Abellio Greater Anglia Class 755s (Regional Trains)
Alfie1014
27 Jun 2012
Essex
Rail Technology Magazine say new images of the 745/755s have been released but only show a couple of new photos with a slightly different front-end design and yellow first class stripe.
Thanks for the tip off Wivenswold they look quite smart, though had to chuckle at the one pic at Ipswich with the Central Trains livered class 156 in the bay!
Domh245
6 Apr 2013
nowhere
5th side window from the front.
Whatever it is (assuming that you are including the driver's side window in that count to make the window in question the one with the weird split running vertically though the middle) - it doesn't appear to be on the IC Flirt, whilst everything else in the render (certainly of the first car) appears near identical. I suspect then that it is something to do with the interior fit-out, possibly some sort of partition door that isn't required in the longer version?
Regional Unit
IC Unit
Sorry, yes, including the driver's window. Yes, you are talking about the one I mean. Could be a luggage rack or partition, I suppose.
Cheers for the IC link, looks really good (and I like the proper use of the yellow stripe).
The IC unit appears to have the window "thing" on the second coach by the way. I'm inclined to think it's most likely the back of a luggage rack.
whoosh
3 Sep 2008
Second window to the right of the doors?
I suspect it is the reflection of the out of sight overhead wire stantion. It's in the right place to be level with the one that is in sight behind the train.
whoosh
3 Sep 2008
Sorry, ignore me. I was looking at the Railway Technology illustration, not the ones on GA site.
Clansman
4 Jan 2016
Hong Kong
Just out of curiosity, is there a reason why the distance, on the driving coaches, from the last window to the cab door (where the Greater Anglia logo is) is so great? Is it toilets? Extra storage?
Electrical equipment I believe, Stadler don't tend to put it below the floor because the floor is lower than other stock (the design is mostly for very low floor countries like Switzerland).
dp21
10 May 2017
Exactly correct. It also helps protect the equipment from external damage. They're quite hot on reliability.
On the ICs, the centre two cars have an extended section like this without windows to allow for electrical equipment also as I believe those two bogies are powered.
Whatever the interiors of those sections are like I hope they are better suited for people of anything taller than 5ft unlike the central corridor on the 90s!
Bornin1980s
4 Apr 2017
It might be noted that these trains seem to have gone full circle with regards to equipment layout. You see, placing electrical control gear above the floor behind the cab goes back to tube stock of the 1920s, and LNWR electrics of 1914!
https://goo.gl/images/zQYv9u
The only thing the Staders are missing are the huge air intakes.
dp21
10 May 2017
Are we still on for these trains entering service in January 2019?
I doubt it. I believe the 720s are set to enter service first despite starting to arrive after the BMUs as they have already had most of the type testing done with the 345s etc. The FLIRTs will require all that to be done and given the first one is now not set to arrive until around October I don't really think they'll enter service in Jan 19.
Domh245
6 Apr 2013
nowhere
Battery Multiple Units?
Bimodal multiple units, although reference to them as BMUs isn't helpful given the battery conflation. The official documentation (that also refers to AIR12 units for the Stanstead Express Fleet) refers to HYB3s & HYB4s for the 3 and 4 car units respectively.
The franchise agreement also notes that the lease dates start in February 2019 for the Aventras, April 2019 for the HYB4s, May 2019 for the Airport and Intercity units, and July 2019 for the HYB3s - so that should give a good idea of when stock will start to appear in passenger service.
D365
29 Jun 2012
Hold on, are we going back to Southern EMU classifications here?
Domh245
6 Apr 2013
nowhere
No, that's just what they were called in the franchise agreement in lieu of any better way to succinctly describe them. Since then, numbers have started to appear - 720s for the Aventras, 745 for the intercity and airport flirts, and 755 for the bimodal flirts - although the last two aren't yet confirmed (Googling them only brings up wiki and Andrew Gwilt - make of that what you will) - which is what I expect will be used going forward.
dp21
10 May 2017
Internally they are colloquially known as BMUs - Bi-Mode Multiple Units.
I can, shy of sharing confidential information, pretty much confirm that it's 745 and 755 for the FLIRTs. I forget the exact numbering off the top of my head but I know the 4-cars are numbered in sequence after the 3-cars in case the latter are ever extended. So, the last 3-car would be something like 755314 and the first 4-car would be 755415.
Alfie1014
27 Jun 2012
Essex
Passed the site of Brantham depot today for the first time in many months not much further sign of an progress on the ground. Mind you the FLIRTs can’t come soon enough, today the Ipswich Pboros (as 2 car 170s) were wedged with many travelling via Pboro to avoid London and the bus/tube replacement and with no Cross Country services (due to the strike) east of Pboro, station overtime was the norm and still people were getting left behind.
Railperf
30 Oct 2017
Just spent 90 mins on a Norwegian Flirt. They seem to have a good ride and good build quality.
And they accelerate very quickly too. 100mph from zero in less than 2 minutes...even in snow
Video with GPS overlay here....
AverageTD
13 Aug 2017
West London
I bet that Shippea Hill was packed
dp21
10 May 2017
Latest news suggests that the FLIRTS will be arriving with yellow front ends. Something to keep all those traditionalists happy.
Apparently due to issues with risk assessments on level crossings and the old discussion about track safety.
Apparently it hasn't been decided for certain yet but don't be surprised if that's what happens.
Meh...really doesn't bother me what colour the snout is, so I'm happy to allow staff safety to decide it. If track workers want it painted yellow, that's good enough for me. It's not like a different coloured can of paint is going to cost more.
Wivenswold
24 Jul 2012
Essex
Booo. Shame, I thought we'd see the last of that ghastly appendage round these parts.
dk1
2 Oct 2009
East Anglia
I must be a traditionalist as I'm smiling 8-)
