samuelmorris
I imagine the NIR Class 450 is a much better example of that than the 210.I'd completely forgotten about them, the experiment at what building a Thumper in a Mk3 body might be like.
Having the engines in a separate module allows the floor in most of the passenger area to be level with the standard platform height. In theory this allows level boarding without a ramp, although it will be interesting to see how this works on curved platforms or those of varying height. It also allows the DMU to be identical to an EMU, just with the engine module. I don't think any of the branch lines have significant train length constraints so the extra length of the engine module probably doesn't matter - but it might be one reason way Northern, for example, isn't buying this design.Wow. The more I'm discovering about these the more it seems like they're just a design for low platformed railways which for some bizarre reason a British operator has ordered despite it being unsuited. A multiple unit design which can't be altered, for example, to have gangway connections between units working in multiple, and with a corridor through an engine compartment. They sound lovely.
Above floor engines in a DMU are more recent than that: the Class 210s had them.
Well yes they an adapted low floor design but so what? they look excellent to me and will probably be superior to travel on compared to a CAF 195, although I expect the Stadler units are more expensive, and perhaps a bit overkill for some of the branches they will work, they would seem to me to more suited as a long distance Regional Train.
That's how they started out, but the FLIRT platform has grown in many ways.Wow. The more I'm discovering about these the more it seems like they're just a design for low platformed railways
I disagree. Stadler are masters at making a reusable design which is suited to almost any use case - from 2-car rural branch line unit to 8-car intercity train. Low platforms, high platforms, low speed, high speed... you name it, Stadler will build it.which for some bizarre reason a British operator has ordered despite it being unsuited.
As someone from the continent, I've never really understood the British fascination with gangways. What problem do they solve? And isn't there a more practical approach?A multiple unit design which can't be altered, for example, to have gangway connections between units working in multiple,
A result of adding diesel to an electric train.and with a corridor through an engine compartment.
If the FLIRT UK is anything like the mainland FLIRT 3 (mechanically, ride quality), it will be a very good train. The quality of the interior is down to the operator's choice, for which Abellio have asked quite a lot of input.They sound lovely.
You could even replace it with a battery or hydrogen module.Also when you wire up all your lines you can simply remove the power module. Unlikely to happen in East Angelia but maybe if they ended up being cascaded in the distant future.
Here in the Netherlands, NS have indicated "boarding zones" at some platforms where regional trains stop. They ask passengers to wait in that zone to even out loadings across the train, as each platform along the route has a different boarding zone. "A train is always guaranteed to stop there". It is slowly gaining traction.
The alternative would've been underfloor engines (as in the 800s) which would have an impact on the passenger experience. And it would've potentially made level access impossible - which is unpreferrable. It really speeds up boarding, quite
the interior specs are very similar to the Abellio flirts they have on the mainland Europe... I’ve never been on an Abellio one though.
I'm not convinced by the 'evening out loading' argument, but it does lead to situations where staff are restricted to one unit. As a passenger, there's nothing more annoying than 'there is a trolley service in the front three cars only'.As someone from the continent, I've never really understood the British fascination with gangways. What problem do they solve? And isn't there a more practical approach?
As far as I can tell, the British argument against that is that operators want the flexibility to kick out a 2-car Class 158 with end doors on a route normally operated by a 3-car Class 170 with doors at thirds, or something similar. If they don't tell people what to expect then there won't be confusion when something different happens.Here in the Netherlands, NS have indicated "boarding zones" at some platforms where regional trains stop. They ask passengers to wait in that zone to even out loadings across the train, as each platform along the route has a different boarding zone. "A train is always guaranteed to stop there". It is slowly gaining traction.
I've found a video on YouTube of the RE 19 Arnhem - Düsseldorf, which is operated by Abellio with FLIRT3 trains:
I seem to recall someone saying the Polish intercity ones are pretty close to the Anglia ones, seen a few videos for them.
According to one highly reliable poster on here, all of the new GA stock will have a small yellow panel.
I think it looks better with the yellow warning panelStupidly and annoyingly this is true.
I'd prefer without but I don't think we should take safety concerns lightly. The days of a near annual big train crash on the system are thankfully consigned to history for good reasons.
This Abellio FLIRT is a regional train, it surprises me that they have even bothered to put in first class at all!At 1:40 it's interesting that first class on that train is a door and an anti-macassar, these trains would fit in well on Southern!
They don't look awful, but the walk through carriages and lack of carpet gives it a bit of a spartan look.
Are the raised seats at the carriage ends because they're over the bogies? Is the aisle raised here too?
Check my previous post about yellow panels.
Almost all German trains have 1st.
