23:30 from Kings Cross to Leeds
Discussion in 'Allocations, Diagrams & Timetables' started by Buzz Lightyear, 23 Oct 2017.
  1. yorksrob
    yorksrob Veteran Member
    14,777
    But that's not the last evening train from London to Manchester. A quick perusal of NRE tomorrow shows a 23:00 Euston to Piccadilly service which does call at Stockport, so at least passengers have the option of catching the last train of the evening !
  2. Sussex Guy
    Sussex Guy Member
    562
    15 Jun 2017
    However the 20.00 from Euston calls at Stockport arriving about ten minutes after the 19.40 would if it called there so no great hardship there. The same obviously can't be said about the Wakefield situation and as every other KXG-Leeds train calls there it's not unreasonable for people to question why this one doesn't.
  3. J-2739
    J-2739 Established Member
    1,438
    30 Jul 2016
    Ah right, cheers for the info!
  4. CheeseOnToast
    CheeseOnToast Member
    31
    12 Dec 2016
    Milton Keynes
    What about Sandwell & Dudley? Last Down train from Euston leaves at 21:43
  5. greyman42
    greyman42 Member
    129
    14 Aug 2017
    It is my understanding that the 23:30 only went via York when England had a match at Wembley(not friendlies) to get fans back to York. I do not know if this is still the case as York now has a 22:57 service.
  6. Mk55A
    Mk55A New Member
    3
    3 Nov 2017
    Hi Buzz,
    The 23.30 is one of our Leeds Jobs 1D36, the train is booked to go via Askern Knottingliey Pontefract Monkhill Calder Bridge Methley and into Leeds arriving around 2.36am, if we can, we ask control to see if we can go via Wakefield Westgate from Doncaster arriving into Leeds (if we get a run) around 2.05 or even earlier
  7. Class 170101
    Class 170101 Established Member
    3,642
    1 Mar 2014
    29 November looks like the train is serving Wakefield Westgate according to Realtime trains. But the rest of that week it seems to be running via Hare Park Jn and Kirkgate.
  8. 61653 HTAFC
    61653 HTAFC Established Member
    6,612
    18 Dec 2012
    Another planet...
    When I was on it the other week, it ran via Hambleton and Neville Hill to arrive in Leeds the opposite way to "normal", but RTT was showing it running the conventional route via Wakefield Westgate, though correctly listed as not calling at Wakefield. In fact, it was listed as running via the seldom-used through line at Westgate but it obviously didn't actually do so. Are any VTEC services scheduled to use that through line? As it looks pretty rusty...
  9. The Lad
    The Lad Member
    82
    22 Jan 2015
    And that might be to turn the unit.
  10. DanTrain
    DanTrain Member
    77
    9 Jul 2017
    Sheffield
    Why though, don't VTEC always run 91 north (or maybe south, can't remember) on the ECML. If turned once, surely it would need to be turned back at a loop (Newcastle for example)?
  11. Temple Meads
    Temple Meads Established Member
    2,093
    2 Sep 2010
    Tiverton, Devon
    There is a National Express service that leaves London Victoria at 23:30 which calls at Wakefield, it seems to have some good value fares available too. So there is an option other than accommodation in London, albeit one which won't appeal to some people.
  12. IanXC
    IanXC Moderator Staff Member Moderator
    4,656
    18 Dec 2009
    Entering Leeds from the East has the same effect in terms of turning a set. VTEC sets are intended to be First Class at the London end, which is reversed by arriving in Leeds via Garforth. (Note this route is not electrified so cannot be used by 91 sets, only HSTs)
    Think of a set in reverse formation, it heads (with first class leading) through Hambleton South, Hambleton West, through Garforth, past Neville Hill and into Leeds. This means that first class is now at the end which will be the leading end departing Leeds via the usual route through Wakefield Westgate.
  13. yorksrob
    14,777
    I dread to think what time that gets in !
  14. greyman42
    greyman42 Member
    129
    14 Aug 2017
    04:55. Costs about £22.
  15. yorksrob
    14,777
    4:55 !
    I suppose one wouldn't have to worry about a hotel !
  16. DanTrain
    DanTrain Member
    77
    9 Jul 2017
    Sheffield
    But surely this unit enters Leeds reversed to the way it left Doncaster, causing a problem (please forgive my ignorance)?
  17. Mk55A
    Mk55A New Member
    3
    3 Nov 2017
    The 91s are on the North end because it is easier for maintenance purposes, or in case they fail, if the train is the wrong way run, of course at the earliest opportunity the train has to be turned, VTEC like to keep the formations all the same way, so the passengers can alight and depart from the formation quickly
  18. Mk55A
    Mk55A New Member
    3
    3 Nov 2017
    the 23.30 departure is booked via KX , Doncaster, Askern, Knottingley, Pontefract Monkhill, past Crofton, Calder Bridge, Turners Lane, Normanton & Leeds, it can also go via Hare Park, Calder Bridge, Turners lane, Normanton & Leeds, and also via Wakefield Westgate to Leeds, if for whatever reason the set goes via Hambleton of course it will be in the wrong formation, now two things can happen, the set can go via Hambleton (ex Lincoln job in a morning, or it can actually be turned via Normanton Wakefield Kirkgate up through Wakefield Westgate to Leeds, thy could of course be the wrong way around to KX, thus turning it later in the diagram (for instance at Newcastle)
  19. 61653 HTAFC
    6,612
    18 Dec 2012
    Another planet...
    It left Kings Cross in the correct orientation with first class at the buffers end, so would be reverse for a Leeds to London service...
    The set used was (one of?) the 2+8 set(s?) with EMT power cars. I think the set from that service then forms the Hull Executive that morning- not sure how it gets to Paragon then though! :oops:
  20. IanXC
    4,656
    18 Dec 2009
    If a set is in reverse formation at Leeds and needs to form a Hull departure, in correct formation, it can go back to Doncaster via Hambelton, reverse, and via Goole or Selby to arrive in Hull the correct way around.
  21. greyman42
    greyman42 Member
    129
    14 Aug 2017
    It is going via York tonight due to England v Brazil.
  22. Class 170101
    3,642
    1 Mar 2014
    On occasion I think VT do actually miss Stockport and tell people to get an earlier train as no bus will be provided.
    23:00 Euston to Manchester Piccadilly
  23. Starmill
    Starmill Established Member
    8,880
    18 May 2012
    Manchester
    Expect that a bus was provided, at 0130 from Stoke-on-Trent.
  24. Class 170101
    3,642
    1 Mar 2014
    There should really be a train departing Kings Cross at 22:30 for Leeds.
    That could be remedied by extending the 22:00 Euston to Crewe forwards to Liverpool Lime Street non stop then it could go via Warrington or Runcorn or Wigan NW (with a reversal).
    Again a 'Tour De Yorkshire' of sorts, the 23:30 to Wolverhampton can be routed via Bescot due to engineering works on the main line via Sandwell and Dudley. On occasion it even misses out Coventry and Birmingham International and operates via Stafford calling at Wolverhampton and then New Street hence the set down calls.
  25. Class 170101
    3,642
    1 Mar 2014
    I was sure that Virgin just told people to catch the earlier train at 21:40 from Euston to Manchester.
Share This Page
