Air Flow to Coaches in Tunnels.
Discussion in 'Traction & Rolling Stock' started by Envoy, 14 Nov 2017.
  1. Envoy
    Envoy Member
    699
    29 Aug 2014
    Modern cars have a feature whereby when in traffic jams, the air system can be switched from sucking in external air to re-circulating air to prevent pollution entering the vehicle. Do trains have a similar feature and if so, do drivers use it?
    (I have smelt diesel fumes when in tunnels although on HST’s, I suspect that much of this enters through door windows left open. It is regrettable that Box tunnel between Chippenham & Bath has the electric conductor rail but will not be linked to the electric system for some time. It is also regrettable that apart from London trains, the Severn tunnel will still have an entirely diesel fleet going through it. I just hope that the Turbos will have their windows closed and a working air-con system in operation).
  2. coppercapped
    coppercapped Established Member
    1,334
    13 Sep 2015
    Reading
    Wimp! :D
    You should have gone through the Severn Tunnel in steam days...
    ...what's the matter with young folk today?
  3. randyrippley
    randyrippley Member
    823
    21 Feb 2016
  4. pdq
    pdq Member
    341
    7 Oct 2010
    On 185s the A/C fans automatically switch off and back on while going through Standedge Tunnel.
  5. BrunswickGreen
    BrunswickGreen Member
    37
    12 Jun 2015
    In fact in those days it was almost compulsory to make sure the train windows were open when entering a tunnel (different times). Travelling between Gt. Malvern and Hereford was a particular favourite route.:rolleyes:
  6. sprinterguy
    sprinterguy Established Member
    8,793
    4 Mar 2010
    Macclesfield
    Yep, in place of the more common wire based overhead catenary; installed due to limited clearances in tunnels such as Severn and Box, amongst others (Example within Stanton Tunnel on the Old Dalby test track pictured below).
    There's some more information on the Great Western installation of overhead conductor rails here:
    https://www.railengineer.uk/2016/07/11/developing-rocs-for-the-uk/
  7. randyrippley
    randyrippley Member
    823
    21 Feb 2016
    thanks, I didn't realise they were using that
    I assumed the poster was referring to 3rd rail.......
  8. sprinterguy
    8,793
    4 Mar 2010
    Macclesfield
    Yes, it took me a little moment to work it out before my brain caught up with what I was reading, too. :D
  9. rebmcr
    rebmcr Established Member
    2,001
    15 Nov 2011
    I believe a while back, when discussing the St Pancras Low Level installation of Rigid Overhead Conductor, one of the electrification engineers on here confirmed that it does not offer any enhanced clearance, but is instead justified on the massive reduction in maintenance requirements.
  10. sprinterguy
    8,793
    4 Mar 2010
    Macclesfield
    Fair enough, though the article I linked to certainly does make the point that it does allow for electrification in restricted clearances that would otherwise prove difficult.
  11. DelW
    DelW Member
    356
    15 Jan 2015
    To be pedantic, a rigid conductor rail would need less vertical space than a catenary cable would, since that has the form of a vertical curve. it would be possible to fix a conductor wire to the tunnel roof without a catenary cable, on a similar alignment to the conductor rail, but that would need more closely spaced supports, which might be a part of the difference in maintenance requirements mentioned.
  12. route:oxford
    route:oxford Established Member
    4,224
    1 Nov 2008
    Should try the "Weegie stink" on the way into Glasgow Queen Street. It's utterly bouffin.
  13. 380101
    380101 Member
    379
    18 Feb 2015
    It'll be less "stinky" come December for a wee while. Then it'll be worse again once the HSTs enter Scotrail service.
  14. Bald Rick
    Bald Rick Established Member
    5,964
    And reliability. It will take a big whack to make it fall down!
  15. gimmea50anyday
    gimmea50anyday Established Member
    2,161
    8 Jan 2013
    Durham
    Do they? Thats news to me....
    Expect you are thinking of Eco mode. One of the engines shuts down when no longer required. Usually once up to speed on the ECML or at the top of the hills. York to scarborough and occy road to liverpool are also often run on eco 2 as the high power isnt needed. It takes a few seconds for the auxiliary power to switch from the shut down engine to crossfeed from one of the remaining running engines and its this power switching that shuts down the HVAC momentarily. Eco often kicks in in standedge as when the train emerges from the other end of the tunnel its down hill all the way to stalybridge or Dewsbury so the traction power isnt needed!
    Crossfeed - when one engine is supplying auxiliary power to two coaches. You can tell which engine is cross feeding as the RPM of the engine will be running at 998 instead of 847 when idling.
  16. pdq
    pdq Member
    341
    7 Oct 2010
    I'm pretty sure about this, having commuted to Manchester between 2010 and 2015. The ac fans go off at Marsden and come back on at Diggle - and vice versa. It's always at the same place so is controlled, I assume, by GPS.
    I remember once we got held for 20 mins or so at the last signal before the tunnel eastbound, just after the A/C had gone off. By the time we got moving the temp and air quality were both pretty unpleasant, but recovered at Marsden.
  17. edwin_m
    edwin_m Veteran Member
    11,024
    395s close the aircon intakes when entering tunnels on HS1. I think this is to reduce the pressure pulse inside the train, and they may re-open when within the tunnel - it probably isn't to do with diesel fumes!
  18. pompeyfan
    pompeyfan Established Member
    1,297
    24 Jan 2012
    Going through Southampton tunnel in a Desiro when an older 66 is passing through is similarly unpleasant... although going through Southampton in general is also unpleasant :D
  19. DarloRich
    DarloRich Veteran Member
    15,757
    Work - Fenny Stratford(MK) Home - Darlington
    Ah so it is 998 revolutions. I only managed to count 996 ;)
    Should have tried Sunderland station when a 56 was starting a long coal train away. Kids today!
  20. gimmea50anyday
    2,161
    8 Jan 2013
    Durham
    Thats what it says on the TMS anyway...
  21. DarloRich
    15,757
    it is fairly obvious, form a passengers point of view, when the system has gone into eco mode. mainly because the carriage is often very quiet. It seems a very good idea!
  22. gimmea50anyday
    2,161
    8 Jan 2013
    Durham
    When you havent got a QSK19 purring away underneath the carriage it does make quite a difference to the "ambiance" of the train. I am amazed how the same engine sounds completely different on a 185 to a voyager or a 180
    If you like your thrash, From a staff members point of view centre cabs of a 6 car bowling thru standedge with all 6 engines at full bore does sound pretty immense!!! FULL POWER NOW SIR!!! XD
  23. tsr
    tsr Established Member
    6,183
    15 Nov 2011
    Ballast
    Soft. We have 10 coach diesels down here.
    No major fume intake in the tunnels on the Uckfield either. (Class 171 HVAC tends not to actually do anything noticeable anyway, so the chances of it drawing in diesel fumes are not too high!)
  24. Envoy
    Envoy Member
    699
    29 Aug 2014
    That’s interesting. I note that when going through single bore tunnels in particular, that air pressure on the ears can be very uncomfortable. The Dinmore tunnel on The Marches comes to mind though I have also encountered this on the twin track Chipping Sodbury tunnel.
  25. dk1
    dk1 Established Member
    4,972
    2 Oct 2009
    East Anglia
    I quite enjoying following a filthy diesel into Ipswich tunnel when it's a thick smog. People are far too worried about their lungs these days :lol:
  26. Master29
    Master29 Member
    615
    19 Feb 2015
    Says he on 40 a day;). Wouldn`t do me much good now at my age but was great wafting in all those fumes at both Liverpool Street and Paddington when I was younger. I`m asthmatic too. Nowadays I spend most of the time in tunnels stopping the blocking sensation in my ears:s.
Share This Page
