SpacePhoenix
- Joined
- 18 Mar 2014
- Messages
- 5,492
Is the 6' 2' manoeuvre there to make sure that the speed is at the bare minimum needed to ensure the mechanical connection?
Why are Desiros faster at coupling than Electrostars? (assuming what people in this thread have said is accurate)
Different manufactures mean different equipment / software and different TOCs have different procedures for attaching. I believe SWT allow attaching before doors are released at some locations. My TOC insists doors are released to allow people off, then closed again for attachment which means it takes longer.
I've always been very impressed with how quickly and smoothly attachments and detachments take place by Southern at Horsham. It is usually so smooth that as a passenger you hardly realise it has happened.
On Sunday afternoon I was aboard a SWT Alton to Waterloo train which was attached to another at Woking. What a difference! I was actually quite concerned as to how rough the procedure felt and there was a considerable bump as we attached to the train in front all without any real warning as the train came into the platform before the doors were opened.
I assume the SWT was 455s? 377s can be kissed together as the coupling mechanism dosnt need much force. Older units with systems like tight lock couplers (southern 455s certainly use them and I assume SWT 455s do to?) need a lot of force to ensure both locks engage. Kiss tight locks together and you'll be there all day trying to get it to lock. If you are on a curve (like attaching units at kings x play 9-11) you need even more force. If you havnt physically moved the other 313 then you won't be coupled properly!
The driver just bangs them together, the computers check everything and the cab shuts down except for the TMS screen which, once it detects how many coaches there are, the driver acknowledges the configuration and then it shuts down as well.Desiros shut the intermediate cabs down once the computers have detected a successful coupling. Other units a pull-away test has to be done to ensure that the mechanical connection was successful then they have to press the couple button to connect the electrical blocks.
When the computers of a Desiro detect a successful mechanical connection, do they automatically connect the electrical block or does the driver still have to press a couple button?
Doesn't the guard open the doors on 377s between Dorking and Horsham? Is this unique on the Southern network?
