2401 & 450 Cab
Coxster
9 Jun 2005
Here's a quick snapshot from w/e today.
Beaker
4 Sep 2005
Not the drawing room
Well yes but that does not change is his age for being in the cab surely.
I understand they most likely would let you but it is twisting the rules.
T
Tom
Guest
...Beaker, he is on work experience with South West Trains helping out guards, so surely he has to shadow a guard. He helps a guard do his duties, so therefore he'd need to go in the rear cab, surely?
Ca55ie
30 Jun 2005
It's quite clearly the rear cab, and as he is on Work Experiance it'd be fairly safe to assume that he was being accompanied by someone fairly competant!
Sam
Coxster
9 Jun 2005
Everything I am doing has been agreed with SWT management. If it wasn't I wouldn't be posting about it here would I?!
66526
9 Nov 2005
If you are accompanied by someone with the right cab pass and job title then it is perfectly legal! ;)
Jonno2055
9 Aug 2005
Essex
Kevin my firend did the same on his W/E using a cab pass on his work experience in the cab of a 90.
