RailUK Forums > Transport Simulations & Games > MSTS & EA Rail Simulator
Closed Thread
Thread Tools
Old 26th March 2006, 17:26   #16
Tom
Guest
Posts: n/a
Default
You must have UKFS (UK FineScale www.trainsimfiles.net), and the latest tsection.dat
Sponsored links - Registered users do not see these banners - join today!
Old 26th March 2006, 18:10   #17
Coxster
Passenger
Coxster's Avatar
Default
Quote:
You also need to ensure you have run the '.bat' files.
Coxster is offline
Old 26th March 2006, 18:11   #18
voyagerdude220
TOC Owner
voyagerdude220's Avatar
Default
Quote:
Originally Posted by Rich
I have got exactly the same program, only mine goes to about third of the way! I really wanted to use the new Dorset Coast, and get back into MSTS, but no such luck...
Having read the posts above, it seems there is nothing wrong with mine. All the routes that come with MSTS are installed, the London-Brighton Express and the Dorset Coast. There are no other routes installed.
However, I do have a hunch - Wjhen I installed the Dorset Coast, I unzipped them into My Documnents, then copied the files into the right place, rather than unzip them straight into the MSTS places. When I copied them in, it asked if I wanted to overwrite, so I said yes - perhaps some objects etc have been deleted???
I'll completely uninstall MSTS, and then completely re-install it, and see how far I get.
Yes, that's EXACTLY the problem I had. Good luck for fixing your copy of MSTS.
I've not got Dorset Cost personally. Have you been able to play on it yet, or has your problem been happening for a little while?
If you've been able to get on it, what's the Dorset Coast like, would you recomend it to me? Having said that, I probablly won't download it because I have no knowledge what so ever for messing with .zip files on UKTS (I ALLWAYS try to get self installing ones, or CDs...)
__________________
13,453.64 miles * covered since 1st January 2008
* 13,226.40 miles since 1st January 2009* - updated 25/12/09
Aprox 1,813.54 miles since 1st January 2010 [very rough and out of date]
voyagerdude220 is offline
Old 26th March 2006, 18:48   #19
Tom
Guest
Posts: n/a
Default
voyagerdude, you can download Dorset Coast here, it is 4 easy zip files. Assuming MSTS is installed in the default location, unzip them to C:\ and it automatically places in the correct location!
Old 26th March 2006, 19:06   #20
Rich
Trainee Track Engineer
Transport Secretary
Rich's Avatar
Default
I have fixed MSTS now, and it seems I had the same problem as voyagerdude!
Tom, I've downloaded the Dorset Coast, and the Finescale stuff and replaced the .dat file. What is that that Damon was talking about?
Now, I need to install the Dorset Coast, so if I open the .zip, and use the install directry of C:\ only, will it install correctly?
Thanks,
__________________
The Red Right Hand
Site Engineer - Oldham Rochdale Line, Manchester Metrolink
Rich is offline
Closed Thread
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright © 2000 - 2010, Jelsoft Enterprises Ltd.
© RailUK Forums 2004 - 2010
