American Express
reclusive46
4 Aug 2012
Hi,
Can I just get on any train in the country and pay by card once on the train or do you have to buy the ticket before you get on? If so do they take credit cards (Specifically Amex)?
If you can buy a ticket before travel then you must. The only times you're generally allowed to board and buy on board is where there is no open booking office or no working ticket vending machine.
I'm not sure about Amex acceptance unfortunately.
Also welcome to the forum and if you have any more questions about ticketing or anything else to do with the railways we'll be more than happy to help :)
RJ
25 Jun 2005
Rail replacement bus cab
Hi,
In general, you must obtain a valid ticket for travel at the first possible oppprtunity. If you choose to pass up the opportunity, various things can happen. Some companies will only allow the purchase of undiscounted tickets on board. Others will issue a Penalty Fare which is twice the undiscounted fare or £20, whichever is greater. You may even be prosecuted for failing to produce a valid ticket when requested, which would result in a fine and possibly a criminal record.
Sometimes, it is impossible to obtain a ticket prior to boarding a train. In this circumstance, you can buy a ticket at the first opportunity without any penalty. This may be on board the train, or at the destinaton for example.
I use American Express and have never had a problem using it to buy a ticket on the railways.
island
30 Dec 2010
There are apparently some Northern vending machines that don't accept Amex, but all train operating companies are required to accept it so you would probably be OK to buy on board if using one of those stations. Every booking office and every other TVM I know of accepts Amex.
It is less clear-cut if the only facility at your departure station is a permit to travel machine, as these only take coins. I would insert some coins in these circumstances and get a permit, just to be safe.
