Advance ticket following Eurostar arrival
Discussion in 'Fares Advice & Policy' started by BRM, 5 Dec 2018.
  1. BRM
    BRM Member
    28
    16 Jan 2015
    I'm travelling from Paris to St Pancras and then onto south Wales with GWR. Would an advance ticket be valid on a later service if the Eurostar arrival is delayed? I have booked the Eurostar so a through ticket is not an option.
    Rail Forums
  3. Wallsendmag
    Wallsendmag Established Member
    1,488
    11 Dec 2014
    Is there not a London Eurostar to South Wales option?
  4. Peter Mugridge
    Peter Mugridge Established Member
    9,915
    8 Apr 2010
    Epsom
    If it's Cardiff, there is a CIV ticket called Euro High Saver which is available single for £65.20 ( assuming no railcard discounts are available to you - it would be £43.05 with a railcard ) and would allow you on any train; it'll be available to other South Wales stations for a similar price.
    Origin code is 5470 ( London International CIV ) but you will have to show proof of your Eurostar booking when buying it.
  5. johnnychips
    johnnychips Established Member
    1,810
    19 Nov 2011
    Doncaster
    I make it £65.20 from London International LNE to Cardiff on brfares. This seems to be valid on any train if you can buy it, and would give you CIV protection if you got stuck in London. The Man in Seat 61 explains it better than I could.
    Edit:
    Peter - snap!
  6. Mag_seven
    Mag_seven Established Member
    4,358
    1 Sep 2014
    here to eternity
    You take the risk with an advance so no. Best advice is to purchase the CIV ticket described rather than an advance.
  7. ForTheLoveOf
    ForTheLoveOf Established Member
    5,024
    7 Oct 2017
    Advance fares to/from London International CIV are available for certain destinations. I have previously bought them at a Virgin ticket office (and used them). However they are not set for destinations towards Cardiff (GWR territory). The nearest you could get would be somewhere like Birmingham with a Virgin-set Advance.
  8. 30907
    30907 Established Member
    6,300
    AFAIK it is ATOC policy that inward journeys on ES are treated the same as any other: they will be accepted on a later train if there is evidence of the delay.
    However I have no personal experience of this - do others?
  9. SickyNicky
    SickyNicky Verified Rep - TrainSplit.com
    2,333
    8 Sep 2010
    Ledbury
    It's worth pointing out that the EU has recently decided:
    Of course, Brexit may have some impact on this, but this appears to give the same protection on split international tickets that we currently have on split domestic tickets.
  10. 30907
    6,300
    I would check with the Man in Seat 61. Unless something has changed, it only applies If the tickets are booked in one transaction, and the likes of Thello are not covered.
  11. ForTheLoveOf
    5,024
    7 Oct 2017
    I have made a new thread on this subject.
  12. johnnychips
    1,810
    19 Nov 2011
    Doncaster
    Whatever ticket you have, make sure the train manager on Eurostar stamps the Eurostar ticket if your train is going to be delayed. If he/she doesn’t walk down the train, ask at the bar and they will get them. We had a through ticket to Doncaster once tied to a particular train at Kings X. When the Eurostar was delayed, permission to travel on the next train was given without question on production of the stamped ticket. Another time we had to spend a night in London because of a delay (Eurostar refunded hotel), and once again there was no problem at all getting permission to travel next day.
  13. 30907
    6,300
    That confirms my theoretical understanding. The only qualification is that you must allow sufficient (as defined by online journey planners) cross London connection time.
  14. A Challenge
    A Challenge Established Member
    2,000
    24 Sep 2016
    Which for LONDON INTERNATIONAL (CIV) to LONDON PADDINGTON appears to be 35 + 40 + 15 = 90 minutes
  15. Crossforth
    Crossforth Established Member
    1,316
    20 Aug 2009
    Hey guys,
    Rather than starting a new thread I thought I would hijack this one.
    How do I book a CIV ticket?
    Not sure yet whether it'll be from Leeds or Liverpool but either way it'll be to London so I can get on a Eurostar which I have already booked.
    I only learnt about CIV earlier and I inspect tickets for a living :P
    Cheers
  16. ForTheLoveOf
    5,024
    7 Oct 2017
    You can't get CIV tickets for domestic British journeys anywhere except at a ticket office (well, or on a knowledgeable and helpful guard's ticket machine!). It used to be possible to get them online at a limited number of retailers; however, this was stopped as some passengers were using CIV tickets in a way they were not intended to be used (bearing in mind CIV tickets generally have fewer restrictions than equivalently priced non-CIV tickets).
    Staff are now instructed only to issue CIV tickets to passengers who produce a valid Eurostar ticket.
  17. Crossforth
    1,316
    20 Aug 2009
    Fantastic.
    I'll drop in on Lime St ticket office tomorrow after work then :)
    Thanks for the help
  18. mad_rich
    mad_rich Member
    106
    12 Feb 2013
    Newcastle
    Still available on Raileasy.
Share This Page
