350's being attacked
bILLOO
6 Jul 2011
Today there were at least two 350's running around with smashed windows. I assume it was due to stone throwing? Are they safe to be in service with just tape around them?
Class377/5
19 Jun 2010
As long as staff have made them them safe, it's fine to run around like that.
On the 377's here two parts to the windows and it's he inner part that's important. Assume it won be too different with a Desiro either.
Seems like in this case staff have dealt with the units and attended to any possible issues.
Matt Taylor
31 Aug 2008
Portsmouth
Broken windows are a hazard of the railways but each TOC will have it's own documented procedures for dealing with them, it's perfectly safe provided only the outer skin is damaged.
WatcherZero
25 Feb 2010
Ive seen broken windowed trains operate just with the affected carriage closed to passengers.
ATW Alex 101
28 Dec 2010
Ellesmere port
I came across a vid on Youtube showing a plastic pig with cardboard windows where they had obviously been bricked in and i'm pretty sure it was in normal passenger service
Kentish Paul
25 Apr 2012
Ashford Kent
Had an instance in the late 90's where a stone/brick completely smashed a window on a 4-CIG approaching Ashford from London. People were covered in glass but projectile did not enter. Someone made to pull the cord but I managed to stop him as we were within 20 secs of stopping in platform 3 (as it was then). After alerting staff and removing glass bits from the hair of the worst affected passengers, the carriage was cleared of people and locked out of use. The train then continued. I was told I could go, so was not sure if BTP were summoned and statements taken.
Found out next day that this happened now and then (footbridge from town to residential area 1/4 mile west of station).
rail-britain
12 Aug 2007
As above, if the outer pane has smashed the train can remain in service until the end of that diagram
The remaining inner pane has to be marked and secured just in case it is smashed later
If both panes have smashed the train can continue at a reduced speed, with all passengers temporarily evacuated from the affected carriage
At the next possible station the train will either be taken out of service or a temporary window fitted
Smashed windows can also be caused by loose ballast, and it seems to happen quite often to LM units
6Gman
1 May 2012
In the late 70s/ early 80s I frequently saw trains I was travelling on being targetted by stone throwers. (I remember it happening five times in six journeys through the Longbridge area of Birmingham).
Nowadays I very, very rarely encounter it.
Is this a genuine trend, or just my luck?
jonb
8 Jun 2005
Essex
It does still happen unfortunately, Dagenham Dock - Rainham seems to be quite a hotspot with the kiddies.
rail-britain
12 Aug 2007
Changed days, as a young person would normally live outside whenever possible; now they live indoors whenever possible
Equally, there are greater barriers and separation between the public and trains now, along with CCTV footage and other deterents
Yew
12 Mar 2011
On northerns pacers they have a layer of clear plastic sheet, this is anti grafitti but it should also reduce the possibility of debris entering the saloon in the event of someone trying to smash a single glazed window
142094
7 Nov 2009
Newcastle
Probably would keep all the smashed glass together, rather than scattered, but probably wouldn't prevent the brick/stone etc from getting through.
142094
7 Nov 2009
Newcastle
The railways are already very safe, and the chances of either an accident or someone hoying a brick through a window are very low. I'd rather have a larger window to look out of, knowing that.
talltim
17 Jan 2010
A guy on my uni course got hit in the face by a half brick thrown through a train window. IIRC it was through an open droplight on an HST just north of Sheffield station. He had to have fair amount of surgery
jon0844
1 Feb 2009
I meant to write to go through it.. Anyway, bad joke - made worse by writing it wrong! - so let's move on. I don't think any of us want to turn this into yet another Pendolino window thread. :)
Statto
8 Feb 2011
At home or at the pub
On Friday io seen a 350 departing LSP to Brum around 4:15pm with one window taped up.
In 1984 i was at primary school then, & we were on a School trip from Liverpool to London for a couple of days, going on a Sunday, & the train we were on got a window bricked around where the line goes passed Spaghetti Junction[one of the diversion routes used on Sundays].
Railsigns
15 Feb 2010
If you're going to quote Eric Morecambe in big red letters at the bottom of every post, could you at least quote him correctly?
The word you're looking for is "necessarily".
bronzeonion
1 Apr 2009
West London
I was on A stock 5118 arriving into Chesham station one evening, and two stones got thrown from the footbridge outside the station, one hitting my window on 5118 and ther other hitting another window in 6118 (trailer car behind 5118). Luckily all A stock windows are graffiti filmed so it all stayed in one piece.
kizzyboi
18 Jun 2012
Ashford, Uk
^^^^ Repton Bridge by any chance it happened the other day on an Ashford International Bound service from London Victoria. as train terminated at AFK it was taken out of servica and replaced for the return leg.
