#16 | |
Quote:
| Sponsored links - Registered users do not see these banners - join today! |
#17 |
That was done twice. The original station was a semi-permanent structure, facing roughly north-west, on the site of the current one. It then moved inside the walls a couple of years later, which would certainly not be allowed now. The gateway was designed to blend in though. However, trains from the south had to negotiate a tight right-hand curve, then reverse (although the fact that it was an engine change location made things easier). This arrangement lasted 38 years, by which time it was already heavily congested. Then they built the current through station on the site of the original one, or maybe a bit southward. This allowed access for the Scarborough line, did away with the reversal, and allowed a big expansion. The old one ended up as a carriage shed, then as additional storage space for preserved LNER stock before the days of the NRM. It is now the council offices.
__________________
Always thinking as I type, sometimes not very well |
#18 | |
Quote:
#19 |
On thinking about it, Berwick, although that was designed with what they called 'passive provision' for becoming a through station. I can't remember which end was built first, the Newcastle & Berwick or North British, but it involved demolishing the great hall of Berwick Castle, although the station originally had a 'castellated' style.
Actually, Waverley as well. The original Edinburgh & Leith railway involved a massive tunnel leading into what is now Waverley station from the north. The Edinburgh & Glasgow arrived from the west, the North British from the east, then all three met up in a station which was effectively a triangular junction. Eventually, they diverted the Leith line on a big loop and the tunnel ended up as the North British's (later LNER's) main source of mushrooms. I don't know whether it is still safe for access.
__________________
#20 | |
Quote:
#21 |
Worth adding, but that came later.
__________________
#22 | |
Quote:
The Met's Watford terminus station still survives as the Moon Under Water pub, although it is a pre-existing building that was due to be converted to a station booking-hall rather than a new build. Still looks like a station even now though. |
#23 |
Island Gardens DLR was originally an elevated terminus, it is now (on a slightly different site) a deep tube through station.
#24 |
I did say Blackfriars, which is wrong, I meant City Thameslink (as Ludgate Hill).
#25 |
Hounslow West on the Piccadilly line changed from being a ground-level terminus to a cut-and-cover through station when the Heathrow extension opened in the 1970s: although, the platforms apart, the remainder of the existing station building remained (and remains) in use.
#26 |
I am the passenger...
That's an interesting question, I really cannot think of any examples in postwar UK stations, though there are certainly a few termini that I would love to become through stations (Hadfield, Matlock etc!)
#27 |
Driver
High Wycombe was originally a terminus. When the line was extended to Thame and Aylesbury the original Brunel-designed station building, complete with overall roof, was converted into the new station's goods shed. It is still there today, awaiting redevelopment for commercial/retail use. http://www.flickr.com/photos/rpmarks/5743958265
#28 |
Dorchester South was built as terminus. It was the intent to continue the line westwards towards Exeter. Instead the current route was used instead from Salisbury.
For many years after the line was connected to the Weymouth, Waterloo bound trains had to reverse in to the station to call, This carried on until to 1970 when a platform was built on the curve. Last edited by Firesprite; 27th May 2012 at 23:59. |
#29 |
If narrow-gauge railways can be included, how about the work now going-on at Porthmadog to make it a "through" station, and allow easier access from the Caernarfon line by removing the need to reverse?
#30 | |
Quote:
Chesham's a bit of a special case as well, since it ended up marooned on a branch having been the Met's original north-western terminus before it diverted west to Aylesbury, Quainton Road and eventually Amersham.
__________________
| Bookmarks |
| Thread Tools | |
