NotATrainspott
- Joined
- 2 Feb 2013
- Messages
- 3,223
In the Manchester HS2 plans, the north chord from Manchester up to Preston uses wrong-way running with trains to the North on the northeastern track and to Manchester on the southwestern track.
Here's the Manchester end of the chord
Here's the Preston end of the chord
In the first PDF you can see the to-Preston-from-Manchester track crossing the up and down London lines on a viaduct and then ending up to the north-east of the to-Manchester-from-Preston track, which is then swapped over again in the second PDF. It seems utterly bizarre when there's all that free land available and a flyover needs built at both junctions anyway but I presume there is some extremely valid engineering reason for it. Weird.
