707's to Shepperton and 442's to Windsor: was I told correctly?
MatthewRead
21 Nov 2014
West london
Is this true on the 442 thread it someone has said 707's are to replace 455/456's on the Shepperton line and 442's are in turn to replace 707's on the Windsor line surely that can't be right it would seem so illogical wouldn't it be easier for them to take over the Reading services or are they not cleared?
bb21
Emeritus Moderator
4 Feb 2010
442's to Windsor? I'll have some of what you are on please. :lol:
TT-ONR-NRN
30 Dec 2016
Farnham
If they put 442s on the Windsor line I’ll know that First really have gone mad
Is this true on the 442 thread it someone has said [...] 442's are in turn to replace 707's on the Windsor line ..
Do you have a quote?
If someone has said that this is happening, I assume it was an example of dramatic irony, and not to be taken seriously.
If anyone wishes to make a proposal for this to happen, then this would need to be suggested in the appropriate forum section, and any such posting in the wrong section can be reported using the report button.
In short: it aint gonna happen.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
I’m Not going to say it can’t happen, but in service more that likely it won’t happen.
For reference or those of you who are interested, a 442 has been to Windsor & Eaton Riverside, and Shepperton, before. This being on the 3rd of February 2007 on South West Trains’s Class 442 Farewell tour.
Photo of 2412 at Windsor can be found here.
https://flic.kr/p/23jjt7G
nlogax
Mostly Glasgow-ish. Mostly.
Islineclear3_1
24 Apr 2014
PTSO or platform depending on the weather
Quote from the aforementioned 442 thread - post 4275 "There are insufficient units to run the scheduled services with full length formations now and six additional units at least appear to be required on the Windsor side from December"
and..post 4276:
Isn't this because they're taking 707s from the Windsor's to run Shepperton services?.
hwl
5 Feb 2012
and..post 4276:
2 different issues:
a) extra services on the Windsor lines from December
b) performance of the Shepperton services isn't great and caused bad reactionary delays elsewhere. Hence using 707s improved performance to improve Shepperton service performance and reactionary delays.
and..post 4276:
So in summary, they need some 442s in service so that the overall fleet plan for the Dec timetable works. It’s a huge jump to conclude that means anything other than an internal cascade of suitable stock to provide extra Windsor side services. It will almost certainly mean that some 450s will move back to a few Windsor side routes that they’ve regularly appeared on in the past. Hopefully by December there’ll be no 444s being refurbished and very few 450s left to do.
Or 455s, particularly if they really are putting 707s on the Shepperton services.
43096
23 Nov 2015
So as it stands currently they are stuffed for the timetable change without the 442s. The other factor is do they have enough crews for the new services. Given they can’t even reliably resource the current timetable, the answer would seem to be “no”.
What’s the odds on the extra services being planned cancellations?
