1030 Arriva Trains Wales of Manchester to South West Wales
Masbroughlad
2 Mar 2011
Midlands
Don't usually make this journey. Is the 1030 off Manchester always booked for a 150? Seems the wrong type of unit for such a long journey. Was hoping for a 175! (and I'm sat near the toilet and it stinks!)
Very rare for the MAN-CDF trains not to be 175s, usually 3-car.
Must be a bad day...
You really need the aircon on a day like today.
Pumbaa
19 Feb 2008
No, but it's not booked for a 175. It's usually a 158. The 1030, 1530 and 1930? off Manchester are all booked 158.
One of the Welsh posters has posted the exact timings before. The above could be an hour either side, I Cant quite remember.
156441
30 Aug 2011
Manchester
It been a 150 since Wednesday due to a lack of 175's causing the 158's to be moved around!
tbtc
16 Dec 2008
Reston City Centre
Sadly ATW have little spare (partly because the 175s on the Manchester route are running into south west Wales, and not concentrating on the busiest section from Swansea/ Cardiff/ Newport to Manchester), so its a 150 from time to time.
In the circumstances I'd rather put a 150 on the Birmingham International - Holyhead route (which sees fewer longer distance passengers) and a 158 on the Manchester trip (if there aren't enough 175s) but that would require some swapping around of stock etc.
ChiefPlanner
6 Sep 2011
Herts
After last nights mishap when a 175 hit 4 cows at St George's crossing in the Vale - another out of action ......
anthony263
19 Aug 2008
South Wales
I think we really need 175002 back in service especially since it looks like ATW have now lost another class 175.
That said if it is only one carriage that is damaged from both unit last night and 175002 could the non damaged carriages be put together to form a hybrid set?
Rhydgaled
25 Nov 2010
What I've read on this fourm and others in the past is that all Manchester - south Wales services are booked for class 175s on weekdays (there's one class 158 booked on Saturdays, the rest should be 175s). ATW really need to get more slack in their long distance fleet (ie. introduce LHCS on franchise workings) to keep the 150s on short distance / suburban workings.
merlodlliw
8 Mar 2009
Dont the Holyhead Birmingham 158s do a swop around at Salop for the Cambrian, thus ruling out 150s,I agree about ATW not concentrating on the busy sections.
ATW probably have nothing spare now.
Bob
Rich McLean
6 Feb 2012
From memory, when a Cambrian service arrives into BHI, it consits of 2x158's.
Either a 158 is left at BHI for an hour, while the other 158 forms the Holyhead service. The next service from Holyhead couples to the 158 left an international and forms the next Cambrian.
However, I think that has changed over the past couple years, where the Holyhead trains go from BHI to Shrewsbury as two 158's and split there, and that 158 left behind joins the next Holyhead service to Birmingham at shrewsbury, to give capacity on the Wolves to Shrewsbury line, which used to often be full and standing when I have used it.
I'm sure someone from ATW can confirm how its works now
150222
9 Jul 2011
Your certainly better off with hopper windows (150) than broken air-con (158).
All Line Rover
17 Feb 2011
Manchester to Cardiff consists of a mixture of 2-car and 3-car 175's. A few are 158's (the 1930 off MAN is booked to be a 158), and this is bearable, if not the most pleasant experience. But to put a 150 on that route is ridiculous!
I don't understand why some of the 175's run as far as Pembroke Dock and Milford Haven. Surely they can't be that busy down there? (Considering most of the 175's "up here" are full and standing). In my opinion they should all terminate at Cardiff Central with connections on 158's and 150's for passengers travelling further afield.
What is the "comfort factor" of the seating on the 150 class, the 158 class and the 175 class on a journey length of Manchester Piccadilly to Cardiff Central, as we may be making this journey quite soon.
175's - very comfortable, lots of space, quiet, lovely overall. Particularly with the aircon on in this heat.
158 refurbs - comfortable seats, if a bit narrow. Quite noisy compared to a 175.
158 originals - not a pleasant experience.
150's - REALLY not a pleasant experience, and extremely loud. Especially with all the windows open!
Rhydgaled
25 Nov 2010
I'm not from ATW, but I'm pretty sure that most services are two 158s coming in from Cambrian, which go straight back out to Shrewsbury on the Holyhead service, leaving one unit at Shrewsbury which as you say couples to the inbound service from Holyhead to go back to Birmingham, then both head out on Cambrian. Might be a little different now, due to strengthening of some of these services.
185
29 Aug 2010
For ATW to use a 158 on the Crewe shuttles or North Wales Coast, and to put a 150 on the Cardiff Manchster, they need lynching.
gareth taylor
11 Oct 2009
Denton Manchester
Yesterdays 1750 CDF to MAN should have been 175104. It was cancelled, then 150236 turned a couple minutes later to do the service. Arrived in to SPT 7/8 minutes late. It could have a 153 and a 142 doing it instead (heaven forbid).
PHILIPE
14 Nov 2011
Caerphilly
Not as simple as that. It all depends on where units finish up the night before thus deciding where they are the next morning. Going back to an earlier post, only the 10 30 Manchester to Milford Haven is booked for a 158There are enough 175s to run the service but if not sufficient available on any one day, one has to improvise..
To add to this, all this has and still is being debated at length on another thread on the Forum in the Traction Section..
Rhydgaled
25 Nov 2010
I thought the only Manchester - Milford booked for a 158 was the one that leaves Milford at 13:08, and even then only on Saturdays with all weekday services being booked for a 175. Is the 10:30 off Manchester now booked for a 158 on weekdays and Saturdays?
PHILIPE
14 Nov 2011
Caerphilly
Yes. We are covering old ground again here. There seem to be too many threads on different boards with different titles all referring to the same subject ie. WAG Express and ATW utilisation are the only ones required. People seem to start a new thread when the topic has already been posted elsewhere.
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
This does not only apply to ATW and the WG Express. Many other topics come up regularly, just as they do on other forums! I think it is natural for unit diagrams 9plus XC HST diagrams of course!) to come up frequently, especially around the time of a timetable change.
185
29 Aug 2010
Last time I was on a similar service, it was a 142.
From.... Newcastle to Liverpool.
-- Arriva Trains Northern. I was it's guard :(
We did have a trolley, window labels and seat reservations sellotaped on.
Big Chris
12 Sep 2009
Norfolk
Arriva seem to be pretty good at providing a unit, come what may, in difficult circumstances. A 150 providing the service; whilst worse than a 175, is better than no train. I think they should be applauded not condemned.
Masbroughlad
2 Mar 2011
Midlands
No. They should provide a train fit for purpose. Why do people think not delivering is good?! We need to demand more from TOCs, not applaud them for failure.
Rhydgaled
25 Nov 2010
If they really only had 150s available we shouldn't grumble, but they have been keeping their 16 to 22 mark 2 carraiges, bought to increase capacity so I'm told, out of service...
Where's this other topic that mentioned extra 158 diagrams on Manchesters then? Could I have a link please?
Rich McLean
6 Feb 2012
Dear god, I wonder how much tea got spilt :lol:
PHILIPE
14 Nov 2011
Caerphilly
Can't you understand they probably would they have could. Again better than cancelling. In an ideal world units would never break down or disruptions occur that might throw them out of their working. Would you have waited an hour hoping it would have been a 175 ?
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
I completely agree. When I catch 1 150 home rather than a 175, I am just happy to be on the way. OK, I prefer a 175, but I would rather get home than have to wait for an hour for a service. Anyhting is better than nothing, and it is hardly ATW's fault if the farmers of Wales seem unable to use crossings properly.
anthony263
19 Aug 2008
South Wales
Speaking of farmers I hear that one which had the incident at Whitland with 175002 has been charged today.
I think his insurance company are facing a hefty bill.
SuperOwl86
2 Jun 2011
Couple of months ago i used to travel on this service from Stockport to Hereford, Could never guess what would turn up more times than not was a 158. The last time I went to Hereford via Stockport I was unlucky to get a 150.
Since then I always go via New Street and catch the 170 Hereford train although the first time I started to go via New Street a 150 also turned up then.
Seems I am cursed.
tbtc
16 Dec 2008
Reston City Centre
Are there diagrams that only run Birmingham International - Shrewsbury shuttles (being attached/ detached at Shrewsbury)? They'd be perfect for 150s (coupling up to 158s bound for Holyhead/ Cambrian).
So when a 175 is out of action for crashing into four cows, what do you suggest we do? Yes, there could be more units in reserve, but that'd be at the cost of having fewer daily services - should we cut down the number of services that ATW run just in case one hits a cow?
