1A40 Night Riviera Sleeper to London (20/11/11)
mralexn
2 Nov 2010
I can see that the up sleeper at the moment is around 100 late, due to a train fault, does anyone have any idea what has happened / is going on?
As far as i can see, its now currently being held at Plymouth station.
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
It was about 130 down at Newton Abbot, back up to about 95 down following a reduced layover in Exeter. Seems to have lost most of that time between Penzance (which it apparently departed on time) and St Erth; not sure what's gone on there.
Did well in the end arrived at Paddington only 11 down having been around 130 down at Newton Abbot.
It must normally crawl through the latter part of the journey!?
In part, sleepers do have a lot of time built into the timetable to accommodate diversions due to engineering work (hence why when thing are normal they often sit in stations for long periods and arrive at their destination early).
mralexn
2 Nov 2010
I was supposed to be going via bristol, and then back through westbury, but it just went the fastest route non stop Via Castle Cary, It was also meant to sit at Exeter for around 30 mins and Bristol TM for around another 40Mins
Oliver
17 Aug 2007
I think they're generally limited to 80mph in a effort to increase the comfort of the would-be sleepers. Arriving in London early is a pain, as there are always people wanting to get off immediately who wake everyone else.
They are, but if there is a delay and the line speed permits it they will run faster. Though in the case of 57s that's only a maximum of 95mph anyway.
