In respect to door-to-door journey times, it’s probably going to be close to competitive (although if your departure point or destination is close to an airport, perhaps not).Hmm.
Can't see how this is really competitive compared with airlines, both on price and journey time (even taking into account security at airports).
However, does it have to be competitive on both? It’s going to be a lot more productive for work that’s for sure, less of the hassle of getting on and off a plane etc and easier to work onboard. It’s also going to be a lot more pleasant experience for those who do not enjoy flying.
Many London-Scotland trains are also not competitive on price or journey times with air travel but are still well utilised.
It was just like the previous try. The run from London to Amsterdam went without issues (or better, without any delays), the return leg suffered from the same issues as before: the change from the Dutch ATB safety system to ETCS didn't happen as expected and the train was stopped by the safety system, which turned out to be exactly in the voltage change-over from 1.5 kV DC to 25 kV AC. Suffice to say that the VCO didn't contribute to a swift solutionSounds like yesterday's test run didn't do so well on the return leg - broke down for over an hour at Hoofddorp. Hopefully that doesn't translate to a delay to the launch.
On a different but related note: If you log into Eurostar.com and tell it you are Dutch, you still get access to the "Any Dutch Station" fares. However, my Dutch isn't good enough to work out if these are not valid on Thalys. I suspect the answer is they are not, however they are cheap enough still to be interesting.
It seems like Siemens has not been able to fix it yet, or it might be a problem with that specific train set.
There's the matter of onward connections from London. Arriving into London at 19:57 means being able to get a connecting service from other termini (Euston, Paddington, Waterloo, and so on) around 20:30 - 21:00.
As far as I'm aware the e320's are all equal when it comes to where they can run.
Eurostar start with two trains a day, but it might be increased if there's enough demand.
I can't see how London alone couldn't have enough people wanting to go to Amsterdam to do a good leisure trade alone, let alone the business market and those outside Greater London.
The longer journey time starts to make a difference here. Under 3hr centre to centre the train is likely to carry many more passenger than air, but once over 3hr the balance start to tilt. Randstad is also more dispersed, probably increasing the proportion of people who can more easily access a flight at Schipol more easily than Eurostar.The Randstad city-region (consisting of Amsterdam, Rotterdam, The Hague and Utrecht) has a population of over 7 million, so the accessible market is almost as big as Paris.
For that reason Eurostar probably see their local catchment as more Amsterdam itself than Randstad. This may explain the relatively early departure time of the evening train, mentioned above as too early for many business people who need to connect from somewhere outside Amsterdam.
If they have to change at Amsterdam then for some of them it's probably just as easy to connect at Brussels into a later service.
I've even seen Amsterdam-based people saying this is too early, given the need for check in and the time it takes to get there, you are leaving the office / meeting before 4pm.
I seen a post on Twitter a while back saying there’s only two with the extra dials or something for signaling that can work to Amsterdam. If that’s true it will limit expansion of services unless they can upgrade the other trains?
