2 Carriage class 150
Discussion in 'Allocations, Diagrams & Timetables' started by Mike99, 5 May 2015.
Thread Status:
  1. Mike99
    Mike99 Member
    131
    4 Mar 2011
    Fareham
    Hi,
    Todays 1F16, 11.23 Portsmouth Harbour to Cardiff Central is being operated by a 2 carriage class 150, Only saw it from my window so unable to identify he unit, currently just arrived at Bristol Temple Meads 18L
  2. PHILIPE
    PHILIPE Established Member
    7,528
    14 Nov 2011
    Caerphilly
    Not unusual at all, unfortunately.
  3. DanTrainMan185
    DanTrainMan185 Established Member
    5,012
    25 Jul 2011
    Cardiff/Bristol
    That would be the return of the 0730 Cardiff to Portsmouth, which was a pair of 150s (150249 and 150219). I imagine the unit on the return was 150219, as 150249 would have been left at Temple Meads on the outbound working. Of course, 150219 is the newly modified DMU. Didn't get a close look at it as I caught the 7.25 Paddington from Cardiff when I saw a pair of 150s on the 0730!
  4. hassaanhc
    hassaanhc Established Member
    2,097
    5 Jan 2014
    Southall
    For some reason I screenshotted this when I noticed it on Journeycheck in the morning :o (was checking for issues from Southall)
  5. Parallel
    Parallel Established Member
    1,560
    9 Dec 2013
    Indeed, it is sadly not uncommon at all. I saw at least 2 Portsmouth diagrams on Saturday being run with 150s, one by a 150/9 and another by a 150/2. Unfortunate that the 150 with the least capacity (150219) ended up on a Portsmouth run today! Does anyone know why it was delayed? 150s don't usually lose too much time on the route *uncomfortable flashbacks when 150002 ended up on the route and was delayed every journey :lol: *
    Would this eventually end up working the 22.21 departure from Bath Spa (originated from Cardiff) to Westbury as the announcements said it was formed of 2 coaches, and then a three car 158 arrived. If so its fault was probably rectified and was put on the diagram so it'd end up in the right place for tomorrow morning.
  6. DanTrainMan185
    5,012
    25 Jul 2011
    Cardiff/Bristol
    Ah I didn't see journey check! Looks as if it detached at Westbury then! And indeed 150219 does have the least capacity with the disabled toilet. However, I'm glad a 150/2 was sourced as opposed to a 150/1.
    As for the 2221 Bath to Westbury, this is the 158 diagram on the Cardiff to Taunton route (0841 Weston-s-Mare to Cardiff, 1100 Cardiff to Taunton, 1307 Taunton to Cardiff, 1600 Cardiff to Taunton, 1808 Taunton to Cardiff and 2100 Cardiff to Westbury).
  7. Parallel
    1,560
    9 Dec 2013
    Thanks for this!
    Does anyone know if the 158 (158959) is still out of service following the fatality at Keynsham? Or is it running as a 2 car unit? I haven't seen it since.
  8. DanTrainMan185
    5,012
    25 Jul 2011
    Cardiff/Bristol
    No worries.
    Haven't seen 158959 for ages, so I would guess yes it is out of service, hence why there are a lot of 150s on the Cardiff to Portsmouth services.
    In fact, 0730 Cardiff to Portsmouth this morning is 153377+150925!
  9. Mike99
    Mike99 Member
    131
    4 Mar 2011
    Fareham
    The 07:30 Cardiff to Portsmouth passes my flat in Fareham around 10:30 will look out for that, thanks for the gen, if the 153 is still on it at Fareham and not detatched at Bristol or Westbury then I'm sure a 153 over here is quite rare. Happy to be corrected on that point though.
  10. DanTrainMan185
    5,012
    25 Jul 2011
    Cardiff/Bristol
    153s aren't cleared past Southampton so you won't see it unfortunately; 153377 was detached at Temple Meads so it'll just be 150925 you'll see!
  11. PHILIPE
    7,528
    14 Nov 2011
    Caerphilly
    158959 has been out until last week when it suffered severe damage after being involved in a fatality and appears to be a Works job. What has been spread about is that the good end car of 959 is going to be attached to 158766 later this week (fresh off C4) and form a 3 Car Set numbered 158962.
    Appears the 150 Bristol detacher went through to Westbury perhaps due to reduced capacity. No hurry because it only goes on to PM after arrival at Bristol TM anyway,
  12. Mike99
    Mike99 Member
    131
    4 Mar 2011
    Fareham
    How thick am I? Old age creeping up...................
    1F05, 07.30 Cardiff Central to Portsmouth Harbour, 5L at Fareham
  13. DanTrainMan185
    5,012
    25 Jul 2011
    Cardiff/Bristol
    Is there a possibility that the 150/1s could be refurbished to the same interior as the 150/2s? I don't like the layout of the 150/1s and think they are only suitable on Avonmouth and Weston services.
  14. Parallel
    1,560
    9 Dec 2013
    Doesn't sound like they are going to be with FGW after the Turbos head west so I doubt FGW will do anything to them. I do agree with you though, a 150/1 turns up on the 08:23 Southampton - Great Malvern - Weymouth diagram more often than not. Not really ideal...
  15. PHILIPE
    7,528
    14 Nov 2011
    Caerphilly
    The seating in the FGW 150/1s can not be altered from 3+2 to 2+2 because when they came to FGW in 2011 the DFT Bean Counters said that xxx number of additional seats are being provided meaning that this was set in stone. Fortunately losing them in the future as electrification cascades come through.
  16. DanTrainMan185
    5,012
    25 Jul 2011
    Cardiff/Bristol
    Thank heavens for that. I think their seating arrangement is utterly vile and I had the misfortune of enduring 150101 yesterday on the 1200 Cardiff to Taunton. My back went stiff when I got off at Filton Abbey Wood - surely that cannot be acceptable? (and before some smart git pipes up - it wasn't down to my own actions, it was because of the seats on the train!)
  17. 40129
    40129 Member
    249
    23 May 2014
    You're not alone with that problem. I had the misfortune to ride a cl-150 from Hereford to New Street last week and found the seats very uncomfortable (as well as the engine very loud) to the extent that had the train called at Barnt Green, I would have transferred onto the Cross City line to spare my back (and ears) from further punishment
  18. Parallel
    1,560
    9 Dec 2013
    Although the seating can get cozy on the 150/1s, I actually prefer them to the 150/2s. Granted, 150/2s are better for long journeys for many reasons but my knee caps get crushed against the seat in front when at an airline seat/ keep knocking the person I'm sitting opposite at a table when on the 150/2s. :(
  19. 387star
    387star Established Member
    4,621
    The new led lighting though a benefit looks very flimsy and on the cheap
    Some units have mismatched floors where the vinyl has been replaced
    They were last refreshed in around 2005 but i find it laughable the white shade is used where the doors are as shows up dirt the most ! The green isn't too bad and I think the toilets are better than the small ones on a 158 still with original floor tap controls
  20. DanTrainMan185
    5,012
    25 Jul 2011
    Cardiff/Bristol
    A quick update on this.
    The reshuffling has taken place and the FGW 158 formations are now as follows:
    158749: 52778(ex 158959) + 57749(ex 158960)
    158769: 52769(ex 158960) + 57769(ex 158960)....so 158769 reformed to original 2 car unit
    158962: 52746(ex 158959) + 52766(ex 158766) + 57766(ex 158766)
    158960 at the moment no longer exists.
  21. PHILIPE
    7,528
    14 Nov 2011
    Caerphilly
    Believe complete position is (From WNXX Forum)
    Current sets
    158749 - 52778+57749 - new set formed from 52778 previously in 158959 plus 57749 previously in 158960
    158763 - 52763+57763 - no change
    158769 - 52769+57769 - new set previously part of 158960
    158798 - 52798+58715+57798 - no change
    158950 - 57751+52761+57761 - no change
    158951 - 52751+52764+57764 - no change
    158952 - 57745+52762+57762 - no change
    158953 - 52745+52750+57750 - no change
    158954 - 57747+52760+57760 - no change
    158955 - 52747+52765+57765 - no change
    158956 - 52748+52768+57768 - no change
    158957 - 57748+52771+57771 - no change
    158958 - 57746+52776+57776 - not been able to check but assume no change
    158961 - 52749+52767+57767 - no change
    158962 - 52746+52766+57766 - new set formed from 158766 plus 52746 previously in 158959
    Disbanded sets
    158766 - disbanded 52766+57766 to 158962
    158959 - disbanded 52746 to 158962, 52778 to 158749, 57778 for repairs
    158960 - disbanded 57749 to 158749, 52769+57769 to 158769
  22. DanTrainMan185
    5,012
    25 Jul 2011
    Cardiff/Bristol
    Yes that is correct.
  23. Kite159
    Kite159 Established Member
    9,221
    27 Jan 2014
    West of Andover
    Thanks for the information :)
Thread Status:
Share This Page
