Why can't the railway companies just clear this up?
If they cause a delay then they should be responsible for it - what difference does it make to them if you get on the next train instead?.
So why would Cross-country be responsible for a delay on a Virgin service? The railways are now separate companies all this talk of "the railway" is irrelevant, "the railway" went to the wall at privatisation!
If the first journey is delayed the responsibility is to get you to the destination, in this case Wolves, NCoC state "it is YOUR responsibility to get to your starting station in good time", so i read it (Yorkie doesn't) that YOU must get there as this is 2 separate journeys even if booked at the same time.
Why can't they just sell the through ticket anyway - it's not exactly rocket science to implement?
He can buy a through ticket, it is just more expensive, possible because the fare is set by a different TOC to the split tickets. Yes it is ridiculous and no I don't want to go there.
Cross-country, for example, actually tell you to buy separate tickets for a single journey on their website; it does not come with a warning that you may be stranded.
Take it up with Cross Country and let us know what the response is, you could ask about connections as well.
I would also buy both tickets, at the same time, from the website of the TOC that is running the second service - they can't then deny all responsibility if they sold you the tickets in the first place.
Not really relevant because I can buy separate tickets with a connection time in negative numbers, it is up to YOU to ensure you have sufficient time for the connection.
To answer the OP, if the first train is delayed then find the guard (or whatever they are called this week) and ASK them to endorse your ticket about the delay, although the guard on the second train is NOT obliged to carry you this should help, basically if you put a bit of effort in to help yourself then it can only be a good thing, or buy a through ticket and all these problems magically disappear.
I do agree with Yorkie (yes honestly) on one thing that the whole ticketing issue needs throwing in the bin and start again with a blank sheet of paper.
I agree with Yorkie that two or more advanced tickets can be combined to form one journey. If you are delayed on that journey then you are allowed to complete it on the next available train.
ATOC also confirm that two or more advanced tickets can be combined to form one journey on their best value fares website at
http://www.bestvaluefares.co.uk/
This confirms that advanced tickets can be mixed to make one journey.
Peter
it all depends on the definition of "journey", now lets say I consider a "journey" is from my starting point (work) and my destination (home), so in that case if I miss the last bus because the train is late do they get me a taxi, um nope its my problem, so I define a railway journey as what is written on the ticket, if I have 2 tickets then that is 2 journeys.
If you buy 2 tickets FOR THE SAME TRAIN, then you will still be on the original train so no issue, but if you have 2 seperate journeys on 2 different trains then that can be a problem, its all a question of interpretation and it needs sorting.
