Advance ticket refunds-Train Split (posting tickets together)
Discussion in 'Fares Advice & Policy' started by VT 390, 24 Mar 2020 at 16:41.
  1. VT 390
    VT 390 Established Member
    1,325
    7 Dec 2018
    Now that Advanced tickets can be refunded for journeys booked through train split I will be applying for a refund on a lot of tickets.
    As I have already collected all the tickets I will need to post them off to get a refund, even though they have been booked through separate bookings (all through train split) and will require multiple refund forms to be filled in but can all the tickets be sent together in the post?
    Rail Forums
  3. Bletchleyite
    Bletchleyite Veteran Member
    48,433
    Up and down the south WCML (mostly)
    Can't see any reason why not.
  4. CrispyUK
    CrispyUK Member
    46
    19 Jan 2019
    As Bletchleyite has said, I don’t see any reason why you couldn’t do this, but I would suggest you make it easy for them to process by attaching the relevant tickets to each refund form.
    As you’ve said a lot of tickets, depending on the overall value consider whether you send them back via Special Delivery or some other suitably insured option.
  5. VT 390
    1,325
    7 Dec 2018
    Thanks for the reply, I see what you mean about making it easy for them to identify each ticket.
    I will definitely be sending them via some sort of special delivery, which is why I would rather send them all together so I do not end up having to pay for lots of separate postage.
  6. alistairlees
    alistairlees Established Member
    1,561
    29 Dec 2016
    Ask trainsplit if they will accept images of the tickets cut in half? @vt390
  7. VT 390
    1,325
    7 Dec 2018
    Good idea I will contact them and ask if this is possible.
Share This Page
