Western Sunset
Is that why wheel-sets seem to squeal so much on some trains nowadays?
"Trains and Technology - The American Railroad in the 19th Century" by Anthony J Bianculli sayso maybe it's all his fault!
there is of course another spoiler to the story: the Roman army didn't use chariots!
They were raced in the arena, but fighting was done by infantry and cavalry
I been to Pompeii and seen the grooves in the road network. View attachment 69635 The average width between the two centres of the grooves is about 4ft 8, the grooves themselves about 5 inches wide. There are ancient cart ruts in Malta which have been worn into the limestone all over the islands of Malta and Gozo. The average width is the same
Especially when you remember that the extensive networks of wagonways in the Forest of Dean and connecting to the Monmouth and Brecon canals were generally around 3ft 6inches. These weren't trivial local hauls, the Hay Railway, as just one example, was 24 miles long. Or in the Celtic west can we link these to Ancient British chariots?I don't doubt this is true, but I have seen no connecting chain of evidence that links ancient wheel ruts in Italy in 79AD (or Malta in whenever) to wagonways in North-East England in the early 1800s.
In steam days in the US, the Pennsylvania Railroad used a gauge of 4 feet 9 inches on goods-only lines, despite being otherwise built to 4' 8.5" gauge. I'm not quite sure why, but I assume it was to help with very sharp curves.Is standard gauge (1435mm) always consistent? Or does it vary by a mm or so to suit differing conditions, eg sharp curves?
4ft9in used to be quite widespread in the States even after other broad gauges were eliminated. The tolerances were such that the same stock could run on both, so there was less urgency to get rid of it.In steam days in the US, the Pennsylvania Railroad used a gauge of 4 feet 9 inches on goods-only lines, despite being otherwise built to 4' 8.5" gauge. I'm not quite sure why, but I assume it was to help with very sharp curves.
Not standard gauge, but the old Russian gauge was 5 feet (1524mm). The Soviet Union metricated it to 1520mm, which is still the Russian standard; Finland, having become independent prior to the change, still uses 1524mm. The two are close enough to allow interrunning, but the line from Helsinki to St Petersburg has a compromise gauge of 1522mm and the dedicated high speed stock for this service has the wheels set to match that.
I believe Spain and Portugal officially have slightly different gauges as well,
I was told off by a Latvian railway official for suggesting their network was "Russian gauge", in a way which suggested to me that having a different measurement was a matter of national pride.
I think the point is that the gauge in Latvia is "Latvian" - even if it is the same measure that they use the other side of the border, in their country, it's theirs. (In the same manner, I think people in England would be distinctly unimpressed at being told their trains run on "French" gauge tracks.)Sounds mad, but national pride is not an area where sanity notably rules... one wonders -- was it perhaps the same deal 1920s-onward, as with Finland / USSR? -- USSR metricated to 1520mm, Latvia in its between-the-World-Wars independence, kept 1524mm; whatever may have happened from 1940 on, is irrelevant to the Latvians?
I should have added that the explanation included that their gauge was actually slightly different from that in Russia - I don't recall the exact figures but it's probably on the Web somewhere. Trains can and do run through including to Kaliningrad which is a Russian enclave.I think the point is that the gauge in Latvia is "Latvian" - even if it is the same measure that they use the other side of the border, in their country, it's theirs. (In the same manner, I think people in England would be distinctly unimpressed at being told their trains run on "French" gauge tracks.)
It's a good question. It's not as if railways were invented independently in different places around the same time - the original wagonways may have been but they were essentially superseded by the concept developed by the Stephensons and exported worldwide. So why did people sometimes change the track gauge but keep everything else pretty much the same?These Earth people are silly -- whyever haven't they had the exact same one gauge, globally, since the very beginning?
Indian broad gauge was explicitly chosen on the grounds of improved stability in bad weather, as well as offering more space for inside cylinders.But the "slightly wider" gauges in Ireland, India, Iberia, Russia etc aren't wide enough to claim that notional benefit but lose the advantages of compatibility - even if they don't encounter other networks of different gauges they have to buy non-standard equipment. The only justifications I've seen for this group of gauges are non-technical - fear of invasion in Russia, and the Irish compromise of making everybody standardize on the average of the three existing gauges which was different from all of them (and then got exported to Australia by Irish engineers).
It's possible to see reasons for a narrower gauge on lines carrying light traffic in mountainous areas, and I presume somewhere like Japan was originally seen as such but developed into one of the world's busiest networks. It's also possible to see why a people might think a much wider gauge would be more stable and permit more speed and larger loads, though I happen to think that even in Brunel's time scientific knowledge was good enough that someone could have proved that wrong before the GWR was built and saved everyone a lot of money and hassle.
There were various re-gaugings in the Baltics reflecting their history of successive occupation by Germany and Russia - I recall there are a lot of details on Wikipedia though I couldn't vouch for their correctness. Since WW2 lines within the Soviet Union itself, which included the Baltics and Kaliningrad, have been to the Russian gauge (give or take a few mm) as has Finland. But the satellite states further west stayed on 1435mm.But what gauge was Kaliningrad before WWII?
Remember it was then part of the German enclave of East Prussia
