Abellio Greater Anglia Class 755s (Regional Trains)
chubs
30 Oct 2012
Why would they use diesel if there is power available?
Seat reservations really not needed on the routes they operate on.
TheEdge
29 Nov 2012
Norwich
Managed to time a 3 car from 0 - 100 on OHL.
Starting from a stand at a red signal Haughley Junction climbing the gradient heading down road it took 81 seconds to hit 100, which I'd say is fairly impressive.
Peter Sarf
Croydon
Had a few rides this weekend (and on 745s). Impressed by the ambience.
Main problem was the step down from the raised area over the bogie which I fell down from !.
dk1
2 Oct 2009
East Anglia
I noticed that when standing in platforms 1 - 5 in Norwich, the diesel engines were switched off and the pantographs raised; is that normal?
Obviously its better to allow them to idle on electric rather than diesel but also because on taking the drivers key out the clock starts ticking & the unit will gradually shut itself down over 20 or so minutes. This leads to two problems. Firstly the doors will lock at the end thus trapping any passengers already onboard. Secondly when the next driver tries to start the unit it will have to go through the full process from shutdown. This can take 4-6 minutes and potentially lead to a delay. Leaving the unit with pantograph raised saves all these issues. That's why it's now frustrating to find your train is in platform 6 at Norwich.
LAX54
15 Jan 2008
Some would say that is absurd ?
LAX54
15 Jan 2008
Can you arrange for 6 to be wired this weekend please? Nobody has mor clout than you ;)
If only ! Get myself into enough grief too easliy already ! maybe as the whiole fleet is now bi-mode a business case can be made.....on delays and trapped passengers alone !
306024
23 Jan 2013
East Anglia
And order a bit of spare wire for platform 1 at Ipswich to save us all getting wet ;)
I have tripped down the step, banged my head and got trapped in a unit, all on the same day in platform 6 at Norwich when the units were first delivered :oops: Not the best way to learn, but you don’t do it again (yet!). Fortunately the unit was forming the train I wanted to catch, just advertised about 40 minutes before departure.
LAX54
15 Jan 2008
755 408 currently heading to Colchester substituting for a 745.
15.43 off Ipswich...
Was going to be for the 1430, but the 755 failed, so stepped up the 745, 755408 came good for the 1500, and will form 1P50 starting Colchester at 1819
dk1
2 Oct 2009
East Anglia
You boys have been so helpful with my requests today on the 5Qxx testing paths. The tech bods onboard can be very demanding with their stop/start, high speed testing & other route needs. Much appreciated.
Railperf
30 Oct 2017
That is very impressive. Even better on a level or slightly downhill start - 100mph in 69secs is achievable!! Even in torrential rain a 755 leaving Colchester for Manningtree was faster to 60mph and 100mph than my best Class 360 run timed in dry conditions!
dk1
2 Oct 2009
East Anglia
I don't think that's helped by the doors being held open due to Covid. I had a very noisy experience from Cambridge sat near the pod.
Not all are set to have them open. I override it if they are & keep them closed.
trebor79
8 Mar 2018
Well done. I went into Norwich a few weeks ago and they were closed, thankfully. Given the very low loadings, the "risk" of transmission form touching buttons must be unmeasurable. Plus you really ought to wash your hands after visiting the bog (the only real reason you'd need to pass through the power car)!
Which reminds me, have the toilet taps been altered, seemed much easier to wash my hands than in the past?
dk1
2 Oct 2009
East Anglia
There are no taps in the toilets. It's all done by sensor.
170TurboFan
25 Jul 2018
I do enjoy the thrash but my sister who was sat opposite me not so much and wished the doors were closed due to the noise. I do think the auto shutdown is a little silly on diesel mode locking the doors as well requiring as you say the full reset taking 5 minutes. But can understand why, maybe Stadler were talking to Northern at the time who like to make you wait until 2 minutes before departure before letting you on. Anything on Platform 6 I don’t wait on the train due to the automatic locking.
trebor79
8 Mar 2018
I know. Sorry I should have been clearer, have the sensors been altered? It used to be next to impossible to properly wet your hands and rinse the soap off because the sensor was to one side of where the water comes out and the water stops almost instantly that the sensor stops "seeing" your hand. After about 6 tries there is a big CLUNK from somewhere behind the mirror and that's your lot, no more water.
The last time I travelled, I managed to wash my hands properly, a first fort hear units.
Noticed too that the enhanced cleaning also seems to involved wiping all of the toilet spray from the walls - good news. I didn't like using the small cubicles with visible "stuff" in a ring round the pan and slowly dribbling towards the floor.
dk1
2 Oct 2009
East Anglia
No that's not nice but good they are cleaning them. Plenty of extra hygiene measures. Not noticed any change with the water flow for hand washing. Cant say personally I've had an issue.
421 is parked up At Colchester with the London end bogie on wheel skates.
Gearbox issue I am led to believe.
dk1
2 Oct 2009
East Anglia
Why does that bit of wire not go full length of platform?
I think it was as usual with BR done as cheaply as possible with only regard to operational use. Nobody would have imagined EMUs using P1 so all it was good for was as a shunt use for electric locos. Sticking up an 'Electric Trains Stop Here' sign was an easy way out.
LAX54
15 Jan 2008
We always try to help :) tell us what you need, and will try to accomodate, does not always pan out tho of course. the 755 parked on the Reception Road is a bit of a pain tho :) (Flat Tyres I hear)
Rest assured if you are on a 755 from Ipswich/Diss, you will never go into P6 now !
dk1
2 Oct 2009
East Anglia
We always try to help :) tell us what you need, and will try to accomodate, does not always pan out tho of course. the 755 parked on the Reception Road is a bit of a pain tho :) (Flat Tyres.
Was told yesterday it's a gearbox issue. Should be skated to Clacton overnight this week.
LAX54
15 Jan 2008
ok :) we were under impression it was 'flats' :) so how does it work brake wise with, what will be the last bogie on the unit?
dk1
2 Oct 2009
East Anglia
Now you've got me. Shame you didn't ask yesterday as I spent all day testing with the tech guy who's assisting with the move. I've never done a skater.
LAX54
15 Jan 2008
Unless, as it is articulated, there are still 'braked' wheels on the last coach
TheEdge
29 Nov 2012
Norwich
Still annoying when we get sent into the Low Level then have to stop halfway in to drop the pan and start the diesels! Although I often call you lot up near Flordon and ask to see what I can get to make it that bit easier... ;)
