Aberystwyth to Cardiff via Derby
krus_aragon
10 Jun 2009
North Wales
Hi,
I'm going to be combining a work journey with a leisure journey next weekend. I want to go to Derby for the weekend (out 29/06, back 01/07) but will be in Aberystwyth on Friday morning, so I'd rather travel straight from Aberystwyth to Derby, then come back home to Cardiff on the return leg.
I can claim the the cost of the AYW-CDF journey as a business expense, so I could buy an AYW-CDF single (and receipt) and then excess it to an AYW-DBY single, and buy the BDY-CDF leg separately.
Alternatively, The cost of an AYW-DBY off-peak return ticket is practically the same price as the AYW-CDF single, and I won't need to present the ticket to claim, only the receipt. As I've been caught out misinformed on excesses in the past could a learned person check that I'd be correct in asking to excess the return leg only to travel DBY-CDF, and the correct price I'd be expected to pay? I will be using my Y-P railcard for all journeys.
Thanks.
dvboy
6 Sep 2011
I'm not sure on excesses so I will leave that to someone else to explore.
If not possible to excess then it's a tough one as an advance from Aberystwyth to Cardiff can be as little as £11.20 YP - will your employer allow you to claim for an Anytime Day Single at £32.80 YP?
That would allow you to break your journey at Shrewsbury, get a return from Shrewsbury to Derby (off peak return £21.85 YP) and can break that return journey at Birmingham and use an advance to Cardiff (£15.20 YP)
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
None of those look to me like situations where an excess would be appropriate. It's neither a change of route, over distance nor change of class. If you got an Off-Peak Return from Aberystwyth to Derby, then on the return leg you would need to buy a new ticket from the point where the routes diverge, which I think would be Birmingham.
bb21
Emeritus Moderator
4 Feb 2010
Agreed.
Officially you cannot excess an Aberystwyth - Cardiff ticket into an Aberystwyth - Derby ticket as Cardiff is not on a permitted route between Aberystwyth and Derby.
For the same reason as above, an Aberystwyth - Derby ticket cannot be excessed to a Cardiff - Derby ticket (return portion only) officially, as Aberystwyth is not on a permitted route between Derby and Cardiff.
dvboy
6 Sep 2011
Birmingham is not a permitted route on Aberystwyth-Cardiff which is why I suggested Shrewsbury.
OwlMan
25 Jun 2008
Bedworth, Warwickshire
A Swansea - Derby SVR is valid via Shrewsbury and is probably the cheapest ticket for travel from Shrewsbury - Derby - Cardiff (with most flows priced by XC cheap splits are hard to find)
London midland wouldn't sell me Aberystwyth-Cardiff via Birmingham
That's because there is no "via Birmingham" fare. They will sell an Aberystwyth-Cardiff via Any Permitted route.
(It is then down to the Routeing Guide to determine if Birmingham is on a permitted route)
They will, however, sell you separate tickets to/from Birmingham if you ask them!
dvboy
6 Sep 2011
What I mean is if I put in Via Birmingham on WebTIS it tells me no fares are available rather than showing the Any Permitted fare.
LexyBoy
Fares Advisor
23 Jan 2009
North of the rivers
WebTIS will only show fares where a single fare is valid for the journey entered - there is no such fare valid for AYW-CDF via BHM. NRE will show that the journey requires two tickets.
One of NRE's suggestions is Anytime Day Singles Aberystwysth-Gloucester (30.05 YP) and Gloucester-Cardiff (£11.20 YP). This would then require an Off Peak Day Return Birmingham-Derby at £9.75. The fares seem reasonable to me for this journey, but might be hard to explain for expenses purposes (I'd just claim the AYW-GCR ticket).
John @ home
1 Mar 2008
This combination won't work for the OP, who wants to travel Aberystwyth - Derby on 29 June and Derby - Cardiff on 1 July.
LexyBoy
Fares Advisor
23 Jan 2009
North of the rivers
D'oh! Could substitute a GCR-AYW SVR (£41.20) and use the return portion for the AYW-BHM and BHM-GCR trips... but I think dvboy's suggestion is better.
