.. is his 14th century castle, with 16th century house and Victorian neo-classical Mansion - obviously!
A trip to Belsay Hall and Castle in Northumberland this weekend has resulted in two new scenery objects being added to the Object Library at BVE Pages. The Castle is a "flat" object to a height of 22m, and should work well if you need a castle on the horizon. The Victorian Hall is a large 3D object, built negatively, and approximately 32m square in plan.
No grounds are supplied, so you can combine the hall with grass and trees, gravel or roads as you wish - for example, the hall might work well as a Town Hall.
Click the image to start your download.
Regards
eezypeazy
Regards
eezypeazy
