Aberdeen - Inverness £170m Upgrade
Discussion in 'Infrastructure & Stations' started by Altnabreac, 16 Oct 2015.
  1. Altnabreac
    Altnabreac Established Member
    2,287
    20 Apr 2013
    Salt & Vinegar
    Previous thread locked so starting a new one.
    http://www.railforums.co.uk/showthread.php?t=98519
    Contractor appointed to carry out phase 1 works which are listed below.
    http://www.transportscotland.gov.uk/news/bam-deliver-£170m-aberdeen-inverness-rail-upgrade
    Also worth following the Network Rail A2I twitter which has good updates on the project:
    https://twitter.com/networkraila2i
    In terms of what it doesn't include the new stations at Kintore and Dalcross are being progressed by NESTRANS and HITRANS.
    Dalcross
    http://www.hitrans.org.uk/News/Story/159
    https://www.pressandjournal.co.uk/fp/news/inverness/722422/inverness-airport-soon-get-train-station/
    Kintore
    https://www.pressandjournal.co.uk/f...-station-after-50-year-absence-gain-traction/
    http://www.nestrans.org.uk/db_docs/...ne_2015/6b_Publications_and_Consultations.pdf
    Also unclear is how much Level Crossing elimination work will be done in Phase 1.
    Phase 2 in CP6 will look at redoubling between Nairn and Inverness to give more flexibility for the hourly train service and to provide capacity for a half hourly Elgin - Inverness service. Some doubling may be needed in advance of Phase 2 at Dalcross when the station reopens.
    http://www.transportscotland.gov.uk/project/aberdeen-inverness-rail-improvements
    One scheme which interacts with Phase 2 is the Inverness - Nairn A96 Dualling. It proposes replacing the existing Gollanfield Rail Bridge with a new structure which could eliminate one of the main obstacles to redoubling.
    http://www.transportscotland.gov.uk/project/a96-inverness-nairn-including-nairn-bypass
    Rail Forums
  3. jw
    jw Member
    134
    25 Jul 2010
    Is there any indication of the journey time savings made possible by this work? Will the introduction of HSTs contribute to further reductions?
  4. cb a1
    cb a1 Member
    211
    9 Mar 2015
    I believe that a 20 minute journey time reduction is expected. I don't know if that's the upgrade and / or the change to HST.
  5. cjt0131
    cjt0131 Member
    64
    14 Dec 2014
    be great to see a station serving inverness airport
  6. Altnabreac
    2,287
    20 Apr 2013
    Salt & Vinegar
    The whole project is meant to reduce journey times from 2 hours 25 to under 2 hours so a 25 minute journey time reduction.
    What is unclear is how much of the time savings will come from
    • A2I Phase 1 - this £170m investment by 2019.
    • The HST introduction from 2018 onwards.
    • A2I Phase 2 - The CP6 investment with more Nairn - Inverness redoubling, more level crossing eliminations and possibly other investments.
    Of course to actually deliver a 2 hour journey time will need more than 25 minutes worth of speed improvements because of the 2 new stations and aspiration for another new station at Bucksburn in CP6.
    The scheme was paused after the franchise award so that Abellio and Network Rail as an alliance could work together to see exactly what elements were needed to deliver the franchise required speed uplift.
    This has presumably been agreed now but not seen anything in public domain about 2019 journey times. Would be worth someone tweeting Network Rail A2I to ask them.
  7. clc
    clc Member
    1,110
    31 Oct 2011
    The franchise ITT stated that Network Rail was designing the scheme on the assumption it would be operated by class 170s so you'd assume HST's would bring additional time savings.
  8. clc
    clc Member
    1,110
    31 Oct 2011
    This time-lapse video of a new road bridge over the Aberdeen-Inverness railway at Inveramsay has just been released. It's of interest because the new bridge is clearly designed to allow future doubling of the line:
    http://whsclients.co.uk/fLKs/XHGyQPZo
  9. Altnabreac
    2,287
    20 Apr 2013
    Salt & Vinegar
    But not dualling of the A96!
    (My understanding is they will probably go for a split carriageway solution here.)
  10. clc
    clc Member
    1,110
    31 Oct 2011
  11. Altnabreac
    2,287
    20 Apr 2013
    Salt & Vinegar
    Good news and bad news there. Sounds like to achieve double track through the tunnels with electrification clearance might be a big disruptive job. Maybe better not to include it in Phase 1 and do a half hearted version. Hopefully will be done properly in Phase 2.
  12. NotATrainspott
    NotATrainspott Established Member
    2,865
    2 Feb 2013
    It's disappointing but wholly understandable. NR get funding from the Scottish Government to improve the rail network for passengers and for the economy, and in this case they've worked out that the best way to go about things is to redouble everything but the tunnels. If they did spend money on the tunnels, then they wouldn't have as much to spend elsewhere, so they may well not be able to fund the improvements that will actually make a difference. The benefit of redoubling this section will only come about when there are significantly more trains per hour.
  13. najaB
    najaB Veteran Member
    20,694
    A short section of single track does eliminate flexibility a little bit, but it isn't the end of the world. As others have said, if there's only a fixed pot of money it's best to spend it where it will have the biggest impact.
  14. A0wen
    A0wen Established Member
    2,525
    19 Jan 2008
    But are HSTs actually quicker - up to 90 / 100 mph - than 170s?
    I seem to recall when both operated on the Midland Mainline out of St Pancras, the 170s were noticeably quicker at getting up to speed - admittedly not as good as the Meridians, but more than capable of outrunning an HST.
    So unless the route is being upgraded to >100mph running, and bearing in mind the longer dwell times for an HST than a 170 - I'm struggling to see where they're going to find further time savings.
  15. edwin_m
    edwin_m Veteran Member
    17,043
    A 170 is a bit underpowered so acceleration is pretty poor at the top end of its speed range (they struggle to achieve 100mph at all unless downhill). At the lower end of the range the dominant factor is proportion of weight on powered axles, which is 50% for a 170 and probably a bit less for a 2+5 HST.
  16. najaB
    20,694
    At 9+2 probably not, at 5+2 I'd bet almost certainly.
  17. D6975
    D6975 Established Member
    2,048
    26 Nov 2009
    Bristol
    Realigning and a new station at Forres is mentioned, but will this be 2 platforms, moving the loop to the station?
    This would remove the 'dead' time that westbound trains sometimes spend in the loop.
  18. JohnR
    JohnR Member
    488
    23 Jul 2010
    Class 170 is about 9.5hp/ton, while a 2+5 HST would be just under 15hp/ton. So i'd expect much better acceleration.
    Plus ScotRail intend to have a number of 2+4 HST sets, presumably for this route and Inverness-Central Belt.
  19. najaB
    20,694
    I hope they've ordered the prerequisite number of 'Turbo' decals to apply to the sides!
  20. Bill EWS
    Bill EWS Member
    609
    10 Feb 2006
    Didcot
    The tunnels at Aberdeen were double tracked when I started at Kittybrewster Depot in 1963. I am not aware that there is anything to stop re-doubling. They are just cut & Cover tunnels so shouldn't have any difficulties, that I know of. It was all double track between Aberdeen and Inch. Kintore was still open and the junction to Alford still operational for freight as was the Oldmeldrum branch and the MacDuff branch, albeit cut back to Turrif that had a daily goods, that I worked over a couple of times.
  21. najaB
    20,694
    Two things come to mind: has the lifted track bed been used for running cabling, and would there be enough room for electrification clearances if the double track was reinstated?
  22. Dr Hoo
    Dr Hoo Established Member
    1,424
    10 Nov 2015
    Hope Valley
    It is also sensible to allow for full container clearance through the tunnels at Aberdeen.
  23. Railsigns
    Railsigns Established Member
    1,764
    15 Feb 2010
    That was decided about a year ago. The design has been progressed on that basis.
    Yes, two platforms, at the middle of loop which will be over a mile in length.
  24. snakeeyes
    snakeeyes Member
    183
    7 Jun 2011
    Hi, does anyone know what's the latest development with the Aberdeen -Inverness improvements?
    is there going to be a station for Inverness airport?
    New station at Forres?
    Cheers.
  25. Highland37
    Highland37 Member
    1,141
    29 Jun 2012
    Yes and yes as far as I know. The City deal confirms that.
  26. Altnabreac
    2,287
    20 Apr 2013
    Salt & Vinegar
    Worth following the project on Twitter:
    Or you can sign up for email updates here:
    http://www.aberdeeninverness.co.uk/index.html
    Dalcross (Inverness Airport) is technically not part of the project itself (beyond the enabling infrastructure) but is being progressed as a Scottish Stations Fund application by Hitrans. You can see the latest information on it here:
    http://www.hitrans.org.uk/userfiles/file/INVERNESS AIRPORT DALCROSS STATION 10 12 2015.pdf
    Kintore Station is also technically not part of the project and is being promoted by NESTrans. AECOM are currently developing a Business Case on their behalf. Latest info is here:
    http://www.nestrans.org.uk/db_docs/..._February_2016/5a_Rail_Action_Plan_Update.pdf
  27. snakeeyes
    snakeeyes Member
    183
    7 Jun 2011
    cheers :D
  28. collexions
    collexions Member
    48
    18 Jan 2010
    Bradford-on-Avon
  29. clc
    clc Member
    1,110
    31 Oct 2011
  30. Highland37
    Highland37 Member
    1,141
    29 Jun 2012
    I haven't seen any reports but it's good news overall.
  31. GRALISTAIR
    GRALISTAIR Established Member
    3,550
    11 Apr 2012
    Dalton Georgia USA
    It is a great document and I have had quite a thorough read. Always a problem when people who know what they are doing meet with politicians.
Share This Page
