1923 Euston - Birmingham Drag
Discussion in 'Traction & Rolling Stock' started by DarloRich, 28 Aug 2015.
Thread Status:
  1. DarloRich
    DarloRich Veteran Member
    23,360
    Work - Fenny Stratford(MK) Home - Darlington
    Twitter is alive with rumours that this evenings 1923 Euston - BHM is to be dragged due to a Pendolino failure
    Rail Forums
  3. Bald Rick
    Bald Rick Established Member
    10,872
    Reading this going the other way, by chance I'll be at Watford at precisely the same time as it is so will let you know.
  4. fishquinn
    fishquinn Established Member Quizmaster
    6,283
    4 Oct 2013
    Warwickshire
    By what? A 57?
  5. Bald Rick
    10,872
    Indeed it was. 'Pride of Crewe'. It might make Wolverhampton by tomorrow.
  6. JonathanH
    JonathanH Established Member
    3,697
    The xx23 is a better choice for this than the xx03 and xx43 but unless the 1930 Glasgow and 1940 Manchester loop somehow they are going to be quite late too.
    Probably a reasonable decision not to lose 11 coaches of capacity on a bank holiday weekend.
    EDIT: It is already on the slow line at Bourne End junction. Now to see how many Birmingham trains overtake it before it gets to Coventry.
  7. Bletchleyite
    Bletchleyite Veteran Member
    47,010
    Up and down the south WCML (mostly)
    14 late at Berko. Wonder will they loop it at MKC platform 5?
  8. Class377/5
    Class377/5 Established Member
    5,594
    19 Jun 2010
    57309 dragging 390118 according to posts else where.
  9. Bald Rick
    10,872
    So I took this for you guys. I have no idea how unusual this is, trains really don't interest me in the slightest!
    And I have no idea how to get that photo the right way up.
  10. Cletus
    Cletus Established Member
    1,831
    11 Dec 2010
    Dover
    I turned my phone upside down, that worked!
  11. azz7008
    azz7008 Member
    77
    17 Nov 2014
    Rotated for you.
    [​IMG]
  12. matt
    matt Forum Staff Staff Member Global Moderator
    6,560
    30 Jun 2005
    Rugby
  13. Minilad
    Minilad Established Member
    4,317
    26 Feb 2011
    Anywhere B link goes
    Damn thing caused me to drop 11 mins between St Andrews and Proof House. Nearly missed my train home because of it
  14. Ash Bridge
    Ash Bridge Established Member
    3,511
    17 Mar 2014
    Stockport Cheshire
  15. dk1
    dk1 Established Member
    8,055
    2 Oct 2009
    East Anglia
    Surprised they didn't withdraw the Watford Jcn call to relieve the disruption to following services. Hats off to them for not cancelling as so many Pendolinos & Voyagers where leaving Euston full & standing yesterday.
  16. onlinespotting
    onlinespotting Member
    339
    14 Apr 2014
    Why does it lose so much time? How fast can these go?
  17. 455driver
    455driver Veteran Member
    11,332
    10 May 2010
    95mph max and very slow acceleration compared to the other trains on the route.
  18. PHILIPE
    PHILIPE Veteran Member
    11,150
    14 Nov 2011
    Caerphilly
    Strange that nobody has mentioned what the problem was with the 390. It was a defective cab door
  19. westcoaster
    westcoaster Established Member
    3,832
    4 Dec 2006
    DTOS A or B
    Any why would it need to be dragged for they do not have cab doors. Maybe a wind noise problem. Or no protection between cab and passengers.
  20. gimmea50anyday
    gimmea50anyday Established Member
    2,699
    8 Jan 2013
    Back Cab
    On the juice with around 9000 horses to shove it along to 125 these things usually fly. With a bodysnatcher cranking barely 2500 horses in comparison the power to haul 11 coaches just isnt there. Its like using a range rover to pull a plaxton premier!
    To be fair seemed to be doing well thru rugby, but i counted only 9 on, so a few ton weight saved will help its progress, and at least it hasnt got shap to face!
    a 67 has even less power at rail (i.e tractive effort not dissimilar to a HST power car with just 4 motors whereas the heinz has at least a comparable figure to a 47 or 50, and 6 motors) and have to scream their tits off to keep a mk4 moving at a credible speed!
  21. causton
    causton Established Member
    5,422
    4 Aug 2010
    And then disrupted a lot of passengers and delayed another train with an SSO? A lot of people get on here you know ;)
    Official reason given on Tyrell was a "door interlock problem". Surely can't be a passenger door interlock problem as then it wouldn't matter if it was hauled or not! Not sure what door had the problem though...
  22. sprinterguy
    sprinterguy Established Member
    10,483
    4 Mar 2010
    Macclesfield
    In which case you counted wrong: It was an eleven car set.
  23. ARoo21
    ARoo21 Member
    102
    17 Mar 2015
    to put it in simplest terms, a 57 can just not keep up with the timings of a Class 390!
  24. Joseph_Locke
    Joseph_Locke Established Member
    1,831
    14 Apr 2012
    A 57 uses nearly half its horses just supplying the hotel power to an 11-car 390, it doesn't tilt (so the EPS is off too) and as 455driver points out a top speed (downhill) of 95mph isn't a top speed of 125mph.
    The 57s were NEVER intended to be used to haul 390s in regular service - the fact that they managed it Crewe - Holyhead was a combination of the bowling green gradients and Palace-of-Westminster-demands-for-restaurant-coaches.
  25. Class 170101
    Class 170101 Established Member
    5,579
    1 Mar 2014
    Didn't the Alsthom contract have to be modified to accept this was going to happen as the dragging on the North Wales Coast meant the locos and the couplers were put through more than they were designed for?
  26. 455driver
    11,332
    10 May 2010
    Don't they?
    I hadn't really noticed and didn't know that!
  27. Minilad
    4,317
    26 Feb 2011
    Thats why they have opening cab windows. So drivers can climb in through them.
  28. D365
    D365 Established Member
    6,737
    29 Jun 2012
    I was fairly sure that an opening cab window is for emergency egress only. Like on the Class 180.
  29. causton
    5,422
    4 Aug 2010
    And for liquids to come out of when they are stopped at a red!
  30. ainsworth74
    ainsworth74 Forum Staff Staff Member Global Moderator
    21,333
    Clearly you've never been at Euston! Very common to see VT drivers climbing into the cab through the windows.
  31. Bletchleyite
    47,010
    You what? I never saw that, and I would assume that would not be allowed.
Thread Status:
Share This Page
