between a Adult ticket and a Child ticket depending on the setup the Operator has chosen, for example with the FCC gatelines you can tell the system to set off a alarm when a child ticket is used, the barriers simply don't accept the ticket and a manual check is done.
These apply to just the FCC gatelines but I'm quite sure equally apply to any regardless of location or operator.
ajax103 is offline
Sponsored links - Registered users do not see these banners - join today!
Closed Thread
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright © 2000 - 2013, Jelsoft Enterprises Ltd.
© RailUK Forums 2005 - the year after 2012
