2016 Christmas to New Year major engineering works
Cletus
11 Dec 2010
Dover
Any there any major engineering works already planned between Christmas and New Year in 2016?
I'm thinking about where to go in that period, so I'm looking for information about blockades/major engineering works on the mainlines + also lines in Kent (hopefully the line out of Dover will be open by then).
I appreciate we are over the 12 week period for booking advance tickets, but I am looking to book hotels in advance of that date.
Thank you in advance for any information.
Alfie1014
27 Jun 2012
Essex
The GEML the route is closed from 24th December until 2nd January, see NR's press release;
In December 2016, the Great Eastern Main line will be closed from Witham and Billericay into London Liverpool Street from 24 December to 2 January inclusive, affecting both Abellio Greater Anglia and TfL Rail services except:
On Christmas Eve, TfL Rail services will be able to operate a limited service between Liverpool Street and Chadwell Heath.
Between 28 December and 2 January 2017 (inclusive), TfL Rail will be able to operate a limited service between Liverpool Street and Chadwell Heath.
Rail replacement bus services will operate from Ingatestone and Billericay to Newbury Park. A rail replacement bus service will operate between Shenfield and Chadwell Heath for TfL Rail passengers.
This in addition to 8 weekends between 17th Sept and 6th November 2016 when there are also various closures between London and Witham/Billericay primarily for Crossrail works and Shenfield remodelling.
Class 466
5 Mar 2010
The Dover Sea Wall will be open by then, Between Saturday 24th & Wednesday 28th December, Sevenoaks Tunnel will be closed with Hastings trains diverted via Redhill to London Bridge LL and a half hourly 'Fast' Sevenoaks to London service will operate.
There's also some major resignalling work at New Cross over the Holiday Period for 6 days which will see services diverted away to Blackfriars/Victoria.
MrB
3 Jan 2016
I assume the closure of Sevenoaks tunnel is something to do with the speed restriction currently in place there?
PHILIPE
14 Nov 2011
Caerphilly
There will be a 6 day closure between Slough and Paddington from 24th December to commission the Acton dive-under and Stockley fly-over. Expect the GWR diversions to Marylebone and Waterloo to operate but this time, it is thought trains will not go to Banbury to reverse but access the Chiltern route via the new Oxford Parkway route.
Bungle965
Buses & Coaches
2 Jul 2014
Blackley and Broughton/ Walsall South
I feel that Chiltern would try and object to that!
Sam
MidnightFlyer
16 May 2010
Would they? Given that it has happened previously and that I can't imagine you'd struggle to fit the diverted services over the new line via Islip I can't see why they'd be up in arms. I seem to recall their timetable took a sizeable hit every time Virgin used to divert via High Wycombe and that diversion happened regularly for years.
JW16
29 Dec 2015
Romford
Will the Romford-Upminster branch remain open between 28-30 Dec inclusive, allowing Romford passengers to travel into London via Upminster?
Problem here is that there's also a big blockade of Waterloo over Christmas, with work in the throat for the P20-24 alterations.
Is it possible the Slough to Paddington stuff will be reliefs only?
philjo
9 Jun 2009
Are there any major works on the WCML or ECML over New Year period?
I can't see anything mentioned yet on NRE or VT sites.
I will be going to Grange Over Sands on 29 or 30 Dec, returning back on Monday 2nd Jan.
Usually use GN into Kings Cross then VT Euston to Lancaster. (or could use VTEC Stevenage to Leeds)
Thanks
PHILIPE
14 Nov 2011
Caerphilly
Further to previous info there will be no GWR diversions to other London stations but trains will run to West Ealing and turn back from there.
I haven't got the actual dates yet as not yet fully in systems, but there will be no trains between Bridgend and Newport on the Main Line and Cardiff Valley services will not run south of Caerphilly or Pontypridd. Massive bus operation. In other words, Cardiff completely closed due to re-modelling and re-signalling
louis97
14 May 2008
Derby
You mean Ealing Broadway for District and Central lines into London.
tcm1106
4 Jan 2010
Thanks
Yes. Major S&C and plain line renewals in the Wembley & Willesden areas. Also a full replacement of bridge 45 in the Harrow area.
collexions
18 Jan 2010
Avoncliff Halt
Thameslink EA20 stage sees the commissioning on the DN Sussex and Bermondsey Dive Under, country end of London Bridge station.
Hophead
5 Apr 2013
I presume Network Rail will have another go at replacing the bridge (or bridges) over Old Lodge Lane, Coulsdon, which was disrupted by bad weather last year. That would see the Brighton Main Line severed for the duration.
tcm1106
4 Jan 2010
Correct.
Does anyone know of any Midland Mainline issues over the festive period ?
PHILIPE
14 Nov 2011
Caerphilly
Start date
27/12/2016
End date
30/12/2016
Route affected
Between London St Pancras International and Nottingham / Sheffield
Train operator affected
East Midlands Trains
Description
Engineering work is taking place between Chesterfield and Sheffield closing some lines.
Early morning and late night services running between London St Pancras International and Derby / Nottingham / Sheffield will be retimed and have journey times extended.
Planning your Journey
You can plan your journey using the National Rail Enquiries Journey Planner
Taken from the NRE Website where Future Engineering Work can be found 12 weeks in advance.
Start date
27/12/2016
End date
30/12/2016
Route affected
Description
Ah thanks. I was thinking around the new year part, which might be why it it didn't show up when I looked.
Still, if there's work between Sheffield and Chesterfield I guess it'll just be diversions around the "old road".
Greybeard33
18 Feb 2012
Greater Manchester
Ordsall Lane Junction closed from 19th to 30th December, so bustitution on the Chat Moss line between Eccles and Manchester. All services on the Bolton and Atherton lines run into Manchester Victoria not Oxford Road/Piccadilly.
dk1
2 Oct 2009
East Anglia
Ha ha guys. I was being extremely facetious as every year a thread kicks off the usual drivel about sporting events & lack of transport on much of the rail network. Lets NOT go there again.
