#61 | |
Quote:
__________________
TOCs Used in 2013 - CH, FC, GA, SE, SN, VT Classes travelled on in 2013 - 168, 171, 313, 319, 375, 377, 390, 90/MK3 |
| Sponsored links - Registered users do not see these banners - join today! |
#62 | |
What would Bob Crow say?
Quote:
I haven't been on every train, obviously, but on FCC that I use most, they're always present, and easy to read. Given FCC continued with the design used by Wagn, they're almost identical to what I'd imagine GA uses (with NXEA having them before). Pretty simple summarised info that most people should understand. Drivers will always give a safety announcement before the train sets off (admittedly, not again for the benefit of those joining along the way) and the screens on 317s will do so when leaving King's Cross and once more after leaving Finsbury Park. If people are told then there's little more a TOC can do. If people say they weren't told anything, then they're probably lying and actually mean they weren't paying attention. These are the ones who talk through the safety briefing on a plane, and haven't travelled loads of times before and don't necessarily appreciate the subtle differences from one plane to another (manufacturer, configuration etc). |
#63 |
I understand now from news reports and eyewitnesses that passengers close to the fire were told to move down the carriages, but still told to stay on board. Apparently, one or two opened the doors and got off the train, with the rest following.
Finally, this picture shows conditions in one of the carriages, although I haven't got a clue why someone would stay behind, take a risk and take a picture. http://www.newsshopper.co.uk/resources/images/2044413/ Would you all stay on board or move down if conditions were like this? I think I would, but I'd be interested to see what others say.
__________________
Be not afeard; the isle is full of noises, Sounds, and sweet airs, that give delight and hurt not. |
#64 | |
Quote:
--- old post above --- --- new post below --- The Standard this evening reported that the fire was a direct result of somebody placing a large piece of metal across the track in an attempt to derail it or cause serious damage. Last edited by No Fault Found; 15th June 2012 at 17:42. Reason: Double post prevention system |
#65 | |
Quote:
__________________
#66 |
#67 |
Well, its half true. Yes an object was put on the line and did cause damage - why the BTP have launched an appeal - what the object was is unknown.
__________________
#68 |
Please, call me Matt
Are the shoe beams on Bombardiers not wooden? Could it have sparked and caught fire
Edit: Didn't see the post above, rendering my idea redundant |
#69 | |
Quote:
Shoegear burn ups are relatively regular occurance (couple every year) and there can be a variety of causes: including, but not exclusively, items on the line that aren't there as a result of malicious intent or train faults or maintenance failings (both train and infrastructure) . Yes, there have been deliberate acts of sabotage in the past. Shopping trolley's chucked off the bridges in the Woolwich/Plumstead/Medway area used to be a favourite but these have decreased noticeably (even in the school holidays). |
#70 | |
"Transforming Trouble..."
Quote:
#71 |
I should say that FCC seems to have fewer problems with the type of people that might remove or damage the notices.
Having had the pleasure of using trains in parts of Essex and Kent, it is perhaps not the TOCs we should blame. Nor can I imagine some of the passengers even knowing how to read! |
#72 | |
Quote:
States 2 men were seen "running from the scene" and remains of an object have been found on the line and are being forensically tested. I hardly think the BTP are going to make something out of nothing.
__________________
#73 |
ECML Regular
Haven't read every post, and I don't know the number of members on these forums, but am surprised 3 members were on the affected train. Seems statistically a little high!
#74 | |
- but not from Decapod 10
Quote:
It's how I first came upon this site - Googling for details of a rail incident and alighting on RailUK Forums. |
#75 | |
Quote:
| Bookmarks |
| Thread Tools | |
