If you have a '[TOC] and connections' Advance ticket, and the train operated by the TOC in question is delayed so you miss the intended connecting train, does anyone know what the rules are about which train you can take instead?
1) If the missed connecting train is reservable, can you take the next suitable train whether it is reservable or not? If that train is also reservable, does it matter which TOC runs it?
2) If the missed connecting train isn't reservable, do you have to wait for the next non-reservable one, or can you take a reservable one instead if it will get you to your destination sooner? This has been brought to my mind by an actual example: I've just bought a 'VT & Connections' Advance from Windermere to Leamington Spa, involving a +7 connection at Coventry into the local service to Leamington. If this is missed, do I have to wait for the next local an hour later, or can I take the XC that gets to Leamington somewhat sooner?
(And if my ticket can be used on the XC, would the fact that it's a 1st class advance mean that I could use it in 1st? -- it's a 1st class ticket to Leamington, but not intended to be used in 1st on that leg).
My journey to Leamington is in fact part of a split (bought through Trainsplit in one transaction, so the connection times must be OK) involving another tight connection into a train to Oxford, but if staff are aware of the rules (is there a significant risk that they won't be?) there presumably shouldn't be a problem using the Leamington-Oxford ticket on whatever XC train I end up on (I'm not expecting to use it on Chiltern + GW as it's XC only).
