Alternative routing with advance fare permitted?
tornado
6 Apr 2010
hi,
i am planning to buy an advance ticket from Kings Cross to Guiseley (GSY). Normally this routes via Leeds with a change onto a WY Metro between Leeds and Guiseley.
however if I get the 18:33 from KGX it routes via Shipley with a change to a WY Metro train to Guiseley. However I know from experience that I can change at Leeds. The reason that routing isn't showing is that it is 1 min less than the (generous) minimum connection time at Leeds.
am I allowed to end my journey short at Leeds, and then change onto a WY Metro, instead of continuing to Shipley?
hkstudent
11 Nov 2018
SE London
hi,
The 10-minute interchange time at Leeds Station is not considered too generous as you may need to go up to a footbridge for interchange between platforms...
You are not allowed to change any bits of travel in the Advance ticket. You need to travel the full bit of journey of each segment.
Leeds Station has guarded ticket barriers, no chance...
30907
hi,
The strict answer is NO, but IMO you are highly unlikely to be challenged, and in any case staff are instructed to use discretion where people are not taking the proverbial....
In normal times you would have time at Leeds to walk over from P8 to the Ilkley train ON P3, ask permission to travel, and if refused walk back again. However there is reportedly a one-way system in operation...
alistairlees
29 Dec 2016
hi,
Currently complete ticket acceptance is in place. If you are doing this journey soon (as opposed to, say, in September), then I cannot see any issue at all with getting a train from Leeds to Guiseley, rather than going to Shipley and getting a train from there. Even under normal circumstances I can't see any issue arising - there would be no financial gain, and no-one would be worse off. I suggest you just do it.
hkstudent
11 Nov 2018
SE London
But I am kind of concerned that once the OP is being refused to board, he can't continue his journey with the LNER train as that will be long gone...
In that case, would be OP be required pay the difference between the advance fare and a full anytime fare for London - Leeds journey?
No, I think Northern may be slightly worse off by that, as Northern is only be allocated revenue for Shipley - Guiseley section, which is shorter than Leeds - Guiseley section...
Hadders
27 Apr 2011
The OP is going from Kings Cross to Guisley so he'll be changing onto Northern not LNER at Leeds.
I agree with @alistairlees that this is unlikely to be an issue although do be prepared to follow the one way system. There shouldn't be any barriers to pass through.
tornado
6 Apr 2010
I should add that the LNER train from Kings Cross to Bradford (stopping at Shipley) waits 13 minutes at Leeds station (dwell time), which is partly why changing there is more sensible.
They normally check tickets once the train from Leeds up to Ilkley is in motion, so it would be a bit late to go back and get on the LNER at that stage...
Is this journey being made before the timetable is restored (which I think is the 4th of July)?
If so then there is acceptance in place (and an on board check would be highly unlikely).
Beyond that, it wouldn't technically be permitted, but you can force a change at Leeds (some booking engines allow this) and simply take an earlier connecting train from Leeds if you make the connection.
Taking an earlier train on the connections leg is generally deemed to be reasonable. But if you are concerned you could seek permission form the Guard prior to departure at Leeds.
tornado
6 Apr 2010
It's probably late july/august.
Forcing the change at Leeds would seem ideal, but LNER booking engine doesn't seem to do the trick even when ticking VIA and inserting Leeds.
Also, anyone know why the Bradford train waits 13 minutes at Leeds? pathing issues?
LNER don't provide that functionality.
A site that does offer that, and also offers a seat selector, without charging a fee, is Trainsplit.com (click advanced options)
Possibly that and also bear in mind that it needs to reverse (unless they give up the Wakefield call, which would also require the use of a bi-mode unit)
30907
There isn't a later Ilkley train ATM, so even "avoid Shipley" won't produce anything.
The wait at Leeds is largely for the crew to change ends, plus a bit for pathing.
A journey for July can't be booked yet but it shouldn't be an issue once the timetable is finalised and bookings are open.
AlbertBeale
16 Jun 2019
How does giving up the Wakefield call avoid reversing at Leeds? There's surely no feasible route to bring you in to Leeds from the east, so as to continue forwards to Bradford; or if you mean skipping Leeds completely, then wouldn't the obvious route take you through Wakefield anyway - but just via Kirkgate instead of Westgate?
alistairlees
29 Dec 2016
As you say, come into Leeds from the East. Route being, after Doncaster, to proceed up the ecml to hambleton junction, then go via south Milford, micklefield and Cross Gates. Some services used to do this.
Tetchytyke
12 Sep 2013
Isle of Man
You could try requesting additional time to change, that's likely to knock you onto a later connection at Leeds. As there are no reservations, you can take any reasonable connection, so just get on the earlier one
Alternatively leave it as it is, you'll not have issues but if the LNER is late you could still catch the connection at Shipley.
30907
When the full Ilkley service is restored, the first option will be possible, but you lose the option of going via Shipley, so I wouldn't go for it.
AlbertBeale
16 Jun 2019
Thanks! Sorry - I must have missed spotting that chord at Hambleton on the map I looked at.
kieron
22 Mar 2012
Connah's Quay
You'd actually need a couple of restrictions. One to force it to use a Leeds-Ilkley train ("avoid Shipley" would give you this on LNER).
The other is to force it to give a longer wait than you need. There isn't a valid connection between the 18:33 to Leeds and the 21:03 to Ilkley, as you mention. There is a valid connection between the 19:03 to Leeds and the 21:33 to Ilkley, so if you just put "avoid Shipley" into a web site, it probably won't give you the 18:33 at all. If you added (say) 15 minutes to the connection time, it would give a connection between the 18:33 and the 21:33. That's not something the LNER web site can do. As far as I can tell, your choice is between using a different web site or booking via a human.
tornado
6 Apr 2010
Best bet is to go to national rail set up the journey as you want it then the hand off to the LNER site will have the journey as specified
There doesn't seem to be any VIA or AVOID options on the national rail site?
edit: oops found them
kieron
22 Mar 2012
Connah's Quay
Sadly, the National Rail site only offers delays of an extra 30, 60, 90 or 120 minutes, none of which are any good for this purpose.
I don't understand how it's any better to fiddle about with NRE and then re-direct to LNER, when a third party website will allow you to specify advanced options, including forcing a change with a custom extra duration, which does it all in one go.
In the past I'd say it was worth the faff to access the seat selector, but that's no longer an advantage. Also the LNER website might charge you more.
Wallsendmag
11 Dec 2014
Wallsend or somewhere in GB
I guess we both have unbiased views ;)
30907
Putting in 1hr works well enough.
The problem was that the 2103 is the last train from Leeds to Ilkley currently; a 2233 has been added from 6 July so the journey is possible (NRE still has a warning against it, but it shows a fare.
tornado
6 Apr 2010
Doesn't seem to work for me. With travel VIA leeds and 1 hour change, it routes via Bradford!
