2 strikes rule
baz962
8 Jun 2017
So you could apply to TOC A and fail the online test. Apply to TOC B and fail the MMI. Apply to TOC C and be told you can’t apply as two strikes. Apply to TOC D and get a job.
No , because you have to pass mmi .
Daz1310
29 Oct 2018
Hi There
I’m pretty new on here (don’t no if this is the right place to post) had an assessment today which didn’t go to well at all! I’m gutted how I performed after all the hard work I put in revising the past month or so. I wanted to no can I re apply for freight trainee driver instead as I failed with a main line train company or do I have to wait 6 months? Or is it only 6 months with a company you failed the test with?
Hope someone can help me
baz962
8 Jun 2017
Which test you fail . If its the main psychometrics , then six months period
Gooner18
24 Oct 2018
Hi There
Sorry to hear this , what ones did you fail on ?
I believe you have to wait for 6 months now
LeGrimpeur
26 Sep 2017
Hi There
If you start a new application with a company you are normally immediately required to answer a few questions which will determine if you are able to continue with the application based on past failures.
Daz1310
29 Oct 2018
I failed the assessment at the centre and was told 6 months but wasn’t sure if that was for the company or all companies
Daz1310
29 Oct 2018
Stupidly failed the dots test, was told I was very accurate with no mistakes but needed few more lines. I thought I don’t ok as I got past half way down the page
