No this service is a booked a single 221.
The service which would form 1V64 on a friday is only a single unit and this returns to Craigentinny, as 1 extra unit leaves there on a Friday monday as 1V52 is a double unit - however this has not been the case the past few fridays because of weekend engineering works.
1 extra arrives on a Thursday night though off 1S47, the 1125 Plymouth to Dundee which is a double set all the way to Dundee on Thursdays. Plymouth would be short of a set of Fridays if 1V66 was a single.
If you're boarding at Edinburgh you will not have any issues getting a seat. Coach B is unreserved.with it being a 5 car does anyone know if this service can be busy between Edinburgh and Leeds?
Its strengthened to 2x220 today between Edinburgh and Bristol so shouldn't be a problem.with it being a 5 car does anyone know if this service can be busy between Edinburgh and Leeds?
If the reserved portion is at the front, the first 4 coaches will be sardine tin conditions between Leeds & Wakefield (but you'd easily get a seat at the rear!Its strengthened to 2x220 today between Edinburgh and Bristol so shouldn't be a problem.
