Is there a link.Colas rail advertising for Apprentice Freight train Drivers full description on their website.
It's not exactly hard to findIs there a link.
Ah didn’t realise it hasn’t closed yet. It’s up for quite a long time for a driver vacancy isn’t it!
Hi,
I have not heard anything yet I guess they are still taking applications.
I get the impression there are many vacancies available since they say they are expanding.
Hi all
Is it worth completing the optional section on the application? Is it looked into and used at all? Good luck to all applying!
£51010 last I heard.Does anyone know how much they paying
I did, it asks a couple of relevant questions and gives you the chance to give a bit more information about yourself. I can't see it doing you any harm unless you answer no to any of the questions in which case you maybe shouldn't apply.
Thanks - thought that was the case. Can’t see anywhere to attach covering letter, guessing just make that page 1 of CV?
None of the posts on Colas' website seem to have closing dates so goodness only knows when this one will close!
Trouble is, apparently they are not expanding - not on the commercial freight side at least. The story goes that that side of the business will be reduced with more emphasis on servicing Network Rail contracts. Im told the recruitment drive for trainees is to replace drivers who keep leaving for other companies. The above I hasten to add is just the persistent rumour going around within circles inside 'the trade'.
I personally believe you have your psychometric pass then you do have a head start on other people the reason I say this they can interview you knowing you have already passed.
Thanks chaps your encouragement is much appreciatedTeddyward fingers crossed for you the psychometric test should give you a great chance.
Is the vacancy still open? Crumbs!
