377s on Beckenham - London Bridge services
Discussion in 'Traction & Rolling Stock' started by TheJRB, 29 Oct 2011.
Thread Status:
  1. TheJRB
    TheJRB Established Member
    1,138
    14 Feb 2011
    Ashford, Kent
    I understand that most of the Beckenham Junction to London Bridge services are operated by 455s but some 377s are also seen on that route. I've been trying to see which services are scheduled to be formed of a 377.
    I've had a look at the timetable which can be found here. Am I right in guessing that the services marked with the symbol "Only folded cycles can be carried on trains marked with this symbol" are 377 operated or is it the opposite?
    Rail Forums
  3. OxtedL
    OxtedL Established Member Quizmaster
    2,349
    23 Mar 2011
    Folded cycles just tells you it's a peak time service in the peak flow direction. :(
    You've had to pick a timetable where services are different services are going to/from/both London terminals directions so it looks confusing, but I don't think rolling stock has anything to do with it.
    I have never yet seen a 377 down there, but you might be lucky at peak times(?).
  4. TheJRB
    1,138
    14 Feb 2011
    Ashford, Kent
    Oh well it seems I've got the wrong idea then! :roll: ;)
    I've seen videos about of 377s on that route (although I can only find the one at the moment at Birkbeck here).
  5. acg5324
    acg5324 Member
    100
    16 Aug 2008
    Brighton
    From Beckenham Jct the following are booked class 377
    Unless otherwise marked all are 4 cars.
    M-F
    0733
    0812 *6
    0953 *6
    1123 *6
    1954
    2053 *8
    2215
    2253
    SO
    0823
    0953
    1123
    1253
    1423
    1553
    1723
    1853
    2023
    2153
    2223
  6. TheJRB
    1,138
    14 Feb 2011
    Ashford, Kent
    Thank you acg5324, that's brilliant. Quite a few on Saturdays then. :)
  7. Southern
    Southern Member
    461
    19 Jun 2005
    Remember a while back a pair of 455's used to run on the branch from about 4pm on a Saturday. Does this still happen?
  8. TheJRB
    1,138
    14 Feb 2011
    Ashford, Kent
    According to the diagrams over on the UKModernEMU group which I've just come across the 09:23 and 17:48 BKJ-LBG services are formed of two 455s.
    EDIT: I didn't read Saturday, so the above info is only valid Mon-Fri. :roll:
  9. acg5324
    acg5324 Member
    100
    16 Aug 2008
    Brighton
    Its the same unit all day.
    Yes the following from BKJ are booked 8/455
    SO
    0923
    1053
    1223
    1353
    1523
    1653
    1823
    1953
    2123
    2253
    Same units.
    M-F
    The following are booked more than one 455 or 456 unit from BKJ
    0742 3 x 456
    0923 8/455
    1053 455/456
    1153 455/456
    1748 8/455
    1811 2 x 456
  10. TheJRB
    1,138
    14 Feb 2011
    Ashford, Kent
    I can imagine, but still quite a few services formed of that 377.
  11. Southern
    Southern Member
    461
    19 Jun 2005
    Thanks, good to know their still running.
Thread Status:
Share This Page
