6Z54 Derails Leyton Midland Road 23/01
Chris M
4 Feb 2012
London E14
And the resilience , or "give" of timber sleepers is noted , - anyone in the past could spot the tell take marks of minor derailments on plain line with wooden sleepers by observing the tell tale scoring. Those who had legitimate reasons to be on the track that is.
Surely anyone who was on the track could spot those marks, whether they were there legitimately or otherwise? </pedant>
Nicholas Lewis
9 Aug 2019
Not speculating on the specifics but often it's a case of the lesser of two evils .
If the train stayed in line and didn't separate , the brake pipe remained continuous and the train continued albeit with additional drag which can be difficult to detect if loco us high power like a 66. Hence lots of track damage.
The other option is train doesn't stay in line , brake pipe separates and train stops sooner. However given the ' chimney pot ' nature of the location, the viaduct could have been badly damaged and people and property killed / damaged.
Given the location this could have been worse. No one hurt and some track damage albeit in a pretty difficult to repair location.
And to those asking why it won't be fixed tomorrow morning , it's because it's not a hornby train set .
Oooooh this armchair is comfy.......
Indeed Bexley 4/2/97 shows what happens when a train derails on a viaduct and doesnt stay on the track
LAX54
15 Jan 2008
Initial reports seemed to suggest that it was a broken rail under the train that caused the derailment.
IF that is the case, far from Network Rail charging the FOC, it will be the FOC charging Network Rail.
There are 3 or 4 (or more) broken rails, all caused by the train, there are also tales that the train was well overweight as well
I am intrigued by photo 2 on Network Rail Media story
What are the red marks on rail, could a flange have been scraping because track gauge was wrong, if it was bit narrow could have caused wheel to ride up, or is it rail head burn from a train spinning wheels
https://www.networkrailmediacentre.co.uk/resources/gob-track-damage-2-png
If the train has almost vertically cracked rails in a number of places, I suspect there will be some serious questions of axle weights (overloading)
Romsey
30 Nov 2019
Near bridge 200
Consists shows zero empty wagons with a train weight of just over 2000 tonnes.
The reference in the train details to 2000t is the load for timing purposes.
It's a good few years since I was involved in timetable planning in Anglia and I don't remember a source of aggregate traffic in Barking.
When a train is terminated en route and the wagons attached to a different service or placed in cripple status, the TOPS record shows 0 LDD 0 MTS.
Just to confuse things further, the train could have conveyed a fully loaded wagons, if the train wasn't fully unloaded due to timing constraints or failure of equipment. The RT3973 HAW forms are applicable in both directions for any specified route unless specifically highlighted.
Romsey
30 Nov 2019
Near bridge 200
As the sockets for the pandrol clips are broken off I would suggest that the derailed wheel was inside the rail, bouncing along the baseplates and the forces would be attempting to twist the rail over. The red mark could be scuffing from the bogie frame or the wheel.
This assumes that the wheel was still complete. If a chunk had broken out of the wheel or there was a very large wheelflat we're even luckier that the whole train didn't tip over on the viaducts.
Freightmaster
7 Jul 2009
For clarification, the train in question actually conveys spoil (destined for Calvert in Buckinghamshire),
rather than aggregate.
MARK
Far north 37
13 Apr 2011
70810 and 816 currently working a train from whitemoor to leyton midland road.
AndrewE
9 Nov 2015
It’s usually worse as it smashes concrete sleepers and rips the housing out.
I thought the big problem with concrete sleepers is that the steel reinforcement is pre-tensioned, i.e. wires are stretched through the moulds, the sleepers cast and then the wires are snipped to separate them. The strength comes from the fact that the concrete making up the bulk of the sleepers is in compression. The disadvantage is that if you chip off a big lump of the concrete then they are likely to self-destruct.
Far north 37
13 Apr 2011
Looks like it was held at Seven Sisters for quite some time before moving onto the GOBLIN. Various amounts of delay put into following LO services.
Yes arrived 45 late at midland road return working booked to leave at 15.06, another engineers train to come in from whitemoor at 21.22 headcode 6Z71 which should be a gbrf service i assume.
GB
16 Nov 2008
Somewhere
6Z71 ex Whitemoor now cancelled. 6Z70 that arrived earlier will run as 6Z71 ex site on Monday.
Far north 37
13 Apr 2011
I imagine there will be a steady stream of engineer trains into the worksite over the next couple weeks.
chappers
5 Mar 2008
If I read it right, it was just one wheel ! but what IS needed, is / are: 6,000 tonnes of ballast, and 1,500 sleepers, plus some bridge timbers for a bridge or two !
Think this is part of what is req:
148 – Falcons for spoil
60 – Falcons for Base stone
120 – Falcons for Top stone
39 strings of rail
There are a lot of my former colleagues in the relaying Contractor in Anglia who will no doubt have a busy couple of weeks. I know the old supervisors used to enjoy a derailment as they are always a good money-maker. All rosters go out the window and it’s an overtime free-for-all. Also, they are jobs that are a thrill to plan as you can make demands that a Contractor normally could no. The name of the game now is to get things up and running as soon as physically possible.
Assuming the quotes figures are correct (no reason to believe they aren’t - although you could throw in some Coalfish and Sidetippers to the mix as the Anglia allocation of Falcons was only 60) that is 15 trains worth of material to bring in and out. The problem will be that the Anglia weekend allocation only ever used to be 13 locos. The likelihood is that any jobs planned over the next couple of weeks won’t provide enough trains. Works of course can be done during the weeks, but that brings the challenge of trying to weave VSTP engineering trains in and out amongst the already congested passenger service.
It will be a huge job to put right. Looking at the state of the rail that’s not going to panel out easily, so I expect the rail may need to be taken out separately and the sleepers bailed or forked out. And it’s always tricky working in and around that area with the various constraints
Nicholas Lewis
9 Aug 2019
Good to see they've got some resources available given Maryland works and do they also need to press on before the Wherry lines blockade
GB
16 Nov 2008
Somewhere
Not a great week (if there’s such a thing) to have the derailment on. Big possession at Kings Cross taking up resources as well as the Maryland possession taking additional resources.
Class 170101
1 Mar 2014
They fixed the track behind the oil train in south Wales far quicker than that. https://assets.publishing.service.g...data/file/748587/R172018_181016_Ferryside.pdf
More space I expect, that train has derailed on a viaduct where access will be very restricted - either from Barking or South Tottenham end.
As Chris M intimated - the cause of the problem hasn't yet been confirmed. Having got into the office this morning, the latest update is that the track damage is over a stretch of nearly 4 miles of track, and the line is under possession between Woodgrange Park Junction and South Tottenham until further notice.
What they are trying to do for the weekend is to try and get the Down T&H available for single line working to get the freight in and out of Thameside. Any trains that do run in and out of Thameside for the time being will be diesel hauled as the OLE has been isolated between South Tottenham and Barking.
I assume its still live between Barking and Forest Gate Jn, so the freight will be diverted this way instead but it will be fun unless Maryland is fixed this weekend, and I'm not sure its due to be completed as there are more Liverpool Street to Ingatestone all weekend blocks starting in a couple of weeks time.
I have read reports that suggest some wagons were overloaded (overweight) with spoil (not aggregates)
Don't know the wagon type but I do remember about 20-30 years ago some spoil trains had rectangular slits cut in the side of wagons to stop this sort of thing happening as it was physically possible to put far more in than was permitted weight wise
Sounds like it was DB Cargo operated (a subsidiary of German Deutche Bahn)
The Overground service that is suspended is operated by Arriva (now also owned by DB)
If I have got that correct, presumably one subsidiary of DB will have to compensate Network Rail and another part of DB
Far north 37
13 Apr 2011
I would wait till the actual investigation is complete before speculating who is to blame for the derailment the claim that the wagons were overloaded is probably pure speculation at this time i imagine it was acton traincrew who were involved in the running of this train who have been working spoil trains for years without such incidents.
Nicholas Lewis
9 Aug 2019
Wagons used on track relaying works have a painted marker on the bogie springs to aid loading within wagon capacity due to the variability of material density on discreet sites. Conversely aggregate flows are repetitive so much easier to know visually whats max limit with operators doing it day in day out. That said someone still has to sign off the train as fit to travel but not necessarily a Certified Loads Examiner as its not a gauging issue.
RAIB havent shown there hand which usual indicates they've not seen anything in the initial reports that suggests anything new will be learnt
Four-wheel mineral wagons back in BR days that were built to be filled to the top with coal but when transferred to engineering duties could be only filled part way with recovered ballast etc because it is more dense. I think some big box wagons (MBA?) were cut down to lower ones in the early days of privatization.
The Overground is on a concession not a normal franchise, so Arriva is paid to operate the trains but the revenue goes to TfL. So Arriva is probably saving a bit of money by not operating the trains, and the loss of revenue is suffered by TfL. Not sure who pays for the replacement buses, if any.
Usually nothing appears on the RAIB site until they've done a preliminary investigation and decided to do either a full report or a Safety Digest. That can take a couple of weeks. I tend to think they will do at least a Safety Digest, in view of the amount of damage and disruption and especially if the rumours of overloading turn out to be true.
185143
3 Mar 2013
I passed through London this morning. Noticed announcements at Euston saying there was no service between South Tottenham and Barking "due to a faulty freight train".
Yet at Liverpool Street, the same was announced "due to an earlier derailment". Surely the same reason should be given everywhere? (Unless of course something significant was discovered between around 07:55 and 09:00...)
