12 carriages on Cambridge villages
mervyn72
23 Jul 2015
Not sure if it's anything to do with the Brighton Mainline closure but the morning the 0813 from Meldreth was 700143. Never have I seen 12 carriages call at the villages.
I knows it's possible going South using SDO but according to RTT the train ran to Cambridge North bedorehand calling at the villages. So can 12 carriages call when going North?
mervyn72
23 Jul 2015
Might thought was that the driver has to be on the platform. Can't be if going North due to level crissings
The timetable has various amendments due to the Brighton works. There’s even some 365 pairs on midday Cambridge-KX semi-fast workings for those who appreciate a retro experience.
However, are you 100% sure this was definitely a 12-car? The reason I ask is that following it back the diagram starts from Letchworth sidings, and it’s hard to see how a 12-car would get there to make it up.
AM9
13 May 2014
St Albans
Whilst it might be inconvenient for traffic at the crossing to wait a minute more for a rural station dwell, is there a physical reason why the leading cars cannot stop at the platform?
mervyn72
23 Jul 2015
Yes it was definitely 700143. My suspicions arose when on the PIS at Meldreth, the 08:13 was shown as formed of 12 coaches.
Not sure. I know that there are many locations where the driver is positioned beyond the platform at station stops as I've seen stop boards for HST's show this but those services have a guard. Maybe someone more in the know regarding DOO trains can shed light?
Bit of a mystery then.
The train appears to have stuck to diagram, the only possibility is that it didn’t start from Letchworth for some reason - perhaps started empty from either Cambridge sidings or Hornsey depot for some reason. With a reduction in the number of FLUs working due to the Brighton works, this could be the explanation.
It doesn’t appear to have been a booked working - as the journey to Cambridge North was booked to start from platform 9 at KX, which means it must have been booked 8-car. This would tie in with the diagram starting from Letchworth sidings.
Doesn’t really answer the question about the level crossings though! Perhaps it’s acceptable as an out-of-course thing, but not acceptable to *plan* on the basis of trains overhanging a crossing?
bengley
18 May 2008
No reason why trains can't overhang a crossing. Happens regularly on the East Sussex coast.
philjo
9 Jun 2009
I saw mention on the GTR journey check that a couple of stopping services were 12 coaches instead of 8 - I think it said this was due to a train fault. So I assumed they substituted a unit. Might be a shock for passengers at the back of the train trying to alight at WGC, Hatfield or Potters Bar !
AM9
13 May 2014
St Albans
Well, provided that the driver gave an announcement to that effect in good time, the class 700s are easy to walk through to those cars that would stop by the platform
47421
7 Feb 2012
london
I think the rule is that you can't overrun a signal at the end of the platform to SDO, so in the up direction would have to overhang the crossing, which as noted above I expect is OK on an exceptional basis but not booked.
As an aside on West Anglia, where once the 720s arrive will peak time be a mostly 12 car equivalent railway, many platforms are currently 8 car and the franchise agreement only specifies Elsenham, St Margarets, Ware and Enfield Lock for extension, all which have a signal which would cause overhang over a crossing. No extension planned at various other stations where SDO will apply.
westcoaster
4 Dec 2006
DTOS A or B
SDO on the 700's only works front to back. Not back to front. So a 700 can't stop with the front of the train not available.
Starmill
Fares Advisor
18 May 2012
Bolton
There are a large number of places where it happened historically and continues to happen today.
Is there anywhere where it didn't happen historically that has begun in the past few years, or could begin from now on?
Failed Unit
26 Jan 2009
Central Belt
Has appeared a couple of days. But runs non-stop from Royston - Cambridge.
I had it on Tuesday on 1721 London - Cambridge.
I understand it appeared on 1651 London - Cambridge North yesterday.
Dwells seemed to increase but the driver announced well in advance so no dramas south of WGC.
