#91 |
| Sponsored links - Registered users do not see these banners - join today! |
#92 |
Starmie
Is learning the Highway Code (or at least the basics of it) part of driving tests? If not, why not?
I know much of the Code isn't legally enforced, such as letting buses pull out or stopping at zebra crossings (as opposed to using bus lanes and not stopping on zebra crossings when a pedestrian is already on the crossing, both of which are I believe illegal), but one cannot deny its value in making the difference between safe/sensible drivers and everyone else?
__________________
Now Available: Ivo's Blog! |
#93 |
The learning of the highway code is required as without it you won't pass the theory test and you would have a hard time passing the practical. The problem is you are only asked 35 random questions and there is no requirement to continue reading it after you have passed.
__________________
http://www.angliarailways.smugmug.com/ |
#94 |
This should have been done a long time ago. As an lgv driver, i see many "near misses" daily. Trucks doing 40mph and cars doing 60mph doesn't work!
#95 |
To go back to the speed limit issue, it makes a lot of sense in some ways, but is it enforceable without seeing cameras spring up all over the place? Can they monitor everywhere effectively? I don't drive (which is probably a good thing considering if there were no speed limits I'd regularly travel at over 100mph) but I've been a passenger with enough rural drivers to know that a lot of them think that the RAC Rally is all day, every day. Fenland drivers are very noteable for this, and considering the state of the roads there, they must keep suspension manufacturers very happy. I'm sure this limit will be treated with as much disdain as the 60 limit is by many rural drivers.
__________________
Always thinking as I type, sometimes not very well |
#96 | |
DIY Calzone Expert
Quote:
__________________
2013 Haulage: 142, 144, 150, 158, 170, 185, 319, 322, 333, 390, 455, 458 ( ), 4652013 TOCs: NR, TPE, VWC, SWT, SET, FCC |
#97 | |
Quote:
What is needed as someone said is a little bit of patience.
__________________
Keep on Truck'in. |
#98 |
Talking Trains?
Getting back to cyclists (yes, another change of subject
http://www.bbc.co.uk/news/world-asia-18920294 - That's why you should not jump a red light.
__________________
Latest Gallery BSB @ Cadwell Park August 2012 |
#99 |
Furfaggotry! :3
I nearly hit a cyclist with a bus on thursday evening.
It was at this junction. I was turning right, waiting on the lights to change. When they did change, I checked my mirrors before moving off, and I did notice a bike but he was in the middle of the left hand lane, so I thought nothing of it and carried on. When I checked the n/s mirror halfway round, there was no sign of him in it - and there shouldn't be if he's gone straight ahead. When I looked back across as I was nearly level with the traffic island, there he was, about 2" away from the bumper. If I hadn't braked and steered away, I would've knocked him off and possibly killed him. What got me about the whole thing is that he seemed to be completely oblivious to what had happened, and just carried on (and cycled through the red light at the next junction). It's not an isolated incident, either. That sort of thing at junctions is worryingly common, though not usuallly quite as bad. It seems somewhat telling that all the buses are now starting to have signs put on the back of them (like this) telling cyclists not to pass on the left, and there are still plenty who completely ignore them. |
#100 | |
Quote:
Sadly they think if they can cut a few seconds they will be fine. Chris
__________________
Current Rail Miles: 1500 Miles Am '220389' on UKTS Forums |
#101 |
Well said, although strictly speaking it is dangerous to life on the planet. The rock itself should be fine, but I think the most economical speed for driving a car at is 60mph. Permitting faster speeds than that, unless something is done to encourage a good mentality that drivers should treat the limit with*, is just going to increase greenhouse gas emmisions. Hence, I would say the standard speed limit** should be 60mph, with lower limits in built-up areas (as already is the case) and on single-track or esspecially twisty roads, for saftey reasons.
* If, rather than trying to drive at the limit, or in some cases as fast as they think they can get away with (80mph on a 70mph stretch for example), they took the limit as a hard-and-fast limit they MUST NEVER, EVER exceed then they might average 60-ish with a 70mph limit. ** For motorways, dual carriageways and wide, straightish, single carriageways. |
#102 |
Similarly, with roundabouts, my driving instructor had a thing about lorries,coaches and buses. His mantra was never go round a roundabout at the same speed as a bus. They have a longer wheelbase and are larger than you. Hang back and give them room to manoeuvre.
#103 | |
Quote:
Some people just don't listen to good advice.
__________________
#104 | |
Quote:
#105 |
That's the trouble with the internet, tone of voice doesn't come accross. Yes, he was absolutely right, I was just injecting a touch of hyperbole. What I really meant was, 'here is a situation that's even worse'. It was also miles off-topic, so apologies for that.
__________________
| Bookmarks |
| Thread Tools | |
