91119: Returns to service and in Swallow livery too!
Class455
19 May 2016
Looks like 91120 may be taking 91119's place in being withdrawn at Bounds Green, according to another forum...
What happened to 91120? Has it suffered a similar fault to its sister?
xotGD
4 Feb 2017
Indeed they do - they can't keep cadging 90s off DB for all eternity.
I'm hoping that they might start cadging 90s off Freightliner too.
(The fact that I haven't had 90048 or 90049 might have some bearing on the above statement!)
43094
19 May 2010
91120 is currently stopped until further notice.
It is being robbed to keep other ones going.
As far as is known, there has currently been no decision as to if it will come back into service or not (with LNER).
43094
19 May 2010
All the seven class 90s mentioned in the previous two posts are compatible.
I *think* 028 may also now be - but hasn't yet been used.
037 isn't.
040 isn't, and likely won't be as it stands.
43096
23 Nov 2015
Please can someone confirm what this compatibility is - I thought all the 90s had the UIC sockets that the Mark 4 use for push-pull operation? My recollection was that the mods for use on East Coast related to fitting of DRA (hence the 'D' in the WEDC pool code?).
Class455
19 May 2016
I heard yesterday from a good friend of mine that 91119 ran under its own power for the first time yesterday, can anyone confirm?
WillPS
18 Nov 2008
Out of interest, what happens to the lease on engines/units which have broken and will not be fixed (or at least wont be fixed for a while)?
Do payments relating to that specific unit stop until such a time the unit re-enters service? If not, does the ROSCO fund the spot-leasing of replacements?
Whistler40145
30 Apr 2010
Lancashire
Presumably if another 90 is drafted in as a temporary replacement for 91119, this would only be until sufficient IEP units are in traffic?
I presume that neither classes 88 or 92 are fitted with the necessary TDM cables and equipment?
43096
23 Nov 2015
It depends on the nature of the lease. In general, though, it is up to the operator to fix it - the owner will expect it back in working order at the end of the lease, unless it suffers terminal damage where owner, operator and relevant insurers will be involved. In normal circumstances there is no interruption of the lease whilst it is broken.
43096
23 Nov 2015
Correct. Moot point anyway as an 88 is top speed 100mph and a 92 87mph (140km/h) - at least 110mph is required to be suitable as a stand-in for a 91.
Whistler40145
30 Apr 2010
Lancashire
There's no other Electric options, if 86101, 86401 & 87002 weren't required for Sleeper ECS duties, possibly if push comes to shove, they could be used, but no doubt Traction Knowledge of LNER drivers would be a big issue.
captainbigun
3 May 2009
It’s just DRA. There’s no TDM modification. TDM is TDM.
driver_m
8 Nov 2011
Please excuse my ignorance as I'm just a humble rail enthusiast, what's DRA?
Drivers Reminder Appliance. It's a large red button that we have to use use when stood at a danger signal. Prevents Starting against Signal SPADs aka known as ding ding SPADs. It cuts taking power when deployed, When we had class 90s, they weren't fitted with DRA .
43094
19 May 2010
91119 has had a couple of test runs... yesterday Bounds Green - Langley Jn and back, today Bounds Green - Peterborough and back.
43094
19 May 2010
91119 actually still at Bounds Green... Another test run planned overnight tonight, this time to Grantham, with a full set.
geoffk
4 Aug 2010
The 90s do indeed lose time, usually a good 5-10 mins on Leeds or Newark services. While they are quicker off the mark, being limited to 110 mph does pose it's problems.
HSTs, if available, would be the better choice timekeeping wise.
There was a 90 out yesterday (Sunday 4th). It worked the 0903 KX - Leeds, which I saw arrive Newark 21 late, having left KX 9 late. It was 20 late into Leeds.
hexagon789
2 Sep 2016
They just can't keep the bookings really, they may only lose a minute or two here or there, especially on workings with lots of calls for which they are more suited that a 91, but once they lose time, that's pretty much it, not much chance of regaining it.
They may accelerate quicker from a stand but that extra 1,090hp and 15mph of a 91 does make a difference in the end.
