Are 67s still doing Manchester to Holyhead?
Iskra
11 Jun 2014
West Riding
Hope it's sorted by next Monday as I'm booked on it in first. Won't be happy with no tea and on a crush-loaded 175, not for the first time...
Why do they even need a DVT, when they have all day to run around at Canton? Guessing it's the Holyhead end, but again they must have time to do it overnight?
FrodshamJnct
14 Apr 2019
Cheshire
There is no first class on the Manchester set. The DVT is on the Manchester end, with the set stabling in Crewe overnight.
craigybagel
25 Oct 2012
Several reasons
The DVT provides a guards van with all the required safety equipment, brake controls (for brake continuity tests) and space for luggage.
The DVT also means that the Premier service can reverse at Chester and serve Wrexham.
But anyway, this thread is about the North Wales set - which changes direction 5 times during the day and thus requires a functioning DVT, which at the moment it doesn't have.
krus_aragon
10 Jun 2009
North Wales
It could run-around its stock at many of those reversals (Chester, Llandudno, Holyhead) given enough turnaround time, but I've got no idea if there's a suitable location to do so at Piccadilly any more.
mrcaa
12 Mar 2019
The 175 may have been crush loaded but one silver lining was that the PA was broken in the rear carriage. Just some faint crackly mumblings coming from it. Absolute bliss! Of course everyone left all of their belongings at their seats, as there’s no way they could have known they were supposed to take them with them without being told, but it was a price worth paying for peace.
Bovverboy
1 Dec 2013
I appreciate that this is probably a silly question, but could someone possibly remind me what advantage a four-car LHCS set has over a four-car DMU?
It allows a 4-car DMU (or more likely 2 separate 2-car sets) to do more messy stuff elsewhere (Valleys etc).
The Manchester Mk3 set exists because DB (not Arriva) donated it as part of the deal with DfT for them to take over the Chiltern and LO franchises.
krus_aragon
10 Jun 2009
North Wales
In the Manchester - North Wales case, it has the advantage that disused LHCS is available, whereas additional DMUs arent/weren't.
For Holyhead-Cardiff, there's also the existence of a kitchen car for first class meals. In the longer term, once new-build DMUs arrive, this will be the only remaining advantage.
TheGarner
11 Dec 2016
The loco hauled service also has an advantage that it's quite long in terms of the coaches so you can get quite a lot of people on and theres lots of standing room too. When it gets replaced with a smaller 3 car class - you can definitely tell and is packed as soon as you leave Manchester.
fairlie
18 Mar 2010
LHCS is also nicer to travel on because you don't get the engine noise/vibration.
Y Ddraig Coch
1 Nov 2013
I'm not sure Llandudno has the run around loop anymore, it would need to shift the whole train down to the siding and do it there which would be quite time consuming. Although in the evening it does have about 30 minutes dwell time so could possibly be done.
FrodshamJnct
14 Apr 2019
Cheshire
Absolutely. I’d take over a 175 any day. Looking forward to the Mark 4s being introduced on the 16th. Waiting to see which 67 it’ll be also.
Jamesrob637
12 Aug 2016
Not heard that the plans have been changed so should be, yes.
Hmm. 16/12 isn't that far off. Does the set operate Sundays? That gives TfW one day less again. Should this thread title be changed to something like "Loco-hauled Manchester to North Wales" as we're in the transition process from Mk3 to Mk4 yet the motive power will remain the same?
Y Ddraig Coch
1 Nov 2013
Doesn't work Saturday or Sundays.
There is the odd exception.
krus_aragon
10 Jun 2009
North Wales
The loop's still there in last month's PDF copy of the sectional appendix, but I don't know what the situation is in the signalbox itself.
craigybagel
25 Oct 2012
As nice as the LHCS is, it had only one advantage at the time over DMUs that actually mattered.
It was available. DMUs weren't.
Merle Haggard
20 Oct 2019
Northampton
On every occasion when I've travelled on this train from Holyhead I've noticed that the rear coach (next to the loco) is locked, with a printed notice saying 'Out of use' in the droplight. It seems to happen so often that it surely can't be a defective coach. This means, of course, that it's a 3 coach train (although the stations announcements always say 'this train is formed of 4 coaches').
Curiously, joining the Holyhead service at Piccadilly I DID manage to get in the front coach (I wasn't first, I followed a lot of other passengers) and it wasn't locked. It seemed to get locked at Holyhead, though.
Perhaps it's something to do with a short platform somewhere, but why have 4 coaches if that's the case?
craigybagel
25 Oct 2012
The platform at Helsby heading towards Manchester is too short to take 4 cars. The coach nearest the loco is normally unlocked on arrival at Frodsham. All 4 cars are needed through to Manchester, as shown by the overcrowding this week whilst it's been operated by a 3 car 175.
Merle Haggard
20 Oct 2019
Northampton
Thanks for that explanation. However, I have encountered it being locked West-bound as well but, as I travel only perhaps once every two months, I accept my experience is anecdotal; and also the demand in that direction is met by 3 coaches. Even 3 mk3s seat 24 more than a 3 car 175, to add to the overcrowding when the latter is used.
Penmorfa
16 Nov 2011
North Wales coast
The crossover is worked from a ground frame not the signalbox. So it requires the attendance of an extra member of staff to operate it.
krus_aragon
10 Jun 2009
North Wales
I should have remembered the ground frame, having played around with it in SimSig a few times. :oops: I guess I should have said was "I don't know what the situation is at the station itself".
Y Ddraig Coch
1 Nov 2013
Yes that one with the ground frame is still there near the siding is still there I was meaning the run around section on platform 1 & 2 I think that has gone now.
craigybagel
25 Oct 2012
Hmm, not sure about that then I'm afraid - other then the fact it's a bit awkward to lock/unlock a coach on the MKIIIs so there may keep it closed except when absolutely necessary?
And that's before you add the requirement for a shunter/other person qualified to couple the loco up to the coaching stock. TfW guards are not qualified on that any more.
Moving on, the DVT was brought down to Cardiff yesterday for repairs.
