Advance ticket for non-existent train !!!
Discussion in 'Fares Advice & Policy' started by mgood, 16 Aug 2019.
  1. mgood
    mgood Member
    19
    5 Jun 2011
    I bought an Advance ticket today for the 14:29 from Crewe to London on Mon 26 August. Afterwards I found an 'amended timetable' in a section about about Bank Holiday works which shows the train isn't running !! Why are Virgin selling tickets for non-existent trains ? Any thoughts
    PS - you can still buy them now !!
    Rail Forums
  3. _toommm_
    _toommm_ Established Member
    2,568
    8 Jul 2017
    Glossop
  4. mgood
    mgood Member
    19
    5 Jun 2011
  5. yorkie
    yorkie Administrator Staff Member Administrator
    43,663
    The question is wrong; all retailers are required to offer itineraries on trains that are shown as running in the timetable feeds.
    The question should be: why have Virgin Trains changed their timetable at short notice? It will probably be down to Network Rail giving them less than the supposedly required 12 week timetables for the works.
    The train will disappear from the feeds soon; probably tomorrow if they marked it for removal today.
    Your options are:
    1) claim a full refund ;
    2) depart earlier in order to arrive on time; or
    3) depart on the first available train after the booked time, and claim Delay Repay if you arrive sufficiently late.
  6. mgood
    mgood Member
    19
    5 Jun 2011
    Presumably options 2 and 3 are allowed even if its an Advance ticket for a specific train ?
  7. _toommm_
    2,568
    8 Jul 2017
    Glossop
    Absolutely - it's not your fault if they've removed a train from the timetable, although you won't have a seat reservation unless you make a new one.
    There's a train at 14:01 from Crewe which arrives into London at 16:32, or one at 14:56 arriving 16:36.
    The second train will get you into London exactly half an hour late, allowing you to do option 3 that Yorkie suggested.
    EDIT: Amended arrival times.
  8. yorkie
    43,663
    The choice is yours!
  9. causton
    causton Established Member
    5,342
    4 Aug 2010
    Are we all jumping the gun a bit?
    It may just be missing from that PDF timetable.
    The one an hour before and an hour after (and two hours after as well) runs.
    Maybe it might be worth checking if it actually is cancelled before using a backup plan!
  10. robbeech
    robbeech Established Member
    2,689
    11 Nov 2015
    Actually, you MAY have a seat reservation. Frequently trains are just re timed significantly (to add time for a diversion) so more often than not your seat will be on the train before or after the one that no longer exists. Of course, finding this out isn’t always straightforward. Staff will likely have no idea.
    This situation is all too common now.
  11. Haywain
    Haywain Established Member
    3,820
    3 Feb 2013
    Is there really a train with a 40 minute schedule from Crewe to London?
  12. _toommm_
    2,568
    8 Jul 2017
    Glossop
    That would be nice wouldn't it!
  13. Wallsendmag
    Wallsendmag Established Member
    1,665
    11 Dec 2014
    Who needs HS2
  14. M28361M
    M28361M Member
    304
    15 May 2014
    The PDF timetable for Monday 26 August is showing several trains with codes for Fridays Only and Fridays Excepted at the top of the column, so I think we can safely assume there are a few mistakes in it.
    The 1429 starts from Manchester Piccadilly at 1355, and Virgin's "spanner" page mentioned upthread says:
    Your train is after midday on 26 August, so a normal timetable should be in operation by then.
    Just looked and your train is still showing up with Advance tickets available. It might be worth printing off an itinerary showing that train (if you don't have one with your booking confirmation), so you have proof just in case that train does get deleted in the next few days.
Share This Page
