I think the majority of the Midland Mainline from Bedford to St Pancras is 110mph.
I think the 110mph applies up to just south of Wellingborough as well, before you get into the speed restrictions for the curves through the station.
That is true, but the thought processes behind deploying the spare HSTs on the MML were just the same: Improve journey times and the travelling experience.Well the MML received its HSTs second hand from the ECML... at which point it was the most suitable route remaining that had not already received them. It was either send them there or to the sidings.
I think that West of England services at the time were largely making use of pressure ventilated mark 2s, so nothing too dissimilar from mark 1s.Were West of England services even using Mark 2 Aircons at the time the HSTs were introduced? I don't imagine mark 1s could hope to stand up to Mark 3s in comfort terms. While I do believe that a Turbostar carriage has a good chance of doing so.
Your concept seems to be to maintain the status quo with regards to journey times, with no notion of attempting to improve the passenger travelling experience or journey times but to instead install the rock bottom quality standard that can be got away with on a long distance Intercity service.No, the ultimate in cost cutting would involve no first class and 3+2 seating.
The fact remains that the only place it would lose time against a HST is possibly east of Reading and that in the Cornish section of the route that is so slow, its superior low speed acceleration may allow it to beat said HST.
An 8 coach Turbostar is also far cheaper to operate than said HST.
People want the train to arrive on time, to be air conditioned, to be reasonably quiet and for it to have WiFi/plug sockets on a long journey, a Turbostar does or can be made to fulfil all of these requirements.
Agreed. I have spoken with engineers in Derby involved with their manufacture, and FCC drivers. It would seem that as often is the case, the restriction is legislative rather than a physical technical problem. That's not to say that raising their max service speed to 110 wouldn't cause longer term issues. Maintenance regimes would need careful monitoring, but yes, to reiterate A-driver - it would seem the units themselves are more than capable, as they have proven before.
How so? You'd be looking at 8 engines rather then 2.. 8 gearboxes, 8 final drives... It's one of the reasons FGW dumped the 180s, their operating costs were far higher then the HST...
Of course as the HSTs are getting on they are going to become maintainence nightmares.
With a dedicated sub fleet you can't interwork with diagrams on the main GWML. It also might cause issues where a 110mph unit is spare and a 125mph breaks down. It wouldn't be as easy to use the spare if there is a speed differential
Though rather then using a standard Turbostar body, if they were bodied like a Irish 22xxx they might make a good inter regional unit.
365s on HS1? That's news to me. For what reason?
Back in 2003 when the 16 cl365's were coming off lease with Connex, as was, the future of the fleet was uncertain - as it still is today - and the viability of many options to the vehicle leasing agents were investigated.
One option was to run them on HS1 but the lack of TE at high speeds and the gradient profile of the HS1 route meant that they couldn't maintain anything approaching 100mph - I seem to recall the calculations suggesting that if a 365 was doing 100mph leaving the Bluebell hill tunnel on the Up it would only be doing ~75mph by the time it got to the top of the Medway Valley and impact upon headway for following services was too great.
I think pan spacing when running in multiple was another impediment as well.
As for Hornsey and the 365's running at 110mph on ECML - I would suggest that their attention is not on the long term future of the cl365 fleet. The smart money is on them being moved eastwards under existing wires or westwards when new wires are strung.
Hmmm I travel on HS1 every day. Where do 395s struggle?
Pan spacing shouldn't be an issue at 100mph, or even 110mph for that matter.
It's definitely true that they can't maintain 225 kph up the hills any more than a Eurostar can maintain 300 kph up them. But speed never drops below 200 kph on the steepest grades. Beyond Ebbsfleet to London the 230 kph limit makes the differential moot anyway ?
Standing waves on the OLE should have been easily contained - what speed was this an issue and what exactly was the problem? 365s use a type of the BW HSP unit without the apex frame on them, which I've no experience of, but I assumed their high speed dynamics wouldn't be too different. The uplift force of a Faiveley GPU at 160km/h is around *digs into memory* 120-140N and this is similar to the BW unit which is fine at 100mph on ECML catenary (with another one or two within 100m of it) which is 11kN tension compared to 14kN on CTRL. Logic checks out on that, unless there was some other issue.
Do you know what problem they had with the pans?
373s can maintain 300km/h up any gradient on HS1 or LGV Nord. It can even accelerate gradually but comfortably up most of them in the 290-300 range provided all motors are in.
Trust me.
