Porterbrook Cl.769 'Flex' trains from 319s, initially for Northern
Llama
29 Apr 2014
What about when they also have a crush load of passengers in all vehicles? We had adhesion issues on the St Helens line in 2015 and a 319 couldn't move. The train crew ended up in desperation asking all the passengers to shift into the PMS vehicle for a bit more adhesive weight. (It didn't work).
JN114
28 Jun 2005
Well we might as well phone up Brush now then and tell them to stop converting 319s immediately. All the very highly paid engineers and designers in this project have clearly got their numbers wrong, as this one incident 4 years ago shows. Sprinters and Pacers have too failed to get away from stations when crush loading has coincided with exceptional railhead conditions; but we can carry on with running them because that doesn’t play to the perpetual 769 jeopardy narrative.
Mordac
5 Mar 2016
At least they didn't ask them to get out and push! :lol:
AM9
13 May 2014
St Albans
I refer you to my earlier post in this thread, #2700 which shows the calculated loads and adhesive percentages of 319s and 769s when empty, all seats loaded and crush loaded*. Yes, the adhesive percentage goes down slightly with the additional genset kit on board the trailers but there are plenty of other multiple units with similar figures running around on services where they cope. Also forget this 'only 25% adhesive weight' argument. The MSOs weigh 50t whereas the trailers are all about 30t as EMUs so it is 50t powered vs 90t trailing. With diesel Gensets it is 50t powered vs 110t trailing. Those are figures for empty units. Read my other post.
* 'crush loaded' is the rated capacity of the stock used for passenger flow calculations. 4 passengers per m^2 is perfectly normal in metro peak conditions,and whilst not the most comfortable way to travel, it is considered acceptable for short periods and exceptional circumstances.
AM9
13 May 2014
St Albans
its irellivent its the same traction motors so same grip same control
unless the diesel control is more "notchy" than the electric then grip will be less off a problem
I assume that they will normally be driven from the same control in both modes and as 319s have always been, is that a four notch lever? If so, the 'notchieness' will be no worse and in some ways better as there will be less power available from the genset so wheelslip will be less likely. As far as hill climbing goes, they will be almost as capable on diesel as electric, (owing to slightly less adhesion) but the lower power will make progress slower. That power will though be more usable than with a mechanical or hydraulic transmission, because the genset will be running at maximum efficiency irrespective of wheel speed, and the motors will be running well within their ratings. That is a wholly different situatuation to the sprinter engine thrashing away into the torque converter which will converting much of the input power into heating its fluid and parts, resulting in less output torque.
Greybeard33
18 Feb 2012
Greater Manchester
Can you back up this assertion with a curve of overall efficiency versus speed for the 319 traction system (traction motor plus traction converter), i.e. (mechanical power at railhead)/(750V electrical power in)? Plus a comparable curve for the 15x Voith hydraulic transmission, i.e. (mechanical power at railhead)/(shaft power in)?
driver_m
8 Nov 2011
I guess that would have been Thatto Heath/Eccleston Park which are notorious slide spots. Was told by one of my colleagues that he tried to stop a 142 there during the time of chain brakes, slid straight through, get the ok to set back and promptly slid back through too!!
Even the best gripping units will struggle so I don't see how am argument what happened 'darn sarf' can be used for a train that hasn't even been used in service yet. Can't we all just see the 769 eventually work before passing judgement. We did the same with the 800's and they're neither as bad as people made out, nor the saviour of the railway, but somewhere inbetween.
Let's wait everyone until they get a good run in the real world. .... .please?
EE Andy b1
12 Dec 2013
CLC
Well said that man!
We can all speculate as much as we like but let's see these conversions in action.
I don't think there is one traction or rolling stock or infrastructure program running on time or without further problems so lets just wait and see and hope they have come up with a descent product fit for purpose.
AM9
13 May 2014
St Albans
Well said that man!
So other than the reports of movements of donor or completed multiple units, there won't be much discussion. If that happens, those who seem to have some portents about any forthcoming rolling stock's dire failure will be nothing to say, and then they won't be able to shout 'I told you so' ad nauseum. :)
FenMan
13 Oct 2011
My local station is on the North Downs Line. I am totally agnostic about GWR's choice of rolling stock to run services as per the timetable. I can tolerate more or less comfortable seats, and, to a lesser extent, air cooling/heating not working as it should, etc, etc, if GWR uses rolling stock that does not extend the current journey times and is reliable.
a_c_skinner
21 Jun 2013
Afraid so, but in truth until something happens that is all there is to say. I remain intrigued by the contrast between no main line testing yet apparently still deliveries going on and even (until recently) orders and people talking about orders. Mind you the 747 was ordered off the drawing board - though so was the 737 Max!
td97
26 Jul 2017
Alderley-Wigan NW services are timed as class 319 EMU from May. Clearly must be some intention of the 769s starting this summer.
Mathew S
7 Aug 2017
I'd missed that. Thanks
Yes, that would seem a bit of a giveaway.
Greybeard33
18 Feb 2012
Greater Manchester
Curiously, the services from Wigan NW or Southport to Alderley Edge are all timed for 75mph Sprinters. It is only (some of) the return services from Alderley Edge to Wigan NW/Southport that are timed for 100mph 319s!
30 Jul 2015
Example: Transport for Wales 769s are 769-002/003/006/007/008/(426)/4xx/4xx/4xx which are converted from 319-002/003/006/007/008/(426)/4xx/4xx/4xx :)
I thought I read somewhere that the GWR 769s are only to retain the last two digits, e.g 319437 will become 769937, 769/9 indicating the retention of 750V capability. I don't recall where I saw that now, so perhaps I am wrong.
anamyd
17 Aug 2018
First I've heard of that but you could be right!
Class 170101
1 Mar 2014
There will be a change on route somewhere for the Traction type but Real Time Trains only shows the leading traction type I think you will find.
geoffk
4 Aug 2010
Also presumably WNW to Stalybridge as they interwork at Wigan.
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
I read the same thing too; it's to differentiate the fact that they are tri-mode units, rather than the bi-modal ones ordered for Northern and TfW.
LOL The Irony
29 Jul 2017
Chinatown, New York
They're not tri-modes! They're dual voltage bi-modes. Using the tri-mode logic porterbrook are using, every dual voltage EMU is a bi-mode.
Greybeard33
18 Feb 2012
Greater Manchester
Not the whole story. Liverail shows changes en route and traction type. From looking at a few examples, the Wigan NW to Alderley Edge workings have two changes en route, at Bolton and Manchester Piccadilly. For both the Wigan to Bolton and Piccadilly to Alderley legs, the data is:
Code:
              Power type: DMU Diesel Mechanical Multiple Unit
             Timing Load: S Class 150, 153, 155, or 156
                   Speed: 075 mph
Whereas for the Bolton to Piccadilly leg, the data is:
Code:
              Power type: EMU Electric Multiple Unit
             Timing Load: 319
                   Speed: 100 mph
See e.g. http://www.charlwoodhouse.co.uk/rail/liverail/train/15869059/18/07/19
The Alderley to Wigan workings, on the other hand, have only one change en route, at Piccadilly. For both legs (including the unelectrified Bolton to Wigan line), the data is:
Code:
             Timing Load: 319
                   Speed: 100 mph
See e.g. http://www.charlwoodhouse.co.uk/rail/liverail/train/15869807/18/07/19
Make sense of that!
No, the Wigan - Stalybridge workings are timed as Sprinters throughout, in both directions.
